Context menu - reload Document not working
Quote from ihayes on June 2, 2025, 11:39 pmI'm using SimulIDE for programming Arduino. If I edit a program in another editor and either use the context menu->reload document or press ctrl+r the document does not get reloaded. To confirm both editors are seeing the same file I close and reopen the file in SimulIDE and the changes then appear.
OS: Linux
version: 1.1.0-SR1 rev 2005
build Date 2024-10-17
OS: Linux
Quote from arcachofo on June 3, 2025, 2:59 pmThank for reporting.
It will be solved in next versions. Including tester builds: https://simulide.com/p/testers/
