aarch64,as_jit.cpp bug.
Quote from doo on September 7, 2024, 9:30 am####### Compiler, tools and options
CC = aarch64-linux-gnu-gcc
CXX = aarch64-linux-gnu-g++
DEFINES = -DREVNO=\""0907"\" -DAPP_VERSION=\"1.2.0\" -DBUILDDATE=\""07-09-24"\" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CONCURRENT_LIB -DQT_SERIALPORT_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB
CFLAGS = -pipe -O2 -Wall -Wextra -D_REENTRANT -fPIC $(DEFINES)
CXXFLAGS = -pipe -Wno-unused-parameter -Wno-implicit-fallthrough -fno-strict-aliasing -Wno-cast-function-type -Wno-deprecated-copy -Wno-invalid-offsetof -fno-pic -Ofast -O2 -std=gnu++11 -Wall -Wextra -D_REENTRANT -fPIC $(DEFINES)error:
build/objects/as_jit.o: In function `std::_Function_handler<void (assembler::JumpType, bool), asCJITCompiler::CompileFunction(asIScriptFunction*, void (**)(asSVMRegisters*, unsigned long))::{lambda(assembler::JumpType, bool)#3}>::_M_invoke(std::_Any_data const&, assembler::JumpType&&, bool&&)': as_jit.cpp:(.text+0x3b0): undefined reference to `assembler::Register::operator=(void*)' as_jit.cpp:(.text+0x3cc): undefined reference to `assembler::Processor::jump(assembler::JumpType, unsigned char volatile*)' as_jit.cpp:(.text+0x3d8): undefined reference to `assembler::Processor::prep_short_jump(assembler::JumpType)' as_jit.cpp:(.text+0x3e8): undefined reference to `assembler::Register::operator=(void*)' as_jit.cpp:(.text+0x3f8): undefined reference to `assembler::Processor::jump(assembler::JumpType, unsigned char volatile*)' as_jit.cpp:(.text+0x410): undefined reference to `assembler::Processor::end_short_jump(void*)' build/objects/as_jit.o: In function `SystemCall::call_entry(asSSystemFunctionInterface*, asCScriptFunction*)': as_jit.cpp:(.text+0xc10): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode, unsigned int)' as_jit.cpp:(.text+0xc20): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' as_jit.cpp:(.text+0xc34): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode, unsigned int)' as_jit.cpp:(.text+0xc48): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode, unsigned int)' as_jit.cpp:(.text+0xc60): undefined reference to `assembler::Register::operator*() const' as_jit.cpp:(.text+0xc70): undefined reference to `assembler::MemAddress::operator+(int)' as_jit.cpp:(.text+0xcc4): undefined reference to `assembler::MemAddress::operator=(void*)' as_jit.cpp:(.text+0xcd0): undefined reference to `assembler::Register::operator*() const' as_jit.cpp:(.text+0xce0): undefined reference to `assembler::MemAddress::operator+(int)' as_jit.cpp:(.text+0xd1c): undefined reference to `assembler::MemAddress::operator=(assembler::Register)' as_jit.cpp:(.text+0xd30): undefined reference to `assembler::Register::operator*() const' as_jit.cpp:(.text+0xd44): undefined reference to `assembler::MemAddress::operator+(int)' as_jit.cpp:(.text+0xd7c): undefined reference to `assembler::Register::operator=(assembler::MemAddress)' as_jit.cpp:(.text+0xd88): undefined reference to `assembler::Register::operator+=(unsigned int)' as_jit.cpp:(.text+0xd94): undefined reference to `assembler::Register::operator*() const' as_jit.cpp:(.text+0xdd8): undefined reference to `assembler::MemAddress::operator=(void*)' as_jit.cpp:(.text+0xde4): undefined reference to `assembler::Register::operator*() const' as_jit.cpp:(.text+0xdf4): undefined reference to `assembler::MemAddress::operator+(int)' ....... as_jit.cpp:(.text+0x16990): undefined reference to `assembler::FloatingPointUnit::store_double(assembler::MemAddress, bool)' as_jit.cpp:(.text+0x169d0): undefined reference to `assembler::FloatingPointUnit::sub_double(assembler::MemAddress, bool)' as_jit.cpp:(.text+0x16a00): undefined reference to `assembler::FloatingPointUnit::div_double(assembler::MemAddress, bool)' as_jit.cpp:(.text+0x16a2c): undefined reference to `assembler::FloatingPointUnit::mult_double(assembler::MemAddress)' build/objects/virtual_asm_linux.o: In function `assembler::Processor::intArg64(unsigned char, unsigned char)': virtual_asm_linux.cpp:(.text+0x68): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' virtual_asm_linux.cpp:(.text+0x84): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' virtual_asm_linux.cpp:(.text+0xac): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' virtual_asm_linux.cpp:(.text+0xc8): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' virtual_asm_linux.cpp:(.text+0xe4): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' build/objects/virtual_asm_linux.o:virtual_asm_linux.cpp:(.text+0x158): more undefined references to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' follow build/objects/as_callfunc.o: In function `CallSystemFunction(int, asCContext*)': as_callfunc.cpp:(.text+0x2b8): undefined reference to `CallSystemFunctionNative(asCContext*, asCScriptFunction*, void*, unsigned int*, void*, unsigned long&, void*)' collect2: error: ld returned 1 exit status make: *** [Makefile:1795: executables/SimulIDE_1.2.0/simulide] Error 1
error:
Quote from arcachofo on September 7, 2024, 10:07 amHi.
Are your sources updated to the last commits?
https://github.com/Arcachofo/SimulIDE-dev
Quote from doo on September 7, 2024, 11:49 amyeah,DEFINES = -DREVNO=\""0907"\" -DAPP_VERSION=\"1.2.0\" -DBUILDDATE=\""07-09-24",
when i use arm,or arm-gcc on x86 ,the same bug.
Maybe my qt:
The QT installation is incomplete and the environment variables are incorrectly configured
Maybe my qt:
Quote from arcachofo on September 7, 2024, 12:03 pmOk, can you try with last commit?
But why are you using your own options instead of default options defined in SimulIDE.pri?
Quote from doo on September 7, 2024, 12:29 pmsorry,
it is not last commit ,0907
i didn't change the SimulIDE.pri.
there no my option,only default.
new@goo-desktop:~/Desktop/SimulIDE-dev-master/build_XX$ ./opt/qt5.15.15/bin/qmake bash: ./opt/qt5.15.15/bin/qmake: No such file or directory new@goo-desktop:~/Desktop/SimulIDE-dev-master/build_XX$ /opt/qt5.15.15/bin/qmakeInfo: creating stash file /home/new/Desktop/SimulIDE-dev-master/build_XX/.qmake.stash Project MESSAGE: ----------------------------------- Project MESSAGE: Project MESSAGE: SimulIDE_1.2.0 for Linux Project MESSAGE: Project MESSAGE: Date: "07-09-24" Project MESSAGE: Qt version: 5.15.15 Project MESSAGE: Project MESSAGE: Destination Folder: Project MESSAGE: /home/new/Desktop/SimulIDE-dev-master/build_XX/executables/SimulIDE_1.2.0 Project MESSAGE: ----------------------------------- new@goo-desktop:~/Desktop/SimulIDE-dev-master/build_XX$ make -j14 。。。 virtual_asm_linux.cpp:(.text+0xc8): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' virtual_asm_linux.cpp:(.text+0xe4): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' build/objects/virtual_asm_linux.o:virtual_asm_linux.cpp:(.text+0x158): more undefined references to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' follow build/objects/as_callfunc.o: In function `CallSystemFunction(int, asCContext*)': as_callfunc.cpp:(.text+0x2b8): undefined reference to `CallSystemFunctionNative(asCContext*, asCScriptFunction*, void*, unsigned int*, void*, unsigned long&, void*)' collect2: error: ld returned 1 exit status make: *** [Makefile:1794: executables/SimulIDE_1.2.0/simulide] Error 1
sorry,
Project MESSAGE:
Project MESSAGE:
Project MESSAGE:
Quote from arcachofo on September 7, 2024, 12:43 pmOk, then be sure that you get the source code from here and it is updated to the last commit (2 hours ago):
Quote from doo on September 7, 2024, 12:49 pmi will try it. thank you.
now ,as_jit worked,but:
virtual_asm_linux.cpp error.
/opt/qt5.15.15/lib/libQt5Network.so /opt/qt5.15.15/lib/libQt5Core.so -lpthread build/objects/virtual_asm_linux.o: In function `assembler::Processor::intArg64(unsigned char, unsigned char)': virtual_asm_linux.cpp:(.text+0x68): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' virtual_asm_linux.cpp:(.text+0x84): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' virtual_asm_linux.cpp:(.text+0xac): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' virtual_asm_linux.cpp:(.text+0xc8): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' virtual_asm_linux.cpp:(.text+0xe4): undefined reference to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' build/objects/virtual_asm_linux.o:virtual_asm_linux.cpp:(.text+0x158): more undefined references to `assembler::Register::Register(assembler::Processor&, assembler::RegCode)' follow build/objects/as_callfunc.o: In function `CallSystemFunction(int, asCContext*)': as_callfunc.cpp:(.text+0x2b8): undefined reference to `CallSystemFunctionNative(asCContext*, asCScriptFunction*, void*, unsigned int*, void*, unsigned long&, void*)' collect2: error: ld returned 1 exit status make: *** [Makefile:1794: executables/SimulIDE_1.2.0/simulide] Error 1
Quote from FeeLynn on September 7, 2024, 3:31 pmaarch64-linux-gnu-g++ : There is still no released virtual_asm_arm64.cpp for src/angel/JIT, but I know this work is in progress. Keep calm, I will post announce.
If you urgently need to compile SimulIDE for your platform - there was a dirty hack https://simulide.com/p/forum/topic/apple-silicon-m1-build-its-working/ - just change __APPLE__ to __UNIX__
You'll have no JIT compiling of AS, this will decrease performance of scripted elements a bit, but other things are working pretty good.
Quote from arcachofo on September 7, 2024, 3:41 pmi will try it. thank you.
Ok, thanks.
Try with last commit.
Ok, thanks.
Quote from doo on September 8, 2024, 3:31 amas_callfunc.o error, thanks.
/opt/qt5.15.15/lib/libQt5Core.so -lpthread build/objects/as_callfunc.o: In function `CallSystemFunction(int, asCContext*)': as_callfunc.cpp:(.text+0x2b8): undefined reference to `CallSystemFunctionNative(asCContext*, asCScriptFunction*, void*, unsigned int*, void*, unsigned long&, void*)' collect2: error: ld returned 1 exit status make: *** [Makefile:1794: executables/SimulIDE_1.2.0/simulide] Error 1
