ATmega16 ADC simultion partly work on 0.1.7 SImulIDE and did`t work on 1.1.0 - SR0 ver.
Quote from NickNameNemo on April 11, 2024, 10:15 amHi
Could anybody help me with problem with SimulIDE ?
OS Name Ubuntu 20.04.6 LST
Precompiled SimulIDE 0.1.7
recently downloaded SImulIDE 1.1.0 -SR0
On old version my code partly work (display zeros on 7-segment display but not display ADC value
on new version display noting even I draw new circuit from scratch.
my code
#include <avr/io.h> #include <avr/interrupt.h> #include <stdint.h> #define DISPLAY PORTC #define DIGIT_0 PIND0 #define DIGIT_1 PIND1 #define DIGIT_2 PIND2 #define DIGIT_3 PIND3 #define SELECTOR PORTD #define TIMER_COMPARE_VALUE 249 #define DISPLAY_DELAY 3 volatile uint8_t numbers[] = {0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f, 0x40}; volatile uint16_t timer = 0; volatile uint8_t digit = 0; void initialize_timer(void) { TCCR0 |= (1 << CS01) | (1 << CS00) | (1 << WGM01); // prescale 64, CTC mode TCNT0 = 0x00; TIMSK |= (1 << OCIE0); // compare match interrupt enable OCR0 = TIMER_COMPARE_VALUE; // 1ms interrupt sei(); // enable global interrupts } void initalize_ports(void) { DDRC = 0xFF; PORTC = 0x00; DDRD |= (1<<PIND0) | (1<<PIND1) | (1<<PIND2) | (1<<PIND3); } void initalize_adc(void) { ADMUX |= (1<< REFS0); //AVCC with external capacitor at AREF pin ADMUX |= (1<<MUX0); ADCSRA |= (1<<ADEN); // ADC enable ADCSRA |= (1<< ADPS1) | (1<<ADPS2); // prescale 64 } uint16_t adc_read(void) { ADCSRA |= (1<< ADSC); // ADC start convertion while(ADCSRA & (1<<ADSC)); return ADC; } void delay(void) { timer++; if (timer % DISPLAY_DELAY == 0) { digit++; if(digit > 3) { digit = 0; } timer = 0; } } void display_digit(volatile uint8_t *port, uint16_t number) { if(digit == 0) { SELECTOR |= (1<<DIGIT_0); SELECTOR &=~ ((1<<DIGIT_1) | (1<<DIGIT_2) | (1<<DIGIT_3)); *port = numbers[number % 10]; } if(digit == 1) { SELECTOR |= (1<<DIGIT_1); SELECTOR &=~ ((1<<DIGIT_0) | (1<<DIGIT_2) | (1<<DIGIT_3)); *port = numbers[(number /10) % 10]; } if(digit == 2) { SELECTOR |= (1<<DIGIT_2); SELECTOR &=~ ((1<<DIGIT_1) | (1<<DIGIT_0) | (1<<DIGIT_3)); *port = numbers[(number /100) % 10]; } if(digit == 3) { SELECTOR |= (1<<DIGIT_3); SELECTOR &=~ ((1<<DIGIT_1) | (1<<DIGIT_2) | (1<<DIGIT_0)); *port = numbers[(number / 1000) % 10]; } } ISR(TIMER0_COMP_vect) { delay(); } int main(void) { initalize_ports(); initialize_timer(); initalize_adc(); while (1) { display_digit(&DISPLAY, adc_read()); } return 0; }thanks.
Hi
my code
#include <avr/io.h>
#include <stdint.h>
TCNT0 = 0x00;
DDRC = 0xFF;
PORTC = 0x00;
ADMUX |= (1<<MUX0);
return ADC;
void delay(void) {
timer++;
digit++;
if(digit > 3) {
digit = 0;
timer = 0;
if(digit == 0) {
if(digit == 1) {
if(digit == 2) {
if(digit == 3) {
delay();
int main(void)
initalize_ports();
initialize_timer();
initalize_adc();
while (1)
return 0;
thanks.
Quote from NickNameNemo on April 11, 2024, 5:31 pmHi,
Could you please explain?
Quote from NickNameNemo on April 12, 2024, 4:20 amDear arcachofo thank you for help.
Simulation starts working, but partly (only lowest digit shows value).
could you please explain why rst should be connected to +5 V?
Is there any information in Atmega datasheet?
Thank you!
Thank you!
Quote from arcachofo on April 12, 2024, 6:20 pmHi.
I see...
There is an error in some configuration files for atmega16.
You can try to add files attached to simulide data folder.
Merge data folder attached with SimulIDE_1.1.0-SR0/data
Then open simulide and try your circuit.
Because Reset pin internal pull-up resistor in AVRs is not simulated in simulide.
I see...
Quote from NickNameNemo on April 13, 2024, 8:35 amDear arcachofo
Thank you a lot!
Now simulation works!
Best regards!
Dear arcachofo
Thank you a lot!
Best regards!
