[AVR (& others MCUs ?)] buggy Clock Out
Quote from Coethium on August 27, 2024, 6:27 pmHello,
Some MCUs have an option to output the clock on a pin. (In the UI that's the "Clock Out" option). But in simulation, it doesn't work. Well i'm lying a little bit : it works but it slows down the simulation realy realy hard, barely unusable.
The clock out is toggled each (simulated) picosecond. We only need a toogle each 1/2 of the frequency of the mcu.
in ./src/microsim/mcuintosc.cpp, we can add a line :
31| void McuIntOsc::stamp() ...| 42| setPinMode( output ); --> 43| m_psInst = m_mcu->psInst()/2; 44| Simulator::self()->addEvent( m_psInst, this );
Consequences for Clock In Pin : i guess that can impact to have MCUs controlled by an external clock (the event must be checked often) ; but i saw that feature is currently disabled : when activated on UI, the CLKI pin is disabled (blued).
