atmega328 i2c slave
bjacquot@bjacquot
#1 · March 13, 2024, 2:59 pm
Quote from bjacquot on March 13, 2024, 2:59 pmHi,i try to use i2c slave mode using arduino lib Wire.h, but that don't work as expected.Very simple programm :#include <Wire.h> const int8_t i2cAddress = 8; void receiveEvent(int nbBytes) { PORTD=Wire.read(); } int main() { DDRD=0xFF; Wire.begin(i2cAddress); Wire.onReceive(receiveEvent); sei(); while(1) { _delay_us(100); //PORTD=TWDR; } }
TWDR register contains right datas but callback function is not executed.it seams TWSR register does not worked as expected. Il should take TW_SR_STOP 0xA0 value but only got TW_SR_DATA_ACK 0x80 and TW_SR_SLA_ACK 0x60
#include <Wire.h>
PORTD=Wire.read();
int main()
DDRD=0xFF;
sei();
while(1)
_delay_us(100);
//PORTD=TWDR;
#2 · March 13, 2024, 4:00 pm
Quote from arcachofo on March 13, 2024, 4:00 pmHi.
Thanks for reporting and for the solution.Indeed a Stop condition does not set the correct status value.
Solved at Rev 2255.
Solved at Rev 2255.
Click for thumbs down.0Click for thumbs up.1
bjacquot has reacted to this post.
bjacquot
#4 · March 21, 2024, 12:36 pm
Quote from bjacquot on March 21, 2024, 12:36 pmit don't work as expected.
You should send TWI_SRX_STOP_RESTART only when the i2c message is for you :if (m_addrMatch) setTwiState( TWI_SRX_STOP_RESTART );
