Quote from lastactionhero9000 on February 4, 2025, 1:03 pmHi. I trying to create schematic with 74XX89 and 74HC193 chips. Counter is working properly, but I can't write any number into RAM. Can you help me and point to my error? Thanks in advance.
Quote from arcachofo on February 6, 2025, 10:19 amHi.
7489 outputs are open collector, so you need pullup resistors or connect to led cathode.
Also note that WE pin is active low.
Quote from lastactionhero9000 on February 6, 2025, 1:55 pmHello. Thank you for the reply. I change the scheme according to your recomendation and now everything working as intended.
