Bad width of DIP resistors properties window
Quote from vranik on March 9, 2024, 4:01 amHi,
when the properties window of DIP resistor is displayed and Czech language is selected the the window looks good. Bad after checking pullup check box the window width is reduced and pullup voltage line looks ugly. When the check box is unchecked again the window width is extended back.
Tested trunk revision 2244
Quote from arcachofo on March 9, 2024, 3:47 pmYes, this one is weird:
When you activate Pullup the widget shrinks...
It doesn't make much sense.Let's see if I can find why.
