CircuitView. Scroll instead of scale in case of Keyboard modifier (Ctrl/Shift) is used.
Quote from ru5t on June 5, 2024, 5:56 pmHi all!
I've used SketchUp web for some time and really like it's scrolling approach - moving two fingers on a trackpad while Shift is pressed leads to horizontal / vertical scroll. Depending of the movement direction.
I tried to somewhat recreate this for Circuit view. In a much simplier way - no movement direction detection . Just a wheel event + Ctrl/Shift modifier for vertical / horizontal scroll. And failed). I mean it was a quick attemtpt. I don't have QT development environment set up - no QT creator or any other QT-specific tool and sadly no QT skills. I'm just using a latest dev build.
I wanted to give it a quick try using google and common sense) no luck.void CircuitView::wheelEvent( QWheelEvent* event ) { // add scroll instead of scale when Cth or Shift is pressed during wheel event bool noModifier = event->modifiers() == Qt::KeyboardModifier::NoModifier; if (m_showScroll && !noModifier){ if (event->modifiers() == Qt::KeyboardModifier::ControlModifier){ self()->horizontalScrollBar()->wheelEvent(event); return; } if (event->modifiers() == Qt::KeyboardModifier::ShiftModifier){ self()->verticalScrollBar()->wheelEvent(event); return; } } qreal scaleFactor = pow( 2.0, event->delta() / 700.0); scale( scaleFactor, scaleFactor ); m_scale *= scaleFactor; }But, it seems that's not how it should be done. Build results with
error: ‘virtual void QScrollBar::wheelEvent(QWheelEvent*)’ is protected within this contextSo, here are the questions:
1 - is it really a quick stuff to implement?
2 - is the point of modifications selected correctly?
3 - is the selected approach overall right?
Hi all!
return;
return;
Quote from arcachofo on June 7, 2024, 12:18 pmHi.
You can pan the circuit using the middle button.
Some trackpads in laptops have an actual middle button, if not it can be emulated I think.About your questions:
1 - Not sure, maybe you can use a similar approach to the middle button implementation.
2 - Yes, I think 2 finger events in trackpads are delivered to CircuitView::wheelEvent, but maybe not in all systems.
3 - As you can see QScrollBar::wheelEvent(QWheelEvent*) is protected. Maybe you can use QScrollBar::setValue(int)
Quote from FeeLynn on September 3, 2024, 11:13 amThere are classic 2-finger gestures for Pan and Zoom, so I was wondered why 2 finger move makes zoom, and closing/expanding fingers do nothing. Shifts, Controls, Third mouse button are not intuitive to me, I'm using mac trackpad. So let's fix it.
Some theory:
Pan Gestures (in Qt) are converted to Mouse Wheel messages which can have a y and also a x offset. This seems strange to me, as there is no common Mouse with a horizontal Wheel. Even more confusing, by MS definition Pan events are converted to WM_VSCROLL/WM_HSCROLL events.
with Qt 6 there is QInputEvent::deviceType() which returns ::Mouse or ::TouchPad, depending on what generated the event. I think we're out of luck with Qt 5 though.
The zoom gesture with two fingers are handled differently on Mac and Windows:
On windows a wheel event is sent with “(event->modifiers() & Qt::ControlModifier) == true”. On the mac not.
So, if(event->modifiers() & (Qt::ControlModifier | Qt::ShiftModifier)) in CircuitView::wheelEvent
we must do a Windows Zoom, else Mac Pan with QGraphicsView::wheelEvent(event);
Now implement Mac Zoom: we have to listen to a QEvent::NativeGesture - thats not called on Windows:bool CircuitView::viewportEvent ( QEvent * event ){
switch (event->type()){
case QEvent::NativeGesture:
auto nge = dynamic_cast<QNativeGestureEvent*>(event);
if (nge){
if(nge->gestureType() == Qt::ZoomNativeGesture){
qreal scaleFactor = pow( 2.0, nge->value());That's all, folks. Enjoy classic Pan/Zoom gestures on Mac. Full code is here: 44608e4
BTW: You still can use old-style zoom with Shift pressed.
Some theory:
if (nge){
Quote from arcachofo on September 3, 2024, 5:54 pmThanks, I will have a look as soon as possible.
In any case I don't want to zoom with Shift pressed.
Quote from arcachofo on September 3, 2024, 9:50 pmQuote from FeeLynn on September 3, 2024, 11:13 amThere are classic 2-finger gestures for Pan and Zoom, so I was wondered why 2 finger move makes zoom, and closing/expanding fingers do nothing. Shifts, Controls, Third mouse button are not intuitive to me, I'm using mac trackpad. So let's fix it.
Some theory:
if (nge){
Well.. let's analyze this issue:
This discussion was about scrolling, not zooming.
Zooming in a track-pad with two fingers is working.
So I don't see the reason for this code.Also if you copy-paste the code and most of your post from the internet, please add a link to the original post:
https://stackoverflow.com/questions/70037430/qt-how-to-implement-panning-zooming-in-qgraphicsscene-with-two-finger-gestures/70263559#70263559
Some theory:
if (nge){
Quote from FeeLynn on September 4, 2024, 1:34 amThis discussion was about scrolling, not zooming. - Exactly! This way we have scrolling AND zooming both work as intended. I tested it, works perfect.
Zooming in a track-pad with two fingers is working. - No. I can't tell this is "working". Let's call it "exists". 2-finger-move gesture must do Pan, not Zoom. I can't Pan with Third mouse button because of no mouse.
So I don't see the reason for this code. - You're the owner - You choose.
Also if you copy-paste the code... The Stack Overflow terms of service indicate that content, including code, can be copied for personal, non-commercial use only and is subject to the copyleft Creative Commons Attribution-Share Alike 4.0 International (CC BY-SA 4.0) license. At least in the US, the legal doctrine of Fair Use does not apply to embedding excerpts even of copyrighted works into source code.I saw there was no solution suggested in three months, so I posted one. Compiled and Tested. Am I wrong?
Quote from arcachofo on September 4, 2024, 9:52 amI saw there was no solution suggested in three months, so I posted one. Compiled and Tested. Am I wrong?
Maybe it works for you, I have no idea.
But this not a solution.Your code has nothing about scrolling, only about zoom, and has this effect:
- Does nothing in Windows laptop: zoom is already working and still no scroll.
- Breaks zoom in Linux laptop: zoom was working and still no scroll.
- Breaks zoom with mouse wheel in Windows, Linux and Mac (now Shift key is needed).I guess in your case scrolling was working and zoom was not working, but I have no idea because you didn't explain.
Quote from arcachofo on September 4, 2024, 11:27 amI managed to make scroll to work with your code at least in Windows by restoring track-pad configuration to default values.
I will do some more investigation in Linux, maybe something similar is happening.
Quote from arcachofo on September 5, 2024, 11:43 amI can't find a combination that don't break zooming with Mouse middle button and works for all systems.
But I added the option to scroll with Shift+Left button for trackpads that don't have middle button or are configured to don't use it.
