# Makefile for building: executables/SimulIDE_1.2.0/simulide
# Generated by qmake (3.1) (Qt 5.15.15)
# Project:  SimulIDE_Build.pro
# Template: app
# Command: /opt/qt5.15.15/bin/qmake -o Makefile SimulIDE_Build.pro
MAKEFILE      = Makefile
EQ            = =
####### Compiler, tools and options
CC            = aarch64-linux-gnu-gcc
CXX           = aarch64-linux-gnu-g++
DEFINES       = -DREVNO=\""0907"\" -DAPP_VERSION=\"1.2.0\" -DBUILDDATE=\""07-09-24"\" -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_WIDGETS_LIB -DQT_MULTIMEDIA_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CONCURRENT_LIB -DQT_SERIALPORT_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB
CFLAGS        = -pipe -O2 -Wall -Wextra -D_REENTRANT -fPIC $(DEFINES)
CXXFLAGS      = -pipe -Wno-unused-parameter -Wno-implicit-fallthrough -fno-strict-aliasing -Wno-cast-function-type -Wno-deprecated-copy -Wno-invalid-offsetof -fno-pic -Ofast -O2 -std=gnu++11 -Wall -Wextra -D_REENTRANT -fPIC $(DEFINES)
INCPATH       = -I. -I../src -I../src/components -I../src/components/active -I../src/components/connectors -I../src/components/graphical -I../src/components/logic -I../src/components/meters -I../src/components/micro -I../src/components/other -I../src/components/other/truthtable -I../src/components/outputs -I../src/components/outputs/displays -I../src/components/outputs/leds -I../src/components/outputs/motors -I../src/components/passive -I../src/components/passive/reactive -I../src/components/passive/resistors -I../src/components/passive/resist_sensors -I../src/components/sources -I../src/components/subcircuits -I../src/components/switches -I../src/gui -I../src/gui/appdialogs -I../src/gui/circuitwidget -I../src/gui/componentlist -I../src/gui/dataplotwidget -I../src/gui/editorwidget -I../src/gui/editorwidget/debuggers -I../src/gui/editorwidget/dialogs -I../src/gui/filebrowser -I../src/gui/memory -I../src/gui/properties -I../src/gui/serial -I../src/simulator -I../src/simulator/elements -I../src/simulator/elements/active -I../src/simulator/elements/outputs -I../src/simulator/elements/passive -I../src/microsim -I../src/microsim/cores -I../src/microsim/cores/avr -I../src/microsim/cores/i51 -I../src/microsim/cores/pic -I../src/microsim/cores/mcs65 -I../src/microsim/cores/z80 -I../src/microsim/cores/scripted -I../src/microsim/cores/intmem -I../src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I../src/microsim/modules/usart -I../src/microsim/modules/twi -I../src/microsim/modules/tcp -I../src/microsim/modules/spi -I../src/microsim/modules/script -I../src/angel/include -I../src/angel/JIT -I../src/angel/src -Ibuild/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -Ibuild/moc -I. -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++
QMAKE         = /opt/qt5.15.15/bin/qmake
DEL_FILE      = rm -f
CHK_DIR_EXISTS= test -d
MKDIR         = mkdir -p
COPY          = cp -f
COPY_FILE     = cp -f
COPY_DIR      = cp -f -R
INSTALL_FILE  = install -m 644 -p
INSTALL_PROGRAM = install -m 755 -p
INSTALL_DIR   = cp -f -R
QINSTALL      = /opt/qt5.15.15/bin/qmake -install qinstall
QINSTALL_PROGRAM = /opt/qt5.15.15/bin/qmake -install qinstall -exe
DEL_FILE      = rm -f
SYMLINK       = ln -f -s
DEL_DIR       = rmdir
MOVE          = mv -f
TAR           = tar -cf
COMPRESS      = gzip -9f
DISTNAME      = simulide1.2.0
DISTDIR = /home/new/Desktop/SimulIDE-dev-master/build_XX/build/objects/simulide1.2.0
LINK          = aarch64-linux-gnu-g++
LFLAGS        = -no-pie -Wl,-O1 -Wl,-rpath,/opt/qt5.15.15/lib -Wl,-rpath-link,/opt/qt5.15.15/lib
LIBS          = $(SUBLIBS) /opt/qt5.15.15/lib/libQt5Svg.so /opt/qt5.15.15/lib/libQt5Widgets.so /opt/qt5.15.15/lib/libQt5Multimedia.so /opt/qt5.15.15/lib/libQt5Gui.so /opt/qt5.15.15/lib/libQt5Xml.so /opt/qt5.15.15/lib/libQt5Concurrent.so /opt/qt5.15.15/lib/libQt5SerialPort.so /opt/qt5.15.15/lib/libQt5Network.so /opt/qt5.15.15/lib/libQt5Core.so -lpthread
AR            = aarch64-linux-gnu-ar cqs
RANLIB        =
SED           = sed
STRIP         = aarch64-linux-gnu-strip
####### Output directory
OBJECTS_DIR   = build/objects/
####### Files
SOURCES       = ../src/main.cpp \
		../src/mainwindow.cpp \
		../src/utils.cpp \
		../src/components/comp2pin.cpp \
		../src/components/component.cpp \
		../src/components/iocomponent.cpp \
		../src/components/linker.cpp \
		../src/components/linkercomponent.cpp \
		../src/components/logiccomponent.cpp \
		../src/components/logicfamily.cpp \
		../src/components/node.cpp \
		../src/gui/custombutton.cpp \
		../src/gui/customdial.cpp \
		../src/gui/customslider.cpp \
		../src/gui/dialwidget.cpp \
		../src/gui/joystickwidget.cpp \
		../src/gui/outpaneltext.cpp \
		../src/gui/sourcewidget.cpp \
		../src/microsim/datautils.cpp \
		../src/microsim/e_iou.cpp \
		../src/microsim/e_mcu.cpp \
		../src/microsim/mcu.cpp \
		../src/microsim/mcuadc.cpp \
		../src/microsim/mcucomparator.cpp \
		../src/microsim/mcuconfigword.cpp \
		../src/microsim/mcucreator.cpp \
		../src/microsim/mcudac.cpp \
		../src/microsim/mcudataspace.cpp \
		../src/microsim/mcueeprom.cpp \
		../src/microsim/mcuicunit.cpp \
		../src/microsim/mcuinterrupts.cpp \
		../src/microsim/mcuintosc.cpp \
		../src/microsim/mcumodule.cpp \
		../src/microsim/mcuocm.cpp \
		../src/microsim/mcuocunit.cpp \
		../src/microsim/mcupin.cpp \
		../src/microsim/mcuport.cpp \
		../src/microsim/mcuprescaled.cpp \
		../src/microsim/mcusleep.cpp \
		../src/microsim/mcuspi.cpp \
		../src/microsim/mcutimer.cpp \
		../src/microsim/mcutwi.cpp \
		../src/microsim/mcuuart.cpp \
		../src/microsim/mcuvref.cpp \
		../src/microsim/mcuwdt.cpp \
		../src/simulator/circmatrix.cpp \
		../src/simulator/e-element.cpp \
		../src/simulator/e-node.cpp \
		../src/simulator/e-pin.cpp \
		../src/simulator/simulator.cpp \
		../src/angel/JIT/as_jit.cpp \
		../src/angel/JIT/virtual_asm_linux.cpp \
		../src/angel/JIT/virtual_asm_windows.cpp \
		../src/angel/JIT/virtual_asm_x64.cpp \
		../src/angel/src/as_atomic.cpp \
		../src/angel/src/as_builder.cpp \
		../src/angel/src/as_bytecode.cpp \
		../src/angel/src/as_callfunc.cpp \
		../src/angel/src/as_callfunc_arm64.cpp \
		../src/angel/src/as_callfunc_x64_gcc.cpp \
		../src/angel/src/as_callfunc_x64_mingw.cpp \
		../src/angel/src/as_callfunc_x86.cpp \
		../src/angel/src/as_compiler.cpp \
		../src/angel/src/as_configgroup.cpp \
		../src/angel/src/as_context.cpp \
		../src/angel/src/as_datatype.cpp \
		../src/angel/src/as_gc.cpp \
		../src/angel/src/as_generic.cpp \
		../src/angel/src/as_globalproperty.cpp \
		../src/angel/src/as_memory.cpp \
		../src/angel/src/as_module.cpp \
		../src/angel/src/as_objecttype.cpp \
		../src/angel/src/as_outputbuffer.cpp \
		../src/angel/src/as_parser.cpp \
		../src/angel/src/as_scriptcode.cpp \
		../src/angel/src/as_scriptengine.cpp \
		../src/angel/src/as_scriptfunction.cpp \
		../src/angel/src/as_scriptnode.cpp \
		../src/angel/src/as_scriptobject.cpp \
		../src/angel/src/as_string.cpp \
		../src/angel/src/as_string_util.cpp \
		../src/angel/src/as_thread.cpp \
		../src/angel/src/as_tokenizer.cpp \
		../src/angel/src/as_typeinfo.cpp \
		../src/angel/src/as_variablescope.cpp \
		../src/angel/src/scriptarray.cpp \
		../src/angel/src/scripthelper.cpp \
		../src/angel/src/scriptstdstring.cpp \
		../src/components/active/bjt.cpp \
		../src/components/active/comparator.cpp \
		../src/components/active/diac.cpp \
		../src/components/active/diode.cpp \
		../src/components/active/mosfet.cpp \
		../src/components/active/mux_analog.cpp \
		../src/components/active/op_amp.cpp \
		../src/components/active/scr.cpp \
		../src/components/active/triac.cpp \
		../src/components/active/volt_reg.cpp \
		../src/components/active/zener.cpp \
		../src/components/connectors/header.cpp \
		../src/components/connectors/socket.cpp \
		../src/components/connectors/tunnel.cpp \
		../src/components/graphical/ellipse.cpp \
		../src/components/graphical/image.cpp \
		../src/components/graphical/line.cpp \
		../src/components/graphical/rectangle.cpp \
		../src/components/graphical/shape.cpp \
		../src/components/graphical/textcomponent.cpp \
		../src/components/logic/adc.cpp \
		../src/components/logic/bcdbase.cpp \
		../src/components/logic/bcdto7s.cpp \
		../src/components/logic/bcdtodec.cpp \
		../src/components/logic/bincounter.cpp \
		../src/components/logic/buffer.cpp \
		../src/components/logic/bus.cpp \
		../src/components/logic/dac.cpp \
		../src/components/logic/dectobcd.cpp \
		../src/components/logic/demux.cpp \
		../src/components/logic/dynamic_memory.cpp \
		../src/components/logic/flipflopbase.cpp \
		../src/components/logic/flipflopd.cpp \
		../src/components/logic/flipflopjk.cpp \
		../src/components/logic/flipfloprs.cpp \
		../src/components/logic/flipflopt.cpp \
		../src/components/logic/fulladder.cpp \
		../src/components/logic/function.cpp \
		../src/components/logic/gate.cpp \
		../src/components/logic/gate_and.cpp \
		../src/components/logic/gate_or.cpp \
		../src/components/logic/gate_xor.cpp \
		../src/components/logic/i2cram.cpp \
		../src/components/logic/i2ctoparallel.cpp \
		../src/components/logic/latchd.cpp \
		../src/components/logic/lm555.cpp \
		../src/components/logic/magnitudecomp.cpp \
		../src/components/logic/memory.cpp \
		../src/components/logic/mux.cpp \
		../src/components/logic/sevensegment_bcd.cpp \
		../src/components/logic/shiftreg.cpp \
		../src/components/meters/ampmeter.cpp \
		../src/components/meters/freqmeter.cpp \
		../src/components/meters/lachannel.cpp \
		../src/components/meters/logicanalizer.cpp \
		../src/components/meters/meter.cpp \
		../src/components/meters/oscope.cpp \
		../src/components/meters/oscopechannel.cpp \
		../src/components/meters/probe.cpp \
		../src/components/meters/voltmeter.cpp \
		../src/components/micro/dht22.cpp \
		../src/components/micro/ds1307.cpp \
		../src/components/micro/ds1621.cpp \
		../src/components/micro/ds18b20.cpp \
		../src/components/micro/esp01.cpp \
		../src/components/micro/ky023.cpp \
		../src/components/micro/ky040.cpp \
		../src/components/micro/rtclock.cpp \
		../src/components/micro/serialport.cpp \
		../src/components/micro/serialterm.cpp \
		../src/components/micro/sr04.cpp \
		../src/components/micro/touchpad.cpp \
		../src/components/micro/touchpadwidget.cpp \
		../src/components/other/dial.cpp \
		../src/components/other/packagepin.cpp \
		../src/components/other/subpackage.cpp \
		../src/components/other/testunit.cpp \
		../src/components/outputs/audio_out.cpp \
		../src/components/outputs/lamp.cpp \
		../src/components/sources/battery.cpp \
		../src/components/sources/clock-base.cpp \
		../src/components/sources/clock.cpp \
		../src/components/sources/csource.cpp \
		../src/components/sources/currsource.cpp \
		../src/components/sources/fixedvolt.cpp \
		../src/components/sources/ground.cpp \
		../src/components/sources/rail.cpp \
		../src/components/sources/varsource.cpp \
		../src/components/sources/voltsource.cpp \
		../src/components/sources/wavegen.cpp \
		../src/components/subcircuits/board.cpp \
		../src/components/subcircuits/chip.cpp \
		../src/components/subcircuits/logicsubc.cpp \
		../src/components/subcircuits/module.cpp \
		../src/components/subcircuits/shield.cpp \
		../src/components/subcircuits/subcircuit.cpp \
		../src/components/switches/keypad.cpp \
		../src/components/switches/mech_contact.cpp \
		../src/components/switches/push.cpp \
		../src/components/switches/push_base.cpp \
		../src/components/switches/relay.cpp \
		../src/components/switches/switch.cpp \
		../src/components/switches/switch_base.cpp \
		../src/components/switches/switchdip.cpp \
		../src/gui/appdialogs/about.cpp \
		../src/gui/appdialogs/appdialog.cpp \
		../src/gui/appdialogs/infowidget.cpp \
		../src/gui/circuitwidget/circuit.cpp \
		../src/gui/circuitwidget/circuitview.cpp \
		../src/gui/circuitwidget/circuitwidget.cpp \
		../src/gui/circuitwidget/compbase.cpp \
		../src/gui/circuitwidget/connbase.cpp \
		../src/gui/circuitwidget/connector.cpp \
		../src/gui/circuitwidget/connectorline.cpp \
		../src/gui/circuitwidget/dialed.cpp \
		../src/gui/circuitwidget/iopin.cpp \
		../src/gui/circuitwidget/ioport.cpp \
		../src/gui/circuitwidget/label.cpp \
		../src/gui/circuitwidget/pin.cpp \
		../src/gui/circuitwidget/updatable.cpp \
		../src/gui/componentlist/componentlist.cpp \
		../src/gui/componentlist/itemlibrary.cpp \
		../src/gui/componentlist/managecomps.cpp \
		../src/gui/componentlist/treeitem.cpp \
		../src/gui/dataplotwidget/datachannel.cpp \
		../src/gui/dataplotwidget/datalawidget.cpp \
		../src/gui/dataplotwidget/datawidget.cpp \
		../src/gui/dataplotwidget/lawidget.cpp \
		../src/gui/dataplotwidget/oscwidget.cpp \
		../src/gui/dataplotwidget/plotbase.cpp \
		../src/gui/dataplotwidget/plotdisplay.cpp \
		../src/gui/dataplotwidget/plotspinbox.cpp \
		../src/gui/editorwidget/basedebugger.cpp \
		../src/gui/editorwidget/codeeditor.cpp \
		../src/gui/editorwidget/compiler.cpp \
		../src/gui/editorwidget/editorwidget.cpp \
		../src/gui/editorwidget/editorwindow.cpp \
		../src/gui/editorwidget/highlighter.cpp \
		../src/gui/editorwidget/scrollbar.cpp \
		../src/gui/filebrowser/filebrowser.cpp \
		../src/gui/filebrowser/filewidget.cpp \
		../src/gui/memory/headerwidget.cpp \
		../src/gui/memory/mcumonitor.cpp \
		../src/gui/memory/memdata.cpp \
		../src/gui/memory/memtable.cpp \
		../src/gui/memory/ramtable.cpp \
		../src/gui/memory/valuewidget.cpp \
		../src/gui/memory/watcher.cpp \
		../src/gui/properties/boolval.cpp \
		../src/gui/properties/colorval.cpp \
		../src/gui/properties/comproperty.cpp \
		../src/gui/properties/dspinbox.cpp \
		../src/gui/properties/enumval.cpp \
		../src/gui/properties/labelval.cpp \
		../src/gui/properties/numprop.cpp \
		../src/gui/properties/numval.cpp \
		../src/gui/properties/pathval.cpp \
		../src/gui/properties/propdialog.cpp \
		../src/gui/properties/proputils.cpp \
		../src/gui/properties/propval.cpp \
		../src/gui/properties/strval.cpp \
		../src/gui/properties/textval.cpp \
		../src/gui/serial/console.cpp \
		../src/gui/serial/serialmon.cpp \
		../src/microsim/cores/corebase.cpp \
		../src/microsim/cores/cpubase.cpp \
		../src/microsim/cores/mcucpu.cpp \
		../src/simulator/elements/e-clocked_device.cpp \
		../src/components/other/truthtable/truthtable.cpp \
		../src/components/outputs/displays/aip31068_i2c.cpp \
		../src/components/outputs/displays/hd44780.cpp \
		../src/components/outputs/displays/hd44780_base.cpp \
		../src/components/outputs/displays/ili9341.cpp \
		../src/components/outputs/displays/ks0108.cpp \
		../src/components/outputs/displays/pcd8544.cpp \
		../src/components/outputs/displays/ssd1306.cpp \
		../src/components/outputs/leds/led.cpp \
		../src/components/outputs/leds/ledbar.cpp \
		../src/components/outputs/leds/ledbase.cpp \
		../src/components/outputs/leds/ledmatrix.cpp \
		../src/components/outputs/leds/ledrgb.cpp \
		../src/components/outputs/leds/ledsmd.cpp \
		../src/components/outputs/leds/max72xx_matrix.cpp \
		../src/components/outputs/leds/sevensegment.cpp \
		../src/components/outputs/leds/ws2812.cpp \
		../src/components/outputs/motors/dcmotor.cpp \
		../src/components/outputs/motors/servo.cpp \
		../src/components/outputs/motors/stepper.cpp \
		../src/components/passive/reactive/capacitor.cpp \
		../src/components/passive/reactive/capacitorbase.cpp \
		../src/components/passive/reactive/elcapacitor.cpp \
		../src/components/passive/reactive/inductor.cpp \
		../src/components/passive/reactive/reactive.cpp \
		../src/components/passive/reactive/transformer.cpp \
		../src/components/passive/resist_sensors/ldr.cpp \
		../src/components/passive/resist_sensors/rtd.cpp \
		../src/components/passive/resist_sensors/strain.cpp \
		../src/components/passive/resist_sensors/thermistor.cpp \
		../src/components/passive/resist_sensors/thermistorbase.cpp \
		../src/components/passive/resistors/potentiometer.cpp \
		../src/components/passive/resistors/resistor.cpp \
		../src/components/passive/resistors/resistordip.cpp \
		../src/components/passive/resistors/varresbase.cpp \
		../src/components/passive/resistors/varresistor.cpp \
		../src/gui/editorwidget/debuggers/asdebugger.cpp \
		../src/gui/editorwidget/debuggers/avrgccdebugger.cpp \
		../src/gui/editorwidget/debuggers/cdebugger.cpp \
		../src/gui/editorwidget/debuggers/gcbdebugger.cpp \
		../src/gui/editorwidget/debuggers/gputilsdebug.cpp \
		../src/gui/editorwidget/debuggers/inodebugger.cpp \
		../src/gui/editorwidget/debuggers/sdccdebugger.cpp \
		../src/gui/editorwidget/debuggers/xc8debugger.cpp \
		../src/gui/editorwidget/dialogs/findreplace.cpp \
		../src/microsim/cores/avr/avradc.cpp \
		../src/microsim/cores/avr/avrcomparator.cpp \
		../src/microsim/cores/avr/avrcore.cpp \
		../src/microsim/cores/avr/avreeprom.cpp \
		../src/microsim/cores/avr/avricunit.cpp \
		../src/microsim/cores/avr/avrinterrupt.cpp \
		../src/microsim/cores/avr/avrintosc.cpp \
		../src/microsim/cores/avr/avrocm.cpp \
		../src/microsim/cores/avr/avrocunit.cpp \
		../src/microsim/cores/avr/avrpin.cpp \
		../src/microsim/cores/avr/avrport.cpp \
		../src/microsim/cores/avr/avrsleep.cpp \
		../src/microsim/cores/avr/avrspi.cpp \
		../src/microsim/cores/avr/avrtimer.cpp \
		../src/microsim/cores/avr/avrtwi.cpp \
		../src/microsim/cores/avr/avrusart.cpp \
		../src/microsim/cores/avr/avrusi.cpp \
		../src/microsim/cores/avr/avrwdt.cpp \
		../src/microsim/cores/i51/i51core.cpp \
		../src/microsim/cores/i51/i51pin.cpp \
		../src/microsim/cores/i51/i51port.cpp \
		../src/microsim/cores/i51/i51timer.cpp \
		../src/microsim/cores/i51/i51usart.cpp \
		../src/microsim/cores/intmem/intmemcore.cpp \
		../src/microsim/cores/mcs65/mcs65core.cpp \
		../src/microsim/cores/mcs65/mcs65interface.cpp \
		../src/microsim/cores/pic/pic14core.cpp \
		../src/microsim/cores/pic/pic14ecore.cpp \
		../src/microsim/cores/pic/pic14einterrupt.cpp \
		../src/microsim/cores/pic/picadc.cpp \
		../src/microsim/cores/pic/picccpunit.cpp \
		../src/microsim/cores/pic/piccomparator.cpp \
		../src/microsim/cores/pic/picconfigword.cpp \
		../src/microsim/cores/pic/picdac.cpp \
		../src/microsim/cores/pic/piceeprom.cpp \
		../src/microsim/cores/pic/picicunit.cpp \
		../src/microsim/cores/pic/picinterrupt.cpp \
		../src/microsim/cores/pic/picintosc.cpp \
		../src/microsim/cores/pic/picmrcore.cpp \
		../src/microsim/cores/pic/picmssp.cpp \
		../src/microsim/cores/pic/picocunit.cpp \
		../src/microsim/cores/pic/picpin.cpp \
		../src/microsim/cores/pic/picport.cpp \
		../src/microsim/cores/pic/picsleep.cpp \
		../src/microsim/cores/pic/picspi.cpp \
		../src/microsim/cores/pic/pictimer.cpp \
		../src/microsim/cores/pic/pictwi.cpp \
		../src/microsim/cores/pic/picusart.cpp \
		../src/microsim/cores/pic/picvref.cpp \
		../src/microsim/cores/pic/picwdt.cpp \
		../src/microsim/cores/scripted/display.cpp \
		../src/microsim/cores/scripted/scriptcpu.cpp \
		../src/microsim/cores/scripted/scriptdisplay.cpp \
		../src/microsim/cores/scripted/scriptperif.cpp \
		../src/microsim/cores/scripted/scriptport.cpp \
		../src/microsim/cores/scripted/scriptspi.cpp \
		../src/microsim/cores/scripted/scripttcp.cpp \
		../src/microsim/cores/scripted/scripttwi.cpp \
		../src/microsim/cores/scripted/scriptusart.cpp \
		../src/microsim/cores/z80/ula_zx48k.cpp \
		../src/microsim/cores/z80/z80core.cpp \
		../src/microsim/modules/script/scriptbase.cpp \
		../src/microsim/modules/script/scriptmodule.cpp \
		../src/microsim/modules/spi/spimodule.cpp \
		../src/microsim/modules/tcp/tcpmodule.cpp \
		../src/microsim/modules/twi/twimodule.cpp \
		../src/microsim/modules/usart/usartmodule.cpp \
		../src/microsim/modules/usart/usartrx.cpp \
		../src/microsim/modules/usart/usarttx.cpp \
		../src/simulator/elements/active/e-bjt.cpp \
		../src/simulator/elements/active/e-diode.cpp \
		../src/simulator/elements/active/e-mosfet.cpp \
		../src/simulator/elements/outputs/e-led.cpp \
		../src/simulator/elements/passive/e-coil.cpp \
		../src/simulator/elements/passive/e-reactive.cpp \
		../src/simulator/elements/passive/e-resistor.cpp qrc_application.cpp \
		build/moc/moc_custombutton.cpp \
		build/moc/moc_customdial.cpp \
		build/moc/moc_customslider.cpp \
		build/moc/moc_about.cpp \
		build/moc/moc_appdialog.cpp \
		build/moc/moc_infowidget.cpp \
		build/moc/moc_datalawidget.cpp \
		build/moc/moc_datawidget.cpp \
		build/moc/moc_lawidget.cpp \
		build/moc/moc_oscwidget.cpp \
		build/moc/moc_highlighter.cpp \
		build/moc/moc_filewidget.cpp \
		build/moc/moc_headerwidget.cpp \
		build/moc/moc_mcumonitor.cpp \
		build/moc/moc_memtable.cpp \
		build/moc/moc_ramtable.cpp \
		build/moc/moc_valuewidget.cpp \
		build/moc/moc_watcher.cpp \
		build/moc/moc_boolval.cpp \
		build/moc/moc_colorval.cpp \
		build/moc/moc_enumval.cpp \
		build/moc/moc_labelval.cpp \
		build/moc/moc_numval.cpp \
		build/moc/moc_pathval.cpp \
		build/moc/moc_propdialog.cpp \
		build/moc/moc_strval.cpp \
		build/moc/moc_textval.cpp \
		build/moc/moc_serialmon.cpp \
		build/moc/moc_truthtable.cpp \
		build/moc/moc_findreplace.cpp
OBJECTS       = build/objects/main.o \
		build/objects/mainwindow.o \
		build/objects/utils.o \
		build/objects/comp2pin.o \
		build/objects/component.o \
		build/objects/iocomponent.o \
		build/objects/linker.o \
		build/objects/linkercomponent.o \
		build/objects/logiccomponent.o \
		build/objects/logicfamily.o \
		build/objects/node.o \
		build/objects/custombutton.o \
		build/objects/customdial.o \
		build/objects/customslider.o \
		build/objects/dialwidget.o \
		build/objects/joystickwidget.o \
		build/objects/outpaneltext.o \
		build/objects/sourcewidget.o \
		build/objects/datautils.o \
		build/objects/e_iou.o \
		build/objects/e_mcu.o \
		build/objects/mcu.o \
		build/objects/mcuadc.o \
		build/objects/mcucomparator.o \
		build/objects/mcuconfigword.o \
		build/objects/mcucreator.o \
		build/objects/mcudac.o \
		build/objects/mcudataspace.o \
		build/objects/mcueeprom.o \
		build/objects/mcuicunit.o \
		build/objects/mcuinterrupts.o \
		build/objects/mcuintosc.o \
		build/objects/mcumodule.o \
		build/objects/mcuocm.o \
		build/objects/mcuocunit.o \
		build/objects/mcupin.o \
		build/objects/mcuport.o \
		build/objects/mcuprescaled.o \
		build/objects/mcusleep.o \
		build/objects/mcuspi.o \
		build/objects/mcutimer.o \
		build/objects/mcutwi.o \
		build/objects/mcuuart.o \
		build/objects/mcuvref.o \
		build/objects/mcuwdt.o \
		build/objects/circmatrix.o \
		build/objects/e-element.o \
		build/objects/e-node.o \
		build/objects/e-pin.o \
		build/objects/simulator.o \
		build/objects/as_jit.o \
		build/objects/virtual_asm_linux.o \
		build/objects/virtual_asm_windows.o \
		build/objects/virtual_asm_x64.o \
		build/objects/as_atomic.o \
		build/objects/as_builder.o \
		build/objects/as_bytecode.o \
		build/objects/as_callfunc.o \
		build/objects/as_callfunc_arm64.o \
		build/objects/as_callfunc_x64_gcc.o \
		build/objects/as_callfunc_x64_mingw.o \
		build/objects/as_callfunc_x86.o \
		build/objects/as_compiler.o \
		build/objects/as_configgroup.o \
		build/objects/as_context.o \
		build/objects/as_datatype.o \
		build/objects/as_gc.o \
		build/objects/as_generic.o \
		build/objects/as_globalproperty.o \
		build/objects/as_memory.o \
		build/objects/as_module.o \
		build/objects/as_objecttype.o \
		build/objects/as_outputbuffer.o \
		build/objects/as_parser.o \
		build/objects/as_scriptcode.o \
		build/objects/as_scriptengine.o \
		build/objects/as_scriptfunction.o \
		build/objects/as_scriptnode.o \
		build/objects/as_scriptobject.o \
		build/objects/as_string.o \
		build/objects/as_string_util.o \
		build/objects/as_thread.o \
		build/objects/as_tokenizer.o \
		build/objects/as_typeinfo.o \
		build/objects/as_variablescope.o \
		build/objects/scriptarray.o \
		build/objects/scripthelper.o \
		build/objects/scriptstdstring.o \
		build/objects/bjt.o \
		build/objects/comparator.o \
		build/objects/diac.o \
		build/objects/diode.o \
		build/objects/mosfet.o \
		build/objects/mux_analog.o \
		build/objects/op_amp.o \
		build/objects/scr.o \
		build/objects/triac.o \
		build/objects/volt_reg.o \
		build/objects/zener.o \
		build/objects/header.o \
		build/objects/socket.o \
		build/objects/tunnel.o \
		build/objects/ellipse.o \
		build/objects/image.o \
		build/objects/line.o \
		build/objects/rectangle.o \
		build/objects/shape.o \
		build/objects/textcomponent.o \
		build/objects/adc.o \
		build/objects/bcdbase.o \
		build/objects/bcdto7s.o \
		build/objects/bcdtodec.o \
		build/objects/bincounter.o \
		build/objects/buffer.o \
		build/objects/bus.o \
		build/objects/dac.o \
		build/objects/dectobcd.o \
		build/objects/demux.o \
		build/objects/dynamic_memory.o \
		build/objects/flipflopbase.o \
		build/objects/flipflopd.o \
		build/objects/flipflopjk.o \
		build/objects/flipfloprs.o \
		build/objects/flipflopt.o \
		build/objects/fulladder.o \
		build/objects/function.o \
		build/objects/gate.o \
		build/objects/gate_and.o \
		build/objects/gate_or.o \
		build/objects/gate_xor.o \
		build/objects/i2cram.o \
		build/objects/i2ctoparallel.o \
		build/objects/latchd.o \
		build/objects/lm555.o \
		build/objects/magnitudecomp.o \
		build/objects/memory.o \
		build/objects/mux.o \
		build/objects/sevensegment_bcd.o \
		build/objects/shiftreg.o \
		build/objects/ampmeter.o \
		build/objects/freqmeter.o \
		build/objects/lachannel.o \
		build/objects/logicanalizer.o \
		build/objects/meter.o \
		build/objects/oscope.o \
		build/objects/oscopechannel.o \
		build/objects/probe.o \
		build/objects/voltmeter.o \
		build/objects/dht22.o \
		build/objects/ds1307.o \
		build/objects/ds1621.o \
		build/objects/ds18b20.o \
		build/objects/esp01.o \
		build/objects/ky023.o \
		build/objects/ky040.o \
		build/objects/rtclock.o \
		build/objects/serialport.o \
		build/objects/serialterm.o \
		build/objects/sr04.o \
		build/objects/touchpad.o \
		build/objects/touchpadwidget.o \
		build/objects/dial.o \
		build/objects/packagepin.o \
		build/objects/subpackage.o \
		build/objects/testunit.o \
		build/objects/audio_out.o \
		build/objects/lamp.o \
		build/objects/battery.o \
		build/objects/clock-base.o \
		build/objects/clock.o \
		build/objects/csource.o \
		build/objects/currsource.o \
		build/objects/fixedvolt.o \
		build/objects/ground.o \
		build/objects/rail.o \
		build/objects/varsource.o \
		build/objects/voltsource.o \
		build/objects/wavegen.o \
		build/objects/board.o \
		build/objects/chip.o \
		build/objects/logicsubc.o \
		build/objects/module.o \
		build/objects/shield.o \
		build/objects/subcircuit.o \
		build/objects/keypad.o \
		build/objects/mech_contact.o \
		build/objects/push.o \
		build/objects/push_base.o \
		build/objects/relay.o \
		build/objects/switch.o \
		build/objects/switch_base.o \
		build/objects/switchdip.o \
		build/objects/about.o \
		build/objects/appdialog.o \
		build/objects/infowidget.o \
		build/objects/circuit.o \
		build/objects/circuitview.o \
		build/objects/circuitwidget.o \
		build/objects/compbase.o \
		build/objects/connbase.o \
		build/objects/connector.o \
		build/objects/connectorline.o \
		build/objects/dialed.o \
		build/objects/iopin.o \
		build/objects/ioport.o \
		build/objects/label.o \
		build/objects/pin.o \
		build/objects/updatable.o \
		build/objects/componentlist.o \
		build/objects/itemlibrary.o \
		build/objects/managecomps.o \
		build/objects/treeitem.o \
		build/objects/datachannel.o \
		build/objects/datalawidget.o \
		build/objects/datawidget.o \
		build/objects/lawidget.o \
		build/objects/oscwidget.o \
		build/objects/plotbase.o \
		build/objects/plotdisplay.o \
		build/objects/plotspinbox.o \
		build/objects/basedebugger.o \
		build/objects/codeeditor.o \
		build/objects/compiler.o \
		build/objects/editorwidget.o \
		build/objects/editorwindow.o \
		build/objects/highlighter.o \
		build/objects/scrollbar.o \
		build/objects/filebrowser.o \
		build/objects/filewidget.o \
		build/objects/headerwidget.o \
		build/objects/mcumonitor.o \
		build/objects/memdata.o \
		build/objects/memtable.o \
		build/objects/ramtable.o \
		build/objects/valuewidget.o \
		build/objects/watcher.o \
		build/objects/boolval.o \
		build/objects/colorval.o \
		build/objects/comproperty.o \
		build/objects/dspinbox.o \
		build/objects/enumval.o \
		build/objects/labelval.o \
		build/objects/numprop.o \
		build/objects/numval.o \
		build/objects/pathval.o \
		build/objects/propdialog.o \
		build/objects/proputils.o \
		build/objects/propval.o \
		build/objects/strval.o \
		build/objects/textval.o \
		build/objects/console.o \
		build/objects/serialmon.o \
		build/objects/corebase.o \
		build/objects/cpubase.o \
		build/objects/mcucpu.o \
		build/objects/e-clocked_device.o \
		build/objects/truthtable.o \
		build/objects/aip31068_i2c.o \
		build/objects/hd44780.o \
		build/objects/hd44780_base.o \
		build/objects/ili9341.o \
		build/objects/ks0108.o \
		build/objects/pcd8544.o \
		build/objects/ssd1306.o \
		build/objects/led.o \
		build/objects/ledbar.o \
		build/objects/ledbase.o \
		build/objects/ledmatrix.o \
		build/objects/ledrgb.o \
		build/objects/ledsmd.o \
		build/objects/max72xx_matrix.o \
		build/objects/sevensegment.o \
		build/objects/ws2812.o \
		build/objects/dcmotor.o \
		build/objects/servo.o \
		build/objects/stepper.o \
		build/objects/capacitor.o \
		build/objects/capacitorbase.o \
		build/objects/elcapacitor.o \
		build/objects/inductor.o \
		build/objects/reactive.o \
		build/objects/transformer.o \
		build/objects/ldr.o \
		build/objects/rtd.o \
		build/objects/strain.o \
		build/objects/thermistor.o \
		build/objects/thermistorbase.o \
		build/objects/potentiometer.o \
		build/objects/resistor.o \
		build/objects/resistordip.o \
		build/objects/varresbase.o \
		build/objects/varresistor.o \
		build/objects/asdebugger.o \
		build/objects/avrgccdebugger.o \
		build/objects/cdebugger.o \
		build/objects/gcbdebugger.o \
		build/objects/gputilsdebug.o \
		build/objects/inodebugger.o \
		build/objects/sdccdebugger.o \
		build/objects/xc8debugger.o \
		build/objects/findreplace.o \
		build/objects/avradc.o \
		build/objects/avrcomparator.o \
		build/objects/avrcore.o \
		build/objects/avreeprom.o \
		build/objects/avricunit.o \
		build/objects/avrinterrupt.o \
		build/objects/avrintosc.o \
		build/objects/avrocm.o \
		build/objects/avrocunit.o \
		build/objects/avrpin.o \
		build/objects/avrport.o \
		build/objects/avrsleep.o \
		build/objects/avrspi.o \
		build/objects/avrtimer.o \
		build/objects/avrtwi.o \
		build/objects/avrusart.o \
		build/objects/avrusi.o \
		build/objects/avrwdt.o \
		build/objects/i51core.o \
		build/objects/i51pin.o \
		build/objects/i51port.o \
		build/objects/i51timer.o \
		build/objects/i51usart.o \
		build/objects/intmemcore.o \
		build/objects/mcs65core.o \
		build/objects/mcs65interface.o \
		build/objects/pic14core.o \
		build/objects/pic14ecore.o \
		build/objects/pic14einterrupt.o \
		build/objects/picadc.o \
		build/objects/picccpunit.o \
		build/objects/piccomparator.o \
		build/objects/picconfigword.o \
		build/objects/picdac.o \
		build/objects/piceeprom.o \
		build/objects/picicunit.o \
		build/objects/picinterrupt.o \
		build/objects/picintosc.o \
		build/objects/picmrcore.o \
		build/objects/picmssp.o \
		build/objects/picocunit.o \
		build/objects/picpin.o \
		build/objects/picport.o \
		build/objects/picsleep.o \
		build/objects/picspi.o \
		build/objects/pictimer.o \
		build/objects/pictwi.o \
		build/objects/picusart.o \
		build/objects/picvref.o \
		build/objects/picwdt.o \
		build/objects/display.o \
		build/objects/scriptcpu.o \
		build/objects/scriptdisplay.o \
		build/objects/scriptperif.o \
		build/objects/scriptport.o \
		build/objects/scriptspi.o \
		build/objects/scripttcp.o \
		build/objects/scripttwi.o \
		build/objects/scriptusart.o \
		build/objects/ula_zx48k.o \
		build/objects/z80core.o \
		build/objects/scriptbase.o \
		build/objects/scriptmodule.o \
		build/objects/spimodule.o \
		build/objects/tcpmodule.o \
		build/objects/twimodule.o \
		build/objects/usartmodule.o \
		build/objects/usartrx.o \
		build/objects/usarttx.o \
		build/objects/e-bjt.o \
		build/objects/e-diode.o \
		build/objects/e-mosfet.o \
		build/objects/e-led.o \
		build/objects/e-coil.o \
		build/objects/e-reactive.o \
		build/objects/e-resistor.o \
		build/objects/qrc_application.o \
		build/objects/moc_custombutton.o \
		build/objects/moc_customdial.o \
		build/objects/moc_customslider.o \
		build/objects/moc_about.o \
		build/objects/moc_appdialog.o \
		build/objects/moc_infowidget.o \
		build/objects/moc_datalawidget.o \
		build/objects/moc_datawidget.o \
		build/objects/moc_lawidget.o \
		build/objects/moc_oscwidget.o \
		build/objects/moc_highlighter.o \
		build/objects/moc_filewidget.o \
		build/objects/moc_headerwidget.o \
		build/objects/moc_mcumonitor.o \
		build/objects/moc_memtable.o \
		build/objects/moc_ramtable.o \
		build/objects/moc_valuewidget.o \
		build/objects/moc_watcher.o \
		build/objects/moc_boolval.o \
		build/objects/moc_colorval.o \
		build/objects/moc_enumval.o \
		build/objects/moc_labelval.o \
		build/objects/moc_numval.o \
		build/objects/moc_pathval.o \
		build/objects/moc_propdialog.o \
		build/objects/moc_strval.o \
		build/objects/moc_textval.o \
		build/objects/moc_serialmon.o \
		build/objects/moc_truthtable.o \
		build/objects/moc_findreplace.o
DIST          = /opt/qt5.15.15/mkspecs/features/spec_pre.prf \
		/opt/qt5.15.15/mkspecs/common/unix.conf \
		/opt/qt5.15.15/mkspecs/common/linux.conf \
		/opt/qt5.15.15/mkspecs/common/sanitize.conf \
		/opt/qt5.15.15/mkspecs/common/gcc-base.conf \
		/opt/qt5.15.15/mkspecs/common/gcc-base-unix.conf \
		/opt/qt5.15.15/mkspecs/common/g++-base.conf \
		/opt/qt5.15.15/mkspecs/common/g++-unix.conf \
		/opt/qt5.15.15/mkspecs/qconfig.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_ext_freetype.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_ext_libjpeg.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_ext_libpng.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_accessibility_support_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_bluetooth.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_bluetooth_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_bodymovin_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_bootstrap_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_charts.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_charts_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_concurrent.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_concurrent_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_core.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_core_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_dbus.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_dbus_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_devicediscovery_support_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_edid_support_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_eventdispatcher_support_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_fb_support_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_fontdatabase_support_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_gamepad.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_gamepad_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_gui.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_gui_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_help.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_help_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_input_support_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_location.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_location_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_multimedia.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_multimedia_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_multimediawidgets.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_multimediawidgets_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_network.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_network_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_networkauth.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_networkauth_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_nfc.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_nfc_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_packetprotocol_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_positioning.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_positioning_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_positioningquick.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_positioningquick_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_printsupport.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_printsupport_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_purchasing.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_purchasing_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qml.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qml_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qmldebug_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qmldevtools_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qmlmodels.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qmlmodels_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qmltest.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qmltest_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qmlworkerscript.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qmlworkerscript_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_qtmultimediaquicktools_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_quick.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_quick_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_quickcontrols2.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_quickcontrols2_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_quickshapes_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_quicktemplates2.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_quicktemplates2_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_quickwidgets.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_quickwidgets_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_remoteobjects.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_remoteobjects_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_repparser.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_repparser_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_script.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_script_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_scripttools.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_scripttools_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_scxml.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_scxml_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_sensors.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_sensors_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_serialbus.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_serialbus_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_serialport.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_serialport_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_service_support_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_sql.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_sql_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_svg.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_svg_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_testlib.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_testlib_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_texttospeech.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_texttospeech_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_theme_support_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_uiplugin.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_uitools.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_uitools_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_virtualkeyboard.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_virtualkeyboard_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_webchannel.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_webchannel_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_websockets.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_websockets_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_webview.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_webview_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_widgets.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_widgets_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_xml.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_xml_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_xmlpatterns.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_xmlpatterns_private.pri \
		/opt/qt5.15.15/mkspecs/modules/qt_lib_zlib_private.pri \
		/opt/qt5.15.15/mkspecs/features/qt_functions.prf \
		/opt/qt5.15.15/mkspecs/features/qt_config.prf \
		/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++/qmake.conf \
		/opt/qt5.15.15/mkspecs/features/spec_post.prf \
		/opt/qt5.15.15/mkspecs/features/exclusive_builds.prf \
		/opt/qt5.15.15/mkspecs/features/toolchain.prf \
		/opt/qt5.15.15/mkspecs/features/default_pre.prf \
		../SimulIDE.pri \
		/opt/qt5.15.15/mkspecs/features/resolve_config.prf \
		/opt/qt5.15.15/mkspecs/features/default_post.prf \
		/opt/qt5.15.15/mkspecs/features/warn_on.prf \
		/opt/qt5.15.15/mkspecs/features/qt.prf \
		/opt/qt5.15.15/mkspecs/features/resources_functions.prf \
		/opt/qt5.15.15/mkspecs/features/resources.prf \
		/opt/qt5.15.15/mkspecs/features/moc.prf \
		/opt/qt5.15.15/mkspecs/features/uic.prf \
		/opt/qt5.15.15/mkspecs/features/unix/thread.prf \
		/opt/qt5.15.15/mkspecs/features/qmake_use.prf \
		/opt/qt5.15.15/mkspecs/features/file_copies.prf \
		/opt/qt5.15.15/mkspecs/features/testcase_targets.prf \
		/opt/qt5.15.15/mkspecs/features/exceptions.prf \
		/opt/qt5.15.15/mkspecs/features/yacc.prf \
		/opt/qt5.15.15/mkspecs/features/lex.prf \
		SimulIDE_Build.pro ../src/mainwindow.h \
		../src/utils.h \
		../src/components/comp2pin.h \
		../src/components/component.h \
		../src/components/iocomponent.h \
		../src/components/linker.h \
		../src/components/linkercomponent.h \
		../src/components/logiccomponent.h \
		../src/components/logicfamily.h \
		../src/components/node.h \
		../src/gui/custombutton.h \
		../src/gui/customdial.h \
		../src/gui/customslider.h \
		../src/gui/dialwidget.h \
		../src/gui/joystickwidget.h \
		../src/gui/outpaneltext.h \
		../src/gui/sourcewidget.h \
		../src/microsim/datautils.h \
		../src/microsim/e_iou.h \
		../src/microsim/e_mcu.h \
		../src/microsim/mcu.h \
		../src/microsim/mcuadc.h \
		../src/microsim/mcucomparator.h \
		../src/microsim/mcuconfigword.h \
		../src/microsim/mcucreator.h \
		../src/microsim/mcudac.h \
		../src/microsim/mcudataspace.h \
		../src/microsim/mcueeprom.h \
		../src/microsim/mcuicunit.h \
		../src/microsim/mcuinterrupts.h \
		../src/microsim/mcuintosc.h \
		../src/microsim/mcumodule.h \
		../src/microsim/mcuocm.h \
		../src/microsim/mcuocunit.h \
		../src/microsim/mcupin.h \
		../src/microsim/mcuport.h \
		../src/microsim/mcuprescaled.h \
		../src/microsim/mcusignal.h \
		../src/microsim/mcusleep.h \
		../src/microsim/mcuspi.h \
		../src/microsim/mcutimer.h \
		../src/microsim/mcutwi.h \
		../src/microsim/mcutypes.h \
		../src/microsim/mcuuart.h \
		../src/microsim/mcuvref.h \
		../src/microsim/mcuwdt.h \
		../src/microsim/regwatcher.h \
		../src/simulator/circmatrix.h \
		../src/simulator/e-element.h \
		../src/simulator/e-node.h \
		../src/simulator/e-pin.h \
		../src/simulator/simulator.h \
		../src/angel/include/angelscript.h \
		../src/angel/JIT/as_jit.h \
		../src/angel/JIT/virtual_asm.h \
		../src/angel/src/as_array.h \
		../src/angel/src/as_atomic.h \
		../src/angel/src/as_builder.h \
		../src/angel/src/as_bytecode.h \
		../src/angel/src/as_callfunc.h \
		../src/angel/src/as_compiler.h \
		../src/angel/src/as_config.h \
		../src/angel/src/as_configgroup.h \
		../src/angel/src/as_context.h \
		../src/angel/src/as_criticalsection.h \
		../src/angel/src/as_datatype.h \
		../src/angel/src/as_debug.h \
		../src/angel/src/as_gc.h \
		../src/angel/src/as_generic.h \
		../src/angel/src/as_map.h \
		../src/angel/src/as_memory.h \
		../src/angel/src/as_module.h \
		../src/angel/src/as_namespace.h \
		../src/angel/src/as_objecttype.h \
		../src/angel/src/as_outputbuffer.h \
		../src/angel/src/as_parser.h \
		../src/angel/src/as_property.h \
		../src/angel/src/as_scriptcode.h \
		../src/angel/src/as_scriptengine.h \
		../src/angel/src/as_scriptfunction.h \
		../src/angel/src/as_scriptnode.h \
		../src/angel/src/as_scriptobject.h \
		../src/angel/src/as_string.h \
		../src/angel/src/as_string_util.h \
		../src/angel/src/as_symboltable.h \
		../src/angel/src/as_texts.h \
		../src/angel/src/as_thread.h \
		../src/angel/src/as_tokendef.h \
		../src/angel/src/as_tokenizer.h \
		../src/angel/src/as_typeinfo.h \
		../src/angel/src/as_variablescope.h \
		../src/angel/src/scriptarray.h \
		../src/angel/src/scripthelper.h \
		../src/angel/src/scriptstdstring.h \
		../src/components/active/bjt.h \
		../src/components/active/comparator.h \
		../src/components/active/diac.h \
		../src/components/active/diode.h \
		../src/components/active/mosfet.h \
		../src/components/active/mux_analog.h \
		../src/components/active/op_amp.h \
		../src/components/active/scr.h \
		../src/components/active/triac.h \
		../src/components/active/volt_reg.h \
		../src/components/active/zener.h \
		../src/components/connectors/header.h \
		../src/components/connectors/socket.h \
		../src/components/connectors/tunnel.h \
		../src/components/graphical/ellipse.h \
		../src/components/graphical/image.h \
		../src/components/graphical/line.h \
		../src/components/graphical/rectangle.h \
		../src/components/graphical/shape.h \
		../src/components/graphical/textcomponent.h \
		../src/components/logic/adc.h \
		../src/components/logic/bcdbase.h \
		../src/components/logic/bcdto7s.h \
		../src/components/logic/bcdtodec.h \
		../src/components/logic/bincounter.h \
		../src/components/logic/buffer.h \
		../src/components/logic/bus.h \
		../src/components/logic/dac.h \
		../src/components/logic/dectobcd.h \
		../src/components/logic/demux.h \
		../src/components/logic/dynamic_memory.h \
		../src/components/logic/flipflopbase.h \
		../src/components/logic/flipflopd.h \
		../src/components/logic/flipflopjk.h \
		../src/components/logic/flipfloprs.h \
		../src/components/logic/flipflopt.h \
		../src/components/logic/fulladder.h \
		../src/components/logic/function.h \
		../src/components/logic/gate.h \
		../src/components/logic/gate_and.h \
		../src/components/logic/gate_or.h \
		../src/components/logic/gate_xor.h \
		../src/components/logic/i2cram.h \
		../src/components/logic/i2ctoparallel.h \
		../src/components/logic/latchd.h \
		../src/components/logic/lm555.h \
		../src/components/logic/magnitudecomp.h \
		../src/components/logic/memory.h \
		../src/components/logic/mux.h \
		../src/components/logic/sevensegment_bcd.h \
		../src/components/logic/shiftreg.h \
		../src/components/meters/ampmeter.h \
		../src/components/meters/freqmeter.h \
		../src/components/meters/lachannel.h \
		../src/components/meters/logicanalizer.h \
		../src/components/meters/meter.h \
		../src/components/meters/oscope.h \
		../src/components/meters/oscopechannel.h \
		../src/components/meters/probe.h \
		../src/components/meters/voltmeter.h \
		../src/components/micro/dht22.h \
		../src/components/micro/ds1307.h \
		../src/components/micro/ds1621.h \
		../src/components/micro/ds18b20.h \
		../src/components/micro/esp01.h \
		../src/components/micro/ky023.h \
		../src/components/micro/ky040.h \
		../src/components/micro/rtclock.h \
		../src/components/micro/serialport.h \
		../src/components/micro/serialterm.h \
		../src/components/micro/sr04.h \
		../src/components/micro/touchpad.h \
		../src/components/micro/touchpadwidget.h \
		../src/components/other/dial.h \
		../src/components/other/packagepin.h \
		../src/components/other/subpackage.h \
		../src/components/other/testunit.h \
		../src/components/outputs/audio_out.h \
		../src/components/outputs/lamp.h \
		../src/components/sources/battery.h \
		../src/components/sources/clock-base.h \
		../src/components/sources/clock.h \
		../src/components/sources/csource.h \
		../src/components/sources/currsource.h \
		../src/components/sources/fixedvolt.h \
		../src/components/sources/ground.h \
		../src/components/sources/rail.h \
		../src/components/sources/varsource.h \
		../src/components/sources/voltsource.h \
		../src/components/sources/wavegen.h \
		../src/components/subcircuits/board.h \
		../src/components/subcircuits/chip.h \
		../src/components/subcircuits/logicsubc.h \
		../src/components/subcircuits/module.h \
		../src/components/subcircuits/shield.h \
		../src/components/subcircuits/subcircuit.h \
		../src/components/switches/keypad.h \
		../src/components/switches/mech_contact.h \
		../src/components/switches/push.h \
		../src/components/switches/push_base.h \
		../src/components/switches/relay.h \
		../src/components/switches/switch.h \
		../src/components/switches/switch_base.h \
		../src/components/switches/switchdip.h \
		../src/gui/appdialogs/about.h \
		../src/gui/appdialogs/appdialog.h \
		../src/gui/appdialogs/infowidget.h \
		../src/gui/circuitwidget/circuit.h \
		../src/gui/circuitwidget/circuitview.h \
		../src/gui/circuitwidget/circuitwidget.h \
		../src/gui/circuitwidget/compbase.h \
		../src/gui/circuitwidget/connbase.h \
		../src/gui/circuitwidget/connector.h \
		../src/gui/circuitwidget/connectorline.h \
		../src/gui/circuitwidget/dialed.h \
		../src/gui/circuitwidget/iopin.h \
		../src/gui/circuitwidget/ioport.h \
		../src/gui/circuitwidget/label.h \
		../src/gui/circuitwidget/pin.h \
		../src/gui/circuitwidget/updatable.h \
		../src/gui/componentlist/componentlist.h \
		../src/gui/componentlist/itemlibrary.h \
		../src/gui/componentlist/managecomps.h \
		../src/gui/componentlist/treeitem.h \
		../src/gui/dataplotwidget/datachannel.h \
		../src/gui/dataplotwidget/datalawidget.h \
		../src/gui/dataplotwidget/datawidget.h \
		../src/gui/dataplotwidget/lawidget.h \
		../src/gui/dataplotwidget/oscwidget.h \
		../src/gui/dataplotwidget/plotbase.h \
		../src/gui/dataplotwidget/plotdisplay.h \
		../src/gui/dataplotwidget/plotspinbox.h \
		../src/gui/editorwidget/basedebugger.h \
		../src/gui/editorwidget/codeeditor.h \
		../src/gui/editorwidget/compiler.h \
		../src/gui/editorwidget/editorwidget.h \
		../src/gui/editorwidget/editorwindow.h \
		../src/gui/editorwidget/highlighter.h \
		../src/gui/editorwidget/scrollbar.h \
		../src/gui/filebrowser/filebrowser.h \
		../src/gui/filebrowser/filewidget.h \
		../src/gui/memory/headerwidget.h \
		../src/gui/memory/mcumonitor.h \
		../src/gui/memory/memdata.h \
		../src/gui/memory/memtable.h \
		../src/gui/memory/ramtable.h \
		../src/gui/memory/valuewidget.h \
		../src/gui/memory/watcher.h \
		../src/gui/properties/boolprop.h \
		../src/gui/properties/boolval.h \
		../src/gui/properties/colorval.h \
		../src/gui/properties/comproperty.h \
		../src/gui/properties/doubleprop.h \
		../src/gui/properties/dspinbox.h \
		../src/gui/properties/enumval.h \
		../src/gui/properties/intprop.h \
		../src/gui/properties/labelval.h \
		../src/gui/properties/numprop.h \
		../src/gui/properties/numval.h \
		../src/gui/properties/pathval.h \
		../src/gui/properties/pointprop.h \
		../src/gui/properties/propdialog.h \
		../src/gui/properties/proputils.h \
		../src/gui/properties/propval.h \
		../src/gui/properties/scriptprop.h \
		../src/gui/properties/stringprop.h \
		../src/gui/properties/strval.h \
		../src/gui/properties/textval.h \
		../src/gui/serial/console.h \
		../src/gui/serial/serialmon.h \
		../src/microsim/cores/corebase.h \
		../src/microsim/cores/cpubase.h \
		../src/microsim/cores/mcucpu.h \
		../src/simulator/elements/e-clocked_device.h \
		../src/components/other/truthtable/truthtable.h \
		../src/components/outputs/displays/aip31068_i2c.h \
		../src/components/outputs/displays/hd44780.h \
		../src/components/outputs/displays/hd44780_base.h \
		../src/components/outputs/displays/ili9341.h \
		../src/components/outputs/displays/ks0108.h \
		../src/components/outputs/displays/pcd8544.h \
		../src/components/outputs/displays/ssd1306.h \
		../src/components/outputs/leds/led.h \
		../src/components/outputs/leds/ledbar.h \
		../src/components/outputs/leds/ledbase.h \
		../src/components/outputs/leds/ledmatrix.h \
		../src/components/outputs/leds/ledrgb.h \
		../src/components/outputs/leds/ledsmd.h \
		../src/components/outputs/leds/max72xx_matrix.h \
		../src/components/outputs/leds/sevensegment.h \
		../src/components/outputs/leds/ws2812.h \
		../src/components/outputs/motors/dcmotor.h \
		../src/components/outputs/motors/servo.h \
		../src/components/outputs/motors/stepper.h \
		../src/components/passive/reactive/capacitor.h \
		../src/components/passive/reactive/capacitorbase.h \
		../src/components/passive/reactive/elcapacitor.h \
		../src/components/passive/reactive/inductor.h \
		../src/components/passive/reactive/reactive.h \
		../src/components/passive/reactive/transformer.h \
		../src/components/passive/resist_sensors/ldr.h \
		../src/components/passive/resist_sensors/rtd.h \
		../src/components/passive/resist_sensors/strain.h \
		../src/components/passive/resist_sensors/thermistor.h \
		../src/components/passive/resist_sensors/thermistorbase.h \
		../src/components/passive/resistors/potentiometer.h \
		../src/components/passive/resistors/resistor.h \
		../src/components/passive/resistors/resistordip.h \
		../src/components/passive/resistors/varresbase.h \
		../src/components/passive/resistors/varresistor.h \
		../src/gui/editorwidget/debuggers/asdebugger.h \
		../src/gui/editorwidget/debuggers/avrgccdebugger.h \
		../src/gui/editorwidget/debuggers/cdebugger.h \
		../src/gui/editorwidget/debuggers/gcbdebugger.h \
		../src/gui/editorwidget/debuggers/gputilsdebug.h \
		../src/gui/editorwidget/debuggers/inodebugger.h \
		../src/gui/editorwidget/debuggers/sdccdebugger.h \
		../src/gui/editorwidget/debuggers/xc8debugger.h \
		../src/gui/editorwidget/dialogs/findreplace.h \
		../src/microsim/cores/avr/avr_defines.h \
		../src/microsim/cores/avr/avradc.h \
		../src/microsim/cores/avr/avrcomparator.h \
		../src/microsim/cores/avr/avrcore.h \
		../src/microsim/cores/avr/avreeprom.h \
		../src/microsim/cores/avr/avricunit.h \
		../src/microsim/cores/avr/avrinterrupt.h \
		../src/microsim/cores/avr/avrintosc.h \
		../src/microsim/cores/avr/avrocm.h \
		../src/microsim/cores/avr/avrocunit.h \
		../src/microsim/cores/avr/avrpin.h \
		../src/microsim/cores/avr/avrport.h \
		../src/microsim/cores/avr/avrsleep.h \
		../src/microsim/cores/avr/avrspi.h \
		../src/microsim/cores/avr/avrtimer.h \
		../src/microsim/cores/avr/avrtwi.h \
		../src/microsim/cores/avr/avrtwicodes.h \
		../src/microsim/cores/avr/avrusart.h \
		../src/microsim/cores/avr/avrusi.h \
		../src/microsim/cores/avr/avrwdt.h \
		../src/microsim/cores/i51/i51core.h \
		../src/microsim/cores/i51/i51pin.h \
		../src/microsim/cores/i51/i51port.h \
		../src/microsim/cores/i51/i51timer.h \
		../src/microsim/cores/i51/i51usart.h \
		../src/microsim/cores/intmem/intmemcore.h \
		../src/microsim/cores/mcs65/mcs65core.h \
		../src/microsim/cores/mcs65/mcs65interface.h \
		../src/microsim/cores/pic/pic14core.h \
		../src/microsim/cores/pic/pic14ecore.h \
		../src/microsim/cores/pic/pic14einterrupt.h \
		../src/microsim/cores/pic/picadc.h \
		../src/microsim/cores/pic/picccpunit.h \
		../src/microsim/cores/pic/piccomparator.h \
		../src/microsim/cores/pic/picconfigword.h \
		../src/microsim/cores/pic/picdac.h \
		../src/microsim/cores/pic/piceeprom.h \
		../src/microsim/cores/pic/picicunit.h \
		../src/microsim/cores/pic/picinterrupt.h \
		../src/microsim/cores/pic/picintosc.h \
		../src/microsim/cores/pic/picmrcore.h \
		../src/microsim/cores/pic/picmssp.h \
		../src/microsim/cores/pic/picocunit.h \
		../src/microsim/cores/pic/picpin.h \
		../src/microsim/cores/pic/picport.h \
		../src/microsim/cores/pic/picsleep.h \
		../src/microsim/cores/pic/picspi.h \
		../src/microsim/cores/pic/pictimer.h \
		../src/microsim/cores/pic/pictwi.h \
		../src/microsim/cores/pic/picusart.h \
		../src/microsim/cores/pic/picvref.h \
		../src/microsim/cores/pic/picwdt.h \
		../src/microsim/cores/scripted/display.h \
		../src/microsim/cores/scripted/scriptcpu.h \
		../src/microsim/cores/scripted/scriptdisplay.h \
		../src/microsim/cores/scripted/scriptperif.h \
		../src/microsim/cores/scripted/scriptport.h \
		../src/microsim/cores/scripted/scriptspi.h \
		../src/microsim/cores/scripted/scripttcp.h \
		../src/microsim/cores/scripted/scripttwi.h \
		../src/microsim/cores/scripted/scriptusart.h \
		../src/microsim/cores/z80/ula_zx48k.h \
		../src/microsim/cores/z80/z80core.h \
		../src/microsim/cores/z80/z80cycles.h \
		../src/microsim/cores/z80/z80regs.h \
		../src/microsim/modules/script/scriptbase.h \
		../src/microsim/modules/script/scriptmodule.h \
		../src/microsim/modules/spi/spimodule.h \
		../src/microsim/modules/tcp/tcpmodule.h \
		../src/microsim/modules/twi/twimodule.h \
		../src/microsim/modules/usart/usartmodule.h \
		../src/microsim/modules/usart/usartrx.h \
		../src/microsim/modules/usart/usarttx.h \
		../src/simulator/elements/active/e-bjt.h \
		../src/simulator/elements/active/e-diode.h \
		../src/simulator/elements/active/e-mosfet.h \
		../src/simulator/elements/outputs/e-led.h \
		../src/simulator/elements/passive/e-coil.h \
		../src/simulator/elements/passive/e-reactive.h \
		../src/simulator/elements/passive/e-resistor.h ../src/main.cpp \
		../src/utils.cpp \
QMAKE_TARGET  = simulide
DESTDIR       = executables/SimulIDE_1.2.0/
TARGET        = executables/SimulIDE_1.2.0/simulide
first: all
####### Build rules
executables/SimulIDE_1.2.0/simulide: runLrelease ui_about.h ui_appdialog.h ui_infowidget.h ui_managecomps.h ui_datalawidget.h ui_datawidget.h ui_lawidget.h ui_oscwidget.h ui_headerwidget.h ui_mcumonitor.h ui_memtable.h ui_ramtable.h ui_valuewidget.h ui_watcher.h ui_boolval.h ui_colorval.h ui_enumval.h ui_labelval.h ui_numval.h ui_pathval.h ui_propdialog.h ui_strval.h ui_textval.h ui_serialmon.h ui_truthtable.h ui_findreplace.h $(OBJECTS)  copy2dest
	@test -d executables/SimulIDE_1.2.0/ || mkdir -p executables/SimulIDE_1.2.0/
	$(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(OBJCOMP) $(LIBS)
Makefile: SimulIDE_Build.pro /opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++/qmake.conf /opt/qt5.15.15/mkspecs/features/spec_pre.prf \
		../SimulIDE.pri \
		SimulIDE_Build.pro \
		../src/application.qrc
	$(QMAKE) -o Makefile SimulIDE_Build.pro
/opt/qt5.15.15/mkspecs/features/spec_pre.prf:
/opt/qt5.15.15/mkspecs/common/unix.conf:
/opt/qt5.15.15/mkspecs/common/linux.conf:
/opt/qt5.15.15/mkspecs/common/sanitize.conf:
/opt/qt5.15.15/mkspecs/common/gcc-base.conf:
/opt/qt5.15.15/mkspecs/common/gcc-base-unix.conf:
/opt/qt5.15.15/mkspecs/common/g++-base.conf:
/opt/qt5.15.15/mkspecs/common/g++-unix.conf:
/opt/qt5.15.15/mkspecs/qconfig.pri:
/opt/qt5.15.15/mkspecs/modules/qt_ext_freetype.pri:
/opt/qt5.15.15/mkspecs/modules/qt_ext_libjpeg.pri:
/opt/qt5.15.15/mkspecs/modules/qt_ext_libpng.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_accessibility_support_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_bluetooth.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_bluetooth_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_bodymovin_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_bootstrap_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_charts.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_charts_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_concurrent.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_concurrent_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_core.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_core_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_dbus.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_dbus_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_devicediscovery_support_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_edid_support_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_eventdispatcher_support_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_fb_support_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_fontdatabase_support_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_gamepad.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_gamepad_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_gui.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_gui_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_help.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_help_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_input_support_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_location.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_location_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_multimedia.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_multimedia_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_multimediawidgets.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_multimediawidgets_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_network.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_network_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_networkauth.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_networkauth_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_nfc.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_nfc_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_packetprotocol_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_positioning.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_positioning_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_positioningquick.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_positioningquick_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_printsupport.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_printsupport_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_purchasing.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_purchasing_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qml.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qml_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qmldebug_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qmldevtools_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qmlmodels.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qmlmodels_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qmltest.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qmltest_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qmlworkerscript.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qmlworkerscript_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_qtmultimediaquicktools_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_quick.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_quick_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_quickcontrols2.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_quickcontrols2_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_quickshapes_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_quicktemplates2.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_quicktemplates2_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_quickwidgets.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_quickwidgets_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_remoteobjects.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_remoteobjects_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_repparser.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_repparser_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_script.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_script_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_scripttools.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_scripttools_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_scxml.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_scxml_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_sensors.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_sensors_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_serialbus.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_serialbus_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_serialport.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_serialport_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_service_support_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_sql.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_sql_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_svg.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_svg_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_testlib.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_testlib_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_texttospeech.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_texttospeech_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_theme_support_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_uiplugin.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_uitools.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_uitools_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_virtualkeyboard.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_virtualkeyboard_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_webchannel.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_webchannel_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_websockets.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_websockets_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_webview.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_webview_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_widgets.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_widgets_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_xml.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_xml_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_xmlpatterns.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_xmlpatterns_private.pri:
/opt/qt5.15.15/mkspecs/modules/qt_lib_zlib_private.pri:
/opt/qt5.15.15/mkspecs/features/qt_functions.prf:
/opt/qt5.15.15/mkspecs/features/qt_config.prf:
/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++/qmake.conf:
/opt/qt5.15.15/mkspecs/features/spec_post.prf:
/opt/qt5.15.15/mkspecs/features/exclusive_builds.prf:
/opt/qt5.15.15/mkspecs/features/toolchain.prf:
/opt/qt5.15.15/mkspecs/features/default_pre.prf:
../SimulIDE.pri:
/opt/qt5.15.15/mkspecs/features/resolve_config.prf:
/opt/qt5.15.15/mkspecs/features/default_post.prf:
/opt/qt5.15.15/mkspecs/features/warn_on.prf:
/opt/qt5.15.15/mkspecs/features/qt.prf:
/opt/qt5.15.15/mkspecs/features/resources_functions.prf:
/opt/qt5.15.15/mkspecs/features/resources.prf:
/opt/qt5.15.15/mkspecs/features/moc.prf:
/opt/qt5.15.15/mkspecs/features/uic.prf:
/opt/qt5.15.15/mkspecs/features/unix/thread.prf:
/opt/qt5.15.15/mkspecs/features/qmake_use.prf:
/opt/qt5.15.15/mkspecs/features/file_copies.prf:
/opt/qt5.15.15/mkspecs/features/testcase_targets.prf:
/opt/qt5.15.15/mkspecs/features/exceptions.prf:
/opt/qt5.15.15/mkspecs/features/yacc.prf:
/opt/qt5.15.15/mkspecs/features/lex.prf:
SimulIDE_Build.pro:
../src/application.qrc:
qmake: FORCE
	@$(QMAKE) -o Makefile SimulIDE_Build.pro
qmake_all: FORCE
all: Makefile executables/SimulIDE_1.2.0/simulide
dist: distdir FORCE
	(cd `dirname $(DISTDIR)` && $(TAR) $(DISTNAME).tar $(DISTNAME) && $(COMPRESS) $(DISTNAME).tar) && $(MOVE) `dirname $(DISTDIR)`/$(DISTNAME).tar.gz . && $(DEL_FILE) -r $(DISTDIR)
distdir: FORCE
	@test -d $(DISTDIR) || mkdir -p $(DISTDIR)
	$(COPY_FILE) --parents $(DIST) $(DISTDIR)/
	$(COPY_FILE) --parents ../src/application.qrc $(DISTDIR)/
	$(COPY_FILE) --parents /opt/qt5.15.15/mkspecs/features/data/dummy.cpp $(DISTDIR)/
	$(COPY_FILE) --parents ../src/mainwindow.h ../src/utils.h ../src/components/comp2pin.h ../src/components/component.h ../src/components/iocomponent.h ../src/components/linker.h ../src/components/linkercomponent.h ../src/components/logiccomponent.h ../src/components/logicfamily.h ../src/components/node.h ../src/gui/custombutton.h ../src/gui/customdial.h ../src/gui/customslider.h ../src/gui/dialwidget.h ../src/gui/joystickwidget.h ../src/gui/outpaneltext.h ../src/gui/sourcewidget.h ../src/microsim/datautils.h ../src/microsim/e_iou.h ../src/microsim/e_mcu.h ../src/microsim/mcu.h ../src/microsim/mcuadc.h ../src/microsim/mcucomparator.h ../src/microsim/mcuconfigword.h ../src/microsim/mcucreator.h ../src/microsim/mcudac.h ../src/microsim/mcudataspace.h ../src/microsim/mcueeprom.h ../src/microsim/mcuicunit.h ../src/microsim/mcuinterrupts.h ../src/microsim/mcuintosc.h ../src/microsim/mcumodule.h ../src/microsim/mcuocm.h ../src/microsim/mcuocunit.h ../src/microsim/mcupin.h ../src/microsim/mcuport.h ../src/microsim/mcuprescaled.h ../src/microsim/mcusignal.h ../src/microsim/mcusleep.h ../src/microsim/mcuspi.h ../src/microsim/mcutimer.h ../src/microsim/mcutwi.h ../src/microsim/mcutypes.h ../src/microsim/mcuuart.h ../src/microsim/mcuvref.h ../src/microsim/mcuwdt.h ../src/microsim/regwatcher.h ../src/simulator/circmatrix.h ../src/simulator/e-element.h ../src/simulator/e-node.h ../src/simulator/e-pin.h ../src/simulator/simulator.h ../src/angel/include/angelscript.h ../src/angel/JIT/as_jit.h ../src/angel/JIT/virtual_asm.h ../src/angel/src/as_array.h ../src/angel/src/as_atomic.h ../src/angel/src/as_builder.h ../src/angel/src/as_bytecode.h ../src/angel/src/as_callfunc.h ../src/angel/src/as_compiler.h ../src/angel/src/as_config.h ../src/angel/src/as_configgroup.h ../src/angel/src/as_context.h ../src/angel/src/as_criticalsection.h ../src/angel/src/as_datatype.h ../src/angel/src/as_debug.h ../src/angel/src/as_gc.h ../src/angel/src/as_generic.h ../src/angel/src/as_map.h ../src/angel/src/as_memory.h ../src/angel/src/as_module.h ../src/angel/src/as_namespace.h ../src/angel/src/as_objecttype.h ../src/angel/src/as_outputbuffer.h ../src/angel/src/as_parser.h ../src/angel/src/as_property.h ../src/angel/src/as_scriptcode.h ../src/angel/src/as_scriptengine.h ../src/angel/src/as_scriptfunction.h ../src/angel/src/as_scriptnode.h ../src/angel/src/as_scriptobject.h ../src/angel/src/as_string.h ../src/angel/src/as_string_util.h ../src/angel/src/as_symboltable.h ../src/angel/src/as_texts.h ../src/angel/src/as_thread.h ../src/angel/src/as_tokendef.h ../src/angel/src/as_tokenizer.h ../src/angel/src/as_typeinfo.h ../src/angel/src/as_variablescope.h ../src/angel/src/scriptarray.h ../src/angel/src/scripthelper.h ../src/angel/src/scriptstdstring.h ../src/components/active/bjt.h ../src/components/active/comparator.h ../src/components/active/diac.h ../src/components/active/diode.h ../src/components/active/mosfet.h ../src/components/active/mux_analog.h ../src/components/active/op_amp.h ../src/components/active/scr.h ../src/components/active/triac.h ../src/components/active/volt_reg.h ../src/components/active/zener.h ../src/components/connectors/header.h ../src/components/connectors/socket.h ../src/components/connectors/tunnel.h ../src/components/graphical/ellipse.h ../src/components/graphical/image.h ../src/components/graphical/line.h ../src/components/graphical/rectangle.h ../src/components/graphical/shape.h ../src/components/graphical/textcomponent.h ../src/components/logic/adc.h ../src/components/logic/bcdbase.h ../src/components/logic/bcdto7s.h ../src/components/logic/bcdtodec.h ../src/components/logic/bincounter.h ../src/components/logic/buffer.h ../src/components/logic/bus.h ../src/components/logic/dac.h ../src/components/logic/dectobcd.h ../src/components/logic/demux.h ../src/components/logic/dynamic_memory.h ../src/components/logic/flipflopbase.h ../src/components/logic/flipflopd.h ../src/components/logic/flipflopjk.h ../src/components/logic/flipfloprs.h ../src/components/logic/flipflopt.h ../src/components/logic/fulladder.h ../src/components/logic/function.h ../src/components/logic/gate.h ../src/components/logic/gate_and.h ../src/components/logic/gate_or.h ../src/components/logic/gate_xor.h ../src/components/logic/i2cram.h ../src/components/logic/i2ctoparallel.h ../src/components/logic/latchd.h ../src/components/logic/lm555.h ../src/components/logic/magnitudecomp.h ../src/components/logic/memory.h ../src/components/logic/mux.h ../src/components/logic/sevensegment_bcd.h ../src/components/logic/shiftreg.h ../src/components/meters/ampmeter.h ../src/components/meters/freqmeter.h ../src/components/meters/lachannel.h ../src/components/meters/logicanalizer.h ../src/components/meters/meter.h ../src/components/meters/oscope.h ../src/components/meters/oscopechannel.h ../src/components/meters/probe.h ../src/components/meters/voltmeter.h ../src/components/micro/dht22.h ../src/components/micro/ds1307.h ../src/components/micro/ds1621.h ../src/components/micro/ds18b20.h ../src/components/micro/esp01.h ../src/components/micro/ky023.h ../src/components/micro/ky040.h ../src/components/micro/rtclock.h ../src/components/micro/serialport.h ../src/components/micro/serialterm.h ../src/components/micro/sr04.h ../src/components/micro/touchpad.h ../src/components/micro/touchpadwidget.h ../src/components/other/dial.h ../src/components/other/packagepin.h ../src/components/other/subpackage.h ../src/components/other/testunit.h ../src/components/outputs/audio_out.h ../src/components/outputs/lamp.h ../src/components/sources/battery.h ../src/components/sources/clock-base.h ../src/components/sources/clock.h ../src/components/sources/csource.h ../src/components/sources/currsource.h ../src/components/sources/fixedvolt.h ../src/components/sources/ground.h ../src/components/sources/rail.h ../src/components/sources/varsource.h ../src/components/sources/voltsource.h ../src/components/sources/wavegen.h ../src/components/subcircuits/board.h ../src/components/subcircuits/chip.h ../src/components/subcircuits/logicsubc.h ../src/components/subcircuits/module.h ../src/components/subcircuits/shield.h ../src/components/subcircuits/subcircuit.h ../src/components/switches/keypad.h ../src/components/switches/mech_contact.h ../src/components/switches/push.h ../src/components/switches/push_base.h ../src/components/switches/relay.h ../src/components/switches/switch.h ../src/components/switches/switch_base.h ../src/components/switches/switchdip.h ../src/gui/appdialogs/about.h ../src/gui/appdialogs/appdialog.h ../src/gui/appdialogs/infowidget.h ../src/gui/circuitwidget/circuit.h ../src/gui/circuitwidget/circuitview.h ../src/gui/circuitwidget/circuitwidget.h ../src/gui/circuitwidget/compbase.h ../src/gui/circuitwidget/connbase.h ../src/gui/circuitwidget/connector.h ../src/gui/circuitwidget/connectorline.h ../src/gui/circuitwidget/dialed.h ../src/gui/circuitwidget/iopin.h ../src/gui/circuitwidget/ioport.h ../src/gui/circuitwidget/label.h ../src/gui/circuitwidget/pin.h ../src/gui/circuitwidget/updatable.h ../src/gui/componentlist/componentlist.h ../src/gui/componentlist/itemlibrary.h ../src/gui/componentlist/managecomps.h ../src/gui/componentlist/treeitem.h ../src/gui/dataplotwidget/datachannel.h ../src/gui/dataplotwidget/datalawidget.h ../src/gui/dataplotwidget/datawidget.h ../src/gui/dataplotwidget/lawidget.h ../src/gui/dataplotwidget/oscwidget.h ../src/gui/dataplotwidget/plotbase.h ../src/gui/dataplotwidget/plotdisplay.h ../src/gui/dataplotwidget/plotspinbox.h ../src/gui/editorwidget/basedebugger.h ../src/gui/editorwidget/codeeditor.h ../src/gui/editorwidget/compiler.h ../src/gui/editorwidget/editorwidget.h ../src/gui/editorwidget/editorwindow.h ../src/gui/editorwidget/highlighter.h ../src/gui/editorwidget/scrollbar.h ../src/gui/filebrowser/filebrowser.h ../src/gui/filebrowser/filewidget.h ../src/gui/memory/headerwidget.h ../src/gui/memory/mcumonitor.h ../src/gui/memory/memdata.h ../src/gui/memory/memtable.h ../src/gui/memory/ramtable.h ../src/gui/memory/valuewidget.h ../src/gui/memory/watcher.h ../src/gui/properties/boolprop.h ../src/gui/properties/boolval.h ../src/gui/properties/colorval.h ../src/gui/properties/comproperty.h ../src/gui/properties/doubleprop.h ../src/gui/properties/dspinbox.h ../src/gui/properties/enumval.h ../src/gui/properties/intprop.h ../src/gui/properties/labelval.h ../src/gui/properties/numprop.h ../src/gui/properties/numval.h ../src/gui/properties/pathval.h ../src/gui/properties/pointprop.h ../src/gui/properties/propdialog.h ../src/gui/properties/proputils.h ../src/gui/properties/propval.h ../src/gui/properties/scriptprop.h ../src/gui/properties/stringprop.h ../src/gui/properties/strval.h ../src/gui/properties/textval.h ../src/gui/serial/console.h ../src/gui/serial/serialmon.h ../src/microsim/cores/corebase.h ../src/microsim/cores/cpubase.h ../src/microsim/cores/mcucpu.h ../src/simulator/elements/e-clocked_device.h ../src/components/other/truthtable/truthtable.h ../src/components/outputs/displays/aip31068_i2c.h ../src/components/outputs/displays/hd44780.h ../src/components/outputs/displays/hd44780_base.h ../src/components/outputs/displays/ili9341.h ../src/components/outputs/displays/ks0108.h ../src/components/outputs/displays/pcd8544.h ../src/components/outputs/displays/ssd1306.h ../src/components/outputs/leds/led.h ../src/components/outputs/leds/ledbar.h ../src/components/outputs/leds/ledbase.h ../src/components/outputs/leds/ledmatrix.h ../src/components/outputs/leds/ledrgb.h ../src/components/outputs/leds/ledsmd.h ../src/components/outputs/leds/max72xx_matrix.h ../src/components/outputs/leds/sevensegment.h ../src/components/outputs/leds/ws2812.h ../src/components/outputs/motors/dcmotor.h ../src/components/outputs/motors/servo.h ../src/components/outputs/motors/stepper.h ../src/components/passive/reactive/capacitor.h ../src/components/passive/reactive/capacitorbase.h ../src/components/passive/reactive/elcapacitor.h ../src/components/passive/reactive/inductor.h ../src/components/passive/reactive/reactive.h ../src/components/passive/reactive/transformer.h ../src/components/passive/resist_sensors/ldr.h ../src/components/passive/resist_sensors/rtd.h ../src/components/passive/resist_sensors/strain.h ../src/components/passive/resist_sensors/thermistor.h ../src/components/passive/resist_sensors/thermistorbase.h ../src/components/passive/resistors/potentiometer.h ../src/components/passive/resistors/resistor.h ../src/components/passive/resistors/resistordip.h ../src/components/passive/resistors/varresbase.h ../src/components/passive/resistors/varresistor.h ../src/gui/editorwidget/debuggers/asdebugger.h ../src/gui/editorwidget/debuggers/avrgccdebugger.h ../src/gui/editorwidget/debuggers/cdebugger.h ../src/gui/editorwidget/debuggers/gcbdebugger.h ../src/gui/editorwidget/debuggers/gputilsdebug.h ../src/gui/editorwidget/debuggers/inodebugger.h ../src/gui/editorwidget/debuggers/sdccdebugger.h ../src/gui/editorwidget/debuggers/xc8debugger.h ../src/gui/editorwidget/dialogs/findreplace.h ../src/microsim/cores/avr/avr_defines.h ../src/microsim/cores/avr/avradc.h ../src/microsim/cores/avr/avrcomparator.h ../src/microsim/cores/avr/avrcore.h ../src/microsim/cores/avr/avreeprom.h ../src/microsim/cores/avr/avricunit.h ../src/microsim/cores/avr/avrinterrupt.h ../src/microsim/cores/avr/avrintosc.h ../src/microsim/cores/avr/avrocm.h ../src/microsim/cores/avr/avrocunit.h ../src/microsim/cores/avr/avrpin.h ../src/microsim/cores/avr/avrport.h ../src/microsim/cores/avr/avrsleep.h ../src/microsim/cores/avr/avrspi.h ../src/microsim/cores/avr/avrtimer.h ../src/microsim/cores/avr/avrtwi.h ../src/microsim/cores/avr/avrtwicodes.h ../src/microsim/cores/avr/avrusart.h ../src/microsim/cores/avr/avrusi.h ../src/microsim/cores/avr/avrwdt.h ../src/microsim/cores/i51/i51core.h ../src/microsim/cores/i51/i51pin.h ../src/microsim/cores/i51/i51port.h ../src/microsim/cores/i51/i51timer.h ../src/microsim/cores/i51/i51usart.h ../src/microsim/cores/intmem/intmemcore.h ../src/microsim/cores/mcs65/mcs65core.h ../src/microsim/cores/mcs65/mcs65interface.h ../src/microsim/cores/pic/pic14core.h ../src/microsim/cores/pic/pic14ecore.h ../src/microsim/cores/pic/pic14einterrupt.h ../src/microsim/cores/pic/picadc.h ../src/microsim/cores/pic/picccpunit.h ../src/microsim/cores/pic/piccomparator.h ../src/microsim/cores/pic/picconfigword.h ../src/microsim/cores/pic/picdac.h ../src/microsim/cores/pic/piceeprom.h ../src/microsim/cores/pic/picicunit.h ../src/microsim/cores/pic/picinterrupt.h ../src/microsim/cores/pic/picintosc.h ../src/microsim/cores/pic/picmrcore.h ../src/microsim/cores/pic/picmssp.h ../src/microsim/cores/pic/picocunit.h ../src/microsim/cores/pic/picpin.h ../src/microsim/cores/pic/picport.h ../src/microsim/cores/pic/picsleep.h ../src/microsim/cores/pic/picspi.h ../src/microsim/cores/pic/pictimer.h ../src/microsim/cores/pic/pictwi.h ../src/microsim/cores/pic/picusart.h ../src/microsim/cores/pic/picvref.h ../src/microsim/cores/pic/picwdt.h ../src/microsim/cores/scripted/display.h ../src/microsim/cores/scripted/scriptcpu.h ../src/microsim/cores/scripted/scriptdisplay.h ../src/microsim/cores/scripted/scriptperif.h ../src/microsim/cores/scripted/scriptport.h ../src/microsim/cores/scripted/scriptspi.h ../src/microsim/cores/scripted/scripttcp.h ../src/microsim/cores/scripted/scripttwi.h ../src/microsim/cores/scripted/scriptusart.h ../src/microsim/cores/z80/ula_zx48k.h ../src/microsim/cores/z80/z80core.h ../src/microsim/cores/z80/z80cycles.h ../src/microsim/cores/z80/z80regs.h ../src/microsim/modules/script/scriptbase.h ../src/microsim/modules/script/scriptmodule.h ../src/microsim/modules/spi/spimodule.h ../src/microsim/modules/tcp/tcpmodule.h ../src/microsim/modules/twi/twimodule.h ../src/microsim/modules/usart/usartmodule.h ../src/microsim/modules/usart/usartrx.h ../src/microsim/modules/usart/usarttx.h ../src/simulator/elements/active/e-bjt.h ../src/simulator/elements/active/e-diode.h ../src/simulator/elements/active/e-mosfet.h ../src/simulator/elements/outputs/e-led.h ../src/simulator/elements/passive/e-coil.h ../src/simulator/elements/passive/e-reactive.h ../src/simulator/elements/passive/e-resistor.h $(DISTDIR)/
	$(COPY_FILE) --parents ../src/main.cpp ../src/mainwindow.cpp ../src/utils.cpp ../src/components/comp2pin.cpp ../src/components/component.cpp ../src/components/iocomponent.cpp ../src/components/linker.cpp ../src/components/linkercomponent.cpp ../src/components/logiccomponent.cpp ../src/components/logicfamily.cpp ../src/components/node.cpp ../src/gui/custombutton.cpp ../src/gui/customdial.cpp ../src/gui/customslider.cpp ../src/gui/dialwidget.cpp ../src/gui/joystickwidget.cpp ../src/gui/outpaneltext.cpp ../src/gui/sourcewidget.cpp ../src/microsim/datautils.cpp ../src/microsim/e_iou.cpp ../src/microsim/e_mcu.cpp ../src/microsim/mcu.cpp ../src/microsim/mcuadc.cpp ../src/microsim/mcucomparator.cpp ../src/microsim/mcuconfigword.cpp ../src/microsim/mcucreator.cpp ../src/microsim/mcudac.cpp ../src/microsim/mcudataspace.cpp ../src/microsim/mcueeprom.cpp ../src/microsim/mcuicunit.cpp ../src/microsim/mcuinterrupts.cpp ../src/microsim/mcuintosc.cpp ../src/microsim/mcumodule.cpp ../src/microsim/mcuocm.cpp ../src/microsim/mcuocunit.cpp ../src/microsim/mcupin.cpp ../src/microsim/mcuport.cpp ../src/microsim/mcuprescaled.cpp ../src/microsim/mcusleep.cpp ../src/microsim/mcuspi.cpp ../src/microsim/mcutimer.cpp ../src/microsim/mcutwi.cpp ../src/microsim/mcuuart.cpp ../src/microsim/mcuvref.cpp ../src/microsim/mcuwdt.cpp ../src/simulator/circmatrix.cpp ../src/simulator/e-element.cpp ../src/simulator/e-node.cpp ../src/simulator/e-pin.cpp ../src/simulator/simulator.cpp ../src/angel/JIT/as_jit.cpp ../src/angel/JIT/virtual_asm_linux.cpp ../src/angel/JIT/virtual_asm_windows.cpp ../src/angel/JIT/virtual_asm_x64.cpp ../src/angel/src/as_atomic.cpp ../src/angel/src/as_builder.cpp ../src/angel/src/as_bytecode.cpp ../src/angel/src/as_callfunc.cpp ../src/angel/src/as_callfunc_arm64.cpp ../src/angel/src/as_callfunc_x64_gcc.cpp ../src/angel/src/as_callfunc_x64_mingw.cpp ../src/angel/src/as_callfunc_x86.cpp ../src/angel/src/as_compiler.cpp ../src/angel/src/as_configgroup.cpp ../src/angel/src/as_context.cpp ../src/angel/src/as_datatype.cpp ../src/angel/src/as_gc.cpp ../src/angel/src/as_generic.cpp ../src/angel/src/as_globalproperty.cpp ../src/angel/src/as_memory.cpp ../src/angel/src/as_module.cpp ../src/angel/src/as_objecttype.cpp ../src/angel/src/as_outputbuffer.cpp ../src/angel/src/as_parser.cpp ../src/angel/src/as_scriptcode.cpp ../src/angel/src/as_scriptengine.cpp ../src/angel/src/as_scriptfunction.cpp ../src/angel/src/as_scriptnode.cpp ../src/angel/src/as_scriptobject.cpp ../src/angel/src/as_string.cpp ../src/angel/src/as_string_util.cpp ../src/angel/src/as_thread.cpp ../src/angel/src/as_tokenizer.cpp ../src/angel/src/as_typeinfo.cpp ../src/angel/src/as_variablescope.cpp ../src/angel/src/scriptarray.cpp ../src/angel/src/scripthelper.cpp ../src/angel/src/scriptstdstring.cpp ../src/components/active/bjt.cpp ../src/components/active/comparator.cpp ../src/components/active/diac.cpp ../src/components/active/diode.cpp ../src/components/active/mosfet.cpp ../src/components/active/mux_analog.cpp ../src/components/active/op_amp.cpp ../src/components/active/scr.cpp ../src/components/active/triac.cpp ../src/components/active/volt_reg.cpp ../src/components/active/zener.cpp ../src/components/connectors/header.cpp ../src/components/connectors/socket.cpp ../src/components/connectors/tunnel.cpp ../src/components/graphical/ellipse.cpp ../src/components/graphical/image.cpp ../src/components/graphical/line.cpp ../src/components/graphical/rectangle.cpp ../src/components/graphical/shape.cpp ../src/components/graphical/textcomponent.cpp ../src/components/logic/adc.cpp ../src/components/logic/bcdbase.cpp ../src/components/logic/bcdto7s.cpp ../src/components/logic/bcdtodec.cpp ../src/components/logic/bincounter.cpp ../src/components/logic/buffer.cpp ../src/components/logic/bus.cpp ../src/components/logic/dac.cpp ../src/components/logic/dectobcd.cpp ../src/components/logic/demux.cpp ../src/components/logic/dynamic_memory.cpp ../src/components/logic/flipflopbase.cpp ../src/components/logic/flipflopd.cpp ../src/components/logic/flipflopjk.cpp ../src/components/logic/flipfloprs.cpp ../src/components/logic/flipflopt.cpp ../src/components/logic/fulladder.cpp ../src/components/logic/function.cpp ../src/components/logic/gate.cpp ../src/components/logic/gate_and.cpp ../src/components/logic/gate_or.cpp ../src/components/logic/gate_xor.cpp ../src/components/logic/i2cram.cpp ../src/components/logic/i2ctoparallel.cpp ../src/components/logic/latchd.cpp ../src/components/logic/lm555.cpp ../src/components/logic/magnitudecomp.cpp ../src/components/logic/memory.cpp ../src/components/logic/mux.cpp ../src/components/logic/sevensegment_bcd.cpp ../src/components/logic/shiftreg.cpp ../src/components/meters/ampmeter.cpp ../src/components/meters/freqmeter.cpp ../src/components/meters/lachannel.cpp ../src/components/meters/logicanalizer.cpp ../src/components/meters/meter.cpp ../src/components/meters/oscope.cpp ../src/components/meters/oscopechannel.cpp ../src/components/meters/probe.cpp ../src/components/meters/voltmeter.cpp ../src/components/micro/dht22.cpp ../src/components/micro/ds1307.cpp ../src/components/micro/ds1621.cpp ../src/components/micro/ds18b20.cpp ../src/components/micro/esp01.cpp ../src/components/micro/ky023.cpp ../src/components/micro/ky040.cpp ../src/components/micro/rtclock.cpp ../src/components/micro/serialport.cpp ../src/components/micro/serialterm.cpp ../src/components/micro/sr04.cpp ../src/components/micro/touchpad.cpp ../src/components/micro/touchpadwidget.cpp ../src/components/other/dial.cpp ../src/components/other/packagepin.cpp ../src/components/other/subpackage.cpp ../src/components/other/testunit.cpp ../src/components/outputs/audio_out.cpp ../src/components/outputs/lamp.cpp ../src/components/sources/battery.cpp ../src/components/sources/clock-base.cpp ../src/components/sources/clock.cpp ../src/components/sources/csource.cpp ../src/components/sources/currsource.cpp ../src/components/sources/fixedvolt.cpp ../src/components/sources/ground.cpp ../src/components/sources/rail.cpp ../src/components/sources/varsource.cpp ../src/components/sources/voltsource.cpp ../src/components/sources/wavegen.cpp ../src/components/subcircuits/board.cpp ../src/components/subcircuits/chip.cpp ../src/components/subcircuits/logicsubc.cpp ../src/components/subcircuits/module.cpp ../src/components/subcircuits/shield.cpp ../src/components/subcircuits/subcircuit.cpp ../src/components/switches/keypad.cpp ../src/components/switches/mech_contact.cpp ../src/components/switches/push.cpp ../src/components/switches/push_base.cpp ../src/components/switches/relay.cpp ../src/components/switches/switch.cpp ../src/components/switches/switch_base.cpp ../src/components/switches/switchdip.cpp ../src/gui/appdialogs/about.cpp ../src/gui/appdialogs/appdialog.cpp ../src/gui/appdialogs/infowidget.cpp ../src/gui/circuitwidget/circuit.cpp ../src/gui/circuitwidget/circuitview.cpp ../src/gui/circuitwidget/circuitwidget.cpp ../src/gui/circuitwidget/compbase.cpp ../src/gui/circuitwidget/connbase.cpp ../src/gui/circuitwidget/connector.cpp ../src/gui/circuitwidget/connectorline.cpp ../src/gui/circuitwidget/dialed.cpp ../src/gui/circuitwidget/iopin.cpp ../src/gui/circuitwidget/ioport.cpp ../src/gui/circuitwidget/label.cpp ../src/gui/circuitwidget/pin.cpp ../src/gui/circuitwidget/updatable.cpp ../src/gui/componentlist/componentlist.cpp ../src/gui/componentlist/itemlibrary.cpp ../src/gui/componentlist/managecomps.cpp ../src/gui/componentlist/treeitem.cpp ../src/gui/dataplotwidget/datachannel.cpp ../src/gui/dataplotwidget/datalawidget.cpp ../src/gui/dataplotwidget/datawidget.cpp ../src/gui/dataplotwidget/lawidget.cpp ../src/gui/dataplotwidget/oscwidget.cpp ../src/gui/dataplotwidget/plotbase.cpp ../src/gui/dataplotwidget/plotdisplay.cpp ../src/gui/dataplotwidget/plotspinbox.cpp ../src/gui/editorwidget/basedebugger.cpp ../src/gui/editorwidget/codeeditor.cpp ../src/gui/editorwidget/compiler.cpp ../src/gui/editorwidget/editorwidget.cpp ../src/gui/editorwidget/editorwindow.cpp ../src/gui/editorwidget/highlighter.cpp ../src/gui/editorwidget/scrollbar.cpp ../src/gui/filebrowser/filebrowser.cpp ../src/gui/filebrowser/filewidget.cpp ../src/gui/memory/headerwidget.cpp ../src/gui/memory/mcumonitor.cpp ../src/gui/memory/memdata.cpp ../src/gui/memory/memtable.cpp ../src/gui/memory/ramtable.cpp ../src/gui/memory/valuewidget.cpp ../src/gui/memory/watcher.cpp ../src/gui/properties/boolval.cpp ../src/gui/properties/colorval.cpp ../src/gui/properties/comproperty.cpp ../src/gui/properties/dspinbox.cpp ../src/gui/properties/enumval.cpp ../src/gui/properties/labelval.cpp ../src/gui/properties/numprop.cpp ../src/gui/properties/numval.cpp ../src/gui/properties/pathval.cpp ../src/gui/properties/propdialog.cpp ../src/gui/properties/proputils.cpp ../src/gui/properties/propval.cpp ../src/gui/properties/strval.cpp ../src/gui/properties/textval.cpp ../src/gui/serial/console.cpp ../src/gui/serial/serialmon.cpp ../src/microsim/cores/corebase.cpp ../src/microsim/cores/cpubase.cpp ../src/microsim/cores/mcucpu.cpp ../src/simulator/elements/e-clocked_device.cpp ../src/components/other/truthtable/truthtable.cpp ../src/components/outputs/displays/aip31068_i2c.cpp ../src/components/outputs/displays/hd44780.cpp ../src/components/outputs/displays/hd44780_base.cpp ../src/components/outputs/displays/ili9341.cpp ../src/components/outputs/displays/ks0108.cpp ../src/components/outputs/displays/pcd8544.cpp ../src/components/outputs/displays/ssd1306.cpp ../src/components/outputs/leds/led.cpp ../src/components/outputs/leds/ledbar.cpp ../src/components/outputs/leds/ledbase.cpp ../src/components/outputs/leds/ledmatrix.cpp ../src/components/outputs/leds/ledrgb.cpp ../src/components/outputs/leds/ledsmd.cpp ../src/components/outputs/leds/max72xx_matrix.cpp ../src/components/outputs/leds/sevensegment.cpp ../src/components/outputs/leds/ws2812.cpp ../src/components/outputs/motors/dcmotor.cpp ../src/components/outputs/motors/servo.cpp ../src/components/outputs/motors/stepper.cpp ../src/components/passive/reactive/capacitor.cpp ../src/components/passive/reactive/capacitorbase.cpp ../src/components/passive/reactive/elcapacitor.cpp ../src/components/passive/reactive/inductor.cpp ../src/components/passive/reactive/reactive.cpp ../src/components/passive/reactive/transformer.cpp ../src/components/passive/resist_sensors/ldr.cpp ../src/components/passive/resist_sensors/rtd.cpp ../src/components/passive/resist_sensors/strain.cpp ../src/components/passive/resist_sensors/thermistor.cpp ../src/components/passive/resist_sensors/thermistorbase.cpp ../src/components/passive/resistors/potentiometer.cpp ../src/components/passive/resistors/resistor.cpp ../src/components/passive/resistors/resistordip.cpp ../src/components/passive/resistors/varresbase.cpp ../src/components/passive/resistors/varresistor.cpp ../src/gui/editorwidget/debuggers/asdebugger.cpp ../src/gui/editorwidget/debuggers/avrgccdebugger.cpp ../src/gui/editorwidget/debuggers/cdebugger.cpp ../src/gui/editorwidget/debuggers/gcbdebugger.cpp ../src/gui/editorwidget/debuggers/gputilsdebug.cpp ../src/gui/editorwidget/debuggers/inodebugger.cpp ../src/gui/editorwidget/debuggers/sdccdebugger.cpp ../src/gui/editorwidget/debuggers/xc8debugger.cpp ../src/gui/editorwidget/dialogs/findreplace.cpp ../src/microsim/cores/avr/avradc.cpp ../src/microsim/cores/avr/avrcomparator.cpp ../src/microsim/cores/avr/avrcore.cpp ../src/microsim/cores/avr/avreeprom.cpp ../src/microsim/cores/avr/avricunit.cpp ../src/microsim/cores/avr/avrinterrupt.cpp ../src/microsim/cores/avr/avrintosc.cpp ../src/microsim/cores/avr/avrocm.cpp ../src/microsim/cores/avr/avrocunit.cpp ../src/microsim/cores/avr/avrpin.cpp ../src/microsim/cores/avr/avrport.cpp ../src/microsim/cores/avr/avrsleep.cpp ../src/microsim/cores/avr/avrspi.cpp ../src/microsim/cores/avr/avrtimer.cpp ../src/microsim/cores/avr/avrtwi.cpp ../src/microsim/cores/avr/avrusart.cpp ../src/microsim/cores/avr/avrusi.cpp ../src/microsim/cores/avr/avrwdt.cpp ../src/microsim/cores/i51/i51core.cpp ../src/microsim/cores/i51/i51pin.cpp ../src/microsim/cores/i51/i51port.cpp ../src/microsim/cores/i51/i51timer.cpp ../src/microsim/cores/i51/i51usart.cpp ../src/microsim/cores/intmem/intmemcore.cpp ../src/microsim/cores/mcs65/mcs65core.cpp ../src/microsim/cores/mcs65/mcs65interface.cpp ../src/microsim/cores/pic/pic14core.cpp ../src/microsim/cores/pic/pic14ecore.cpp ../src/microsim/cores/pic/pic14einterrupt.cpp ../src/microsim/cores/pic/picadc.cpp ../src/microsim/cores/pic/picccpunit.cpp ../src/microsim/cores/pic/piccomparator.cpp ../src/microsim/cores/pic/picconfigword.cpp ../src/microsim/cores/pic/picdac.cpp ../src/microsim/cores/pic/piceeprom.cpp ../src/microsim/cores/pic/picicunit.cpp ../src/microsim/cores/pic/picinterrupt.cpp ../src/microsim/cores/pic/picintosc.cpp ../src/microsim/cores/pic/picmrcore.cpp ../src/microsim/cores/pic/picmssp.cpp ../src/microsim/cores/pic/picocunit.cpp ../src/microsim/cores/pic/picpin.cpp ../src/microsim/cores/pic/picport.cpp ../src/microsim/cores/pic/picsleep.cpp ../src/microsim/cores/pic/picspi.cpp ../src/microsim/cores/pic/pictimer.cpp ../src/microsim/cores/pic/pictwi.cpp ../src/microsim/cores/pic/picusart.cpp ../src/microsim/cores/pic/picvref.cpp ../src/microsim/cores/pic/picwdt.cpp ../src/microsim/cores/scripted/display.cpp ../src/microsim/cores/scripted/scriptcpu.cpp ../src/microsim/cores/scripted/scriptdisplay.cpp ../src/microsim/cores/scripted/scriptperif.cpp ../src/microsim/cores/scripted/scriptport.cpp ../src/microsim/cores/scripted/scriptspi.cpp ../src/microsim/cores/scripted/scripttcp.cpp ../src/microsim/cores/scripted/scripttwi.cpp ../src/microsim/cores/scripted/scriptusart.cpp ../src/microsim/cores/z80/ula_zx48k.cpp ../src/microsim/cores/z80/z80core.cpp ../src/microsim/modules/script/scriptbase.cpp ../src/microsim/modules/script/scriptmodule.cpp ../src/microsim/modules/spi/spimodule.cpp ../src/microsim/modules/tcp/tcpmodule.cpp ../src/microsim/modules/twi/twimodule.cpp ../src/microsim/modules/usart/usartmodule.cpp ../src/microsim/modules/usart/usartrx.cpp ../src/microsim/modules/usart/usarttx.cpp ../src/simulator/elements/active/e-bjt.cpp ../src/simulator/elements/active/e-diode.cpp ../src/simulator/elements/active/e-mosfet.cpp ../src/simulator/elements/outputs/e-led.cpp ../src/simulator/elements/passive/e-coil.cpp ../src/simulator/elements/passive/e-reactive.cpp ../src/simulator/elements/passive/e-resistor.cpp $(DISTDIR)/
	$(COPY_FILE) --parents ../src/gui/appdialogs/about.ui ../src/gui/appdialogs/appdialog.ui ../src/gui/appdialogs/infowidget.ui ../src/gui/componentlist/managecomps.ui ../src/gui/dataplotwidget/datalawidget.ui ../src/gui/dataplotwidget/datawidget.ui ../src/gui/dataplotwidget/lawidget.ui ../src/gui/dataplotwidget/oscwidget.ui ../src/gui/memory/headerwidget.ui ../src/gui/memory/mcumonitor.ui ../src/gui/memory/memtable.ui ../src/gui/memory/ramtable.ui ../src/gui/memory/valuewidget.ui ../src/gui/memory/watcher.ui ../src/gui/properties/boolval.ui ../src/gui/properties/colorval.ui ../src/gui/properties/enumval.ui ../src/gui/properties/labelval.ui ../src/gui/properties/numval.ui ../src/gui/properties/pathval.ui ../src/gui/properties/propdialog.ui ../src/gui/properties/strval.ui ../src/gui/properties/textval.ui ../src/gui/serial/serialmon.ui ../src/components/other/truthtable/truthtable.ui ../src/gui/editorwidget/dialogs/findreplace.ui $(DISTDIR)/
	$(COPY_FILE) --parents /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_cz.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_de.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_en.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_es.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_fr.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_it.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_nl.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_pt_BR.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_pt_PT.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_ru.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_sk.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_tr.ts /home/new/Desktop/SimulIDE-dev-master/resources/translations/simulide_zh_CN.ts $(DISTDIR)/
clean: compiler_clean
	-$(DEL_FILE) $(OBJECTS)
	-$(DEL_FILE) *~ core *.core
distclean: clean
	-$(DEL_FILE) $(TARGET)
	-$(DEL_FILE) .qmake.stash
	-$(DEL_FILE) Makefile
####### Sub-libraries
runLrelease:
	lrelease /home/new/Desktop/SimulIDE-dev-master/resources/translations/*.ts; lrelease /home/new/Desktop/SimulIDE-dev-master/resources/translations/qt/*.ts; $(MOVE) /home/new/Desktop/SimulIDE-dev-master/resources/translations/*.qm /home/new/Desktop/SimulIDE-dev-master/resources/qm; $(MOVE) /home/new/Desktop/SimulIDE-dev-master/resources/translations/qt/*.qm /home/new/Desktop/SimulIDE-dev-master/resources/qm;
copy2dest:
	$(COPY_DIR) /home/new/Desktop/SimulIDE-dev-master/resources/data /home/new/Desktop/SimulIDE-dev-master/build_XX/executables/SimulIDE_1.2.0; $(COPY_DIR) /home/new/Desktop/SimulIDE-dev-master/resources/examples /home/new/Desktop/SimulIDE-dev-master/build_XX/executables/SimulIDE_1.2.0;
mocclean: compiler_moc_header_clean compiler_moc_objc_header_clean compiler_moc_source_clean
mocables: compiler_moc_header_make_all compiler_moc_objc_header_make_all compiler_moc_source_make_all
check: first
benchmark: first
compiler_rcc_make_all: qrc_application.cpp
compiler_rcc_clean:
	-$(DEL_FILE) qrc_application.cpp
qrc_application.cpp: ../src/application.qrc \
		/opt/qt5.15.15/bin/rcc \
		../resources/qm/simulide_ru.qm \
		../src/icons/components/voltimeter.png \
		../src/icons/components/max72xx.png \
		../src/icons/components/transformer.png \
		../src/icons/components/1to2.png \
		../src/icons/components/tunnel.png \
		../src/icons/mainwindow/unuse.png \
		../src/icons/components/bus.png \
		../src/icons/components/diac.png \
		../src/icons/components/resistor.png \
		../resources/qm/qt_pt_PT.qm \
		../resources/qm/qt_es.qm \
		../src/icons/components/board.png \
		../src/icons/mainwindow/expose.png \
		../src/icons/components/probe.png \
		../src/icons/components/inductor.png \
		../src/icons/mainwindow/vflip.svg \
		../src/icons/mainwindow/new.svg \
		../src/icons/components/esp01.png \
		../resources/qm/simulide_pt_PT.qm \
		../resources/qm/simulide_es.qm \
		../src/icons/mainwindow/open.svg \
		../src/icons/mainwindow/powerdeb.png \
		../resources/qm/qt_tr.qm \
		../resources/fonts/UbuntuMono-B.ttf \
		../src/icons/mainwindow/pausesim.png \
		../src/icons/components/ic2.png \
		../src/icons/components/rnd.png \
		../src/icons/components/switch.png \
		../src/icons/components/rotencod.png \
		../src/icons/mainwindow/zoomfit.svg \
		../src/icons/components/sin.png \
		../src/icons/components/1to3-c.png \
		../src/icons/components/blanc.png \
		../src/icons/components/wavegen.png \
		../src/icons/components/scr.png \
		../resources/qm/simulide_tr.qm \
		../src/icons/components/socket.png \
		../src/icons/components/2to2.png \
		../src/icons/components/header.png \
		../src/icons/mainwindow/find.svg \
		../resources/fonts/UbuntuMono-RI.ttf \
		../src/icons/components/subc_ico.png \
		../src/icons/components/toggleswitch.png \
		../src/icons/components/demux.png \
		../src/icons/components/zener.png \
		../src/icons/components/ic_comp.png \
		../src/icons/mainwindow/brkpoint.png \
		../src/icons/components/mux.png \
		../src/icons/components/ledrgb.png \
		../resources/qm/qt_sk.qm \
		../src/icons/components/dht22.png \
		../src/icons/components/dial.png \
		../src/icons/components/pcd8544.png \
		../src/icons/components/rectangle.png \
		../src/icons/components/oscope.png \
		../src/icons/components/mosfet.png \
		../resources/fonts/Ubuntu-R.ttf \
		../src/icons/mainwindow/rename.svg \
		../src/icons/components/bjt.png \
		../src/icons/components/ic2_comp.png \
		../resources/qm/simulide_sk.qm \
		../src/icons/mainwindow/config.svg \
		../src/icons/components/serialport.png \
		../src/icons/mainwindow/link.png \
		../src/icons/components/ky-040.png \
		../src/icons/mainwindow/saveas.svg \
		../src/icons/components/displays.png \
		../src/icons/mainwindow/help.svg \
		../src/icons/mainwindow/load.svg \
		../src/icons/mainwindow/poweroff.png \
		../src/icons/mainwindow/stop.svg \
		../src/icons/components/seven_segment.png \
		../src/icons/components/3to2.png \
		../src/icons/components/battery.png \
		../src/icons/components/sr04_ico.png \
		../src/icons/components/diode.png \
		../src/icons/components/gates.png \
		../src/icons/components/voltage.png \
		../src/icons/mainwindow/remove.svg \
		../src/icons/components/triac.png \
		../src/icons/components/socket_V.png \
		../src/icons/mainwindow/cut.svg \
		../src/icons/components/ili9341.png \
		../src/icons/components/ledbar.png \
		../src/icons/components/rectifiers.png \
		../src/icons/components/bug.png \
		../src/icons/components/leds.png \
		../src/icons/components/lamp.png \
		../src/icons/mainwindow/attach.png \
		../src/icons/components/keypad.png \
		../src/icons/mainwindow/hflip.svg \
		../resources/qm/qt_en.qm \
		../src/icons/mainwindow/simpaused.png \
		../src/icons/components/potentiometer.png \
		../src/icons/components/frequencimeter.png \
		../src/icons/mainwindow/nobreakpoint.png \
		../src/icons/components/lanalizer.png \
		../src/icons/components/1to3.png \
		../src/icons/components/cursource.png \
		../src/icons/components/transistors.png \
		../src/icons/components/line.png \
		../resources/qm/simulide_en.qm \
		../src/icons/components/resistordip.png \
		../src/icons/components/dcmotor.png \
		../src/icons/components/ledmatrix.png \
		../src/icons/mainwindow/closeterminal.png \
		../src/icons/components/buffer.png \
		../src/icons/components/push.png \
		../src/icons/components/voltreg.png \
		../src/icons/mainwindow/properties.svg \
		../resources/qm/qt_cz.qm \
		../src/icons/components/up.png \
		../src/icons/components/1to1.png \
		../src/icons/components/orgate.png \
		../src/icons/components/serialterm.png \
		../src/icons/components/motors.png \
		../src/icons/components/andgate.png \
		../src/icons/components/saw.png \
		../src/icons/components/switchdip.png \
		../resources/qm/qt_zh_CN.qm \
		../src/icons/components/led.png \
		../src/icons/components/null-0.png \
		../resources/qm/simulide_cz.qm \
		../src/icons/mainwindow/debug.svg \
		../resources/icons/simulide.png \
		../src/icons/mainwindow/terminal.svg \
		../resources/qm/qt_fr.qm \
		../src/icons/mainwindow/step.svg \
		../src/icons/mainwindow/detach.png \
		../src/icons/components/joystick.png \
		../resources/fonts/UbuntuMono-R.ttf \
		../resources/fonts/UbuntuMono-BI.ttf \
		../resources/qm/simulide_zh_CN.qm \
		../src/icons/components/7segbcd.png \
		../src/icons/mainwindow/lastfiles.svg \
		../src/icons/components/thermistor.png \
		../src/icons/components/subc.png \
		../src/icons/components/img.png \
		../src/icons/components/xorgate.png \
		../resources/qm/simulide_fr.qm \
		../src/icons/mainwindow/poweron.png \
		../src/icons/components/ldr.png \
		../src/icons/components/2to3.png \
		../src/icons/components/csource.png \
		../src/icons/mainwindow/upload.svg \
		../src/icons/components/ellipse.png \
		../resources/qm/qt_pt_BR.qm \
		../src/icons/mainwindow/rotate180.svg \
		../src/icons/mainwindow/about.svg \
		../src/icons/components/rail.png \
		../src/icons/components/hd44780.png \
		../src/icons/components/subc2.png \
		../src/icons/components/amperimeter.png \
		../src/icons/components/null_ico.png \
		../src/icons/mainwindow/rotateccw.svg \
		../src/icons/mainwindow/switchbut.png \
		../src/icons/mainwindow/verify.png \
		../src/icons/components/header_U.png \
		../src/icons/mainwindow/pause.svg \
		../resources/qm/simulide_pt_BR.qm \
		../src/icons/components/2to1.png \
		../resources/qm/qt_de.qm \
		../src/icons/mainwindow/copy.svg \
		../src/icons/components/null.png \
		../src/icons/components/varresistor.png \
		../src/icons/mainwindow/verify.svg \
		../src/icons/components/text.png \
		../src/icons/components/touch.png \
		../src/icons/mainwindow/paste.svg \
		../src/icons/mainwindow/rotatecw.svg \
		../src/icons/components/ky-023.png \
		../resources/qm/simulide_de.qm \
		../src/icons/components/resistors.png \
		../src/icons/components/header_D.png \
		../src/icons/components/esp01_ico.png \
		../src/icons/components/audio_out.png \
		../src/icons/components/3to2g.png \
		../src/icons/components/subcl.png \
		../src/icons/components/perif.png \
		../src/icons/mainwindow/reload.svg \
		../src/icons/components/script_ico.png \
		../resources/fonts/Ubuntu-B.ttf \
		../src/icons/components/ground.png \
		../src/icons/components/opamp.png \
		../src/icons/components/sr04.png \
		../src/icons/components/tri.png \
		../src/icons/components/capacitor.png \
		../resources/qm/qt_nl.qm \
		../src/icons/components/ks0108.png \
		../src/icons/mainwindow/zoomsel.svg \
		../resources/qm/qt_it.qm \
		../src/icons/mainwindow/reset.svg \
		../src/icons/components/reactive.png \
		../src/icons/components/steeper.png \
		../src/icons/components/giu.png \
		../src/icons/mainwindow/cdup.png \
		../src/icons/components/socket_H.png \
		../src/icons/components/dsxxx_ico.png \
		../resources/qm/simulide_nl.qm \
		../src/icons/components/dsxxx.png \
		../resources/qm/simulide_it.qm \
		../src/icons/components/sqa.png \
		../src/icons/components/3to1.png \
		../src/icons/components/voltsource.png \
		../src/icons/components/relay-spst.png \
		../src/icons/components/down.png \
		../src/icons/mainwindow/invert.png \
		../src/icons/components/su.png \
		../src/icons/components/servo.png \
		../src/icons/components/resistorsensors.png \
		../src/icons/mainwindow/save.svg \
		../src/icons/mainwindow/runtobk.png \
		../src/icons/components/aip31068.png \
		../resources/qm/qt_ru.qm \
		../src/icons/components/ssd1306.png \
		../src/icons/components/shield.png \
		../src/icons/mainwindow/breakpoint.png \
		../src/icons/components/elcapacitor.png \
		../src/icons/components/clock.png \
		../src/icons/components/wav.png \
		../src/icons/mainwindow/zoomone.svg \
		../src/icons/components/strain.png \
		../src/icons/mainwindow/saveimage.svg \
		../src/icons/components/ws2812.png \
		../src/icons/font/font2.png \
		../src/icons/components/rtd.png \
		../src/icons/components/2to3g.png
	/opt/qt5.15.15/bin/rcc -name application ../src/application.qrc -o qrc_application.cpp
compiler_moc_predefs_make_all: build/moc/moc_predefs.h
compiler_moc_predefs_clean:
	-$(DEL_FILE) build/moc/moc_predefs.h
build/moc/moc_predefs.h: /opt/qt5.15.15/mkspecs/features/data/dummy.cpp
	aarch64-linux-gnu-g++ -pipe -Wno-unused-parameter -Wno-implicit-fallthrough -fno-strict-aliasing -Wno-cast-function-type -Wno-deprecated-copy -Wno-invalid-offsetof -fno-pic -Ofast -O2 -std=gnu++11 -Wall -Wextra -dM -E -o build/moc/moc_predefs.h /opt/qt5.15.15/mkspecs/features/data/dummy.cpp
compiler_moc_header_make_all: build/moc/moc_mainwindow.cpp build/moc/moc_custombutton.cpp build/moc/moc_customdial.cpp build/moc/moc_customslider.cpp build/moc/moc_dialwidget.cpp build/moc/moc_outpaneltext.cpp build/moc/moc_simulator.cpp build/moc/moc_about.cpp build/moc/moc_appdialog.cpp build/moc/moc_infowidget.cpp build/moc/moc_circuit.cpp build/moc/moc_circuitwidget.cpp build/moc/moc_datalawidget.cpp build/moc/moc_datawidget.cpp build/moc/moc_lawidget.cpp build/moc/moc_oscwidget.cpp build/moc/moc_plotdisplay.cpp build/moc/moc_codeeditor.cpp build/moc/moc_compiler.cpp build/moc/moc_editorwidget.cpp build/moc/moc_editorwindow.cpp build/moc/moc_highlighter.cpp build/moc/moc_filebrowser.cpp build/moc/moc_filewidget.cpp build/moc/moc_headerwidget.cpp build/moc/moc_mcumonitor.cpp build/moc/moc_memtable.cpp build/moc/moc_ramtable.cpp build/moc/moc_valuewidget.cpp build/moc/moc_watcher.cpp build/moc/moc_boolval.cpp build/moc/moc_colorval.cpp build/moc/moc_enumval.cpp build/moc/moc_labelval.cpp build/moc/moc_numval.cpp build/moc/moc_pathval.cpp build/moc/moc_propdialog.cpp build/moc/moc_strval.cpp build/moc/moc_textval.cpp build/moc/moc_serialmon.cpp build/moc/moc_truthtable.cpp build/moc/moc_findreplace.cpp
compiler_moc_header_clean:
	-$(DEL_FILE) build/moc/moc_mainwindow.cpp build/moc/moc_custombutton.cpp build/moc/moc_customdial.cpp build/moc/moc_customslider.cpp build/moc/moc_dialwidget.cpp build/moc/moc_outpaneltext.cpp build/moc/moc_simulator.cpp build/moc/moc_about.cpp build/moc/moc_appdialog.cpp build/moc/moc_infowidget.cpp build/moc/moc_circuit.cpp build/moc/moc_circuitwidget.cpp build/moc/moc_datalawidget.cpp build/moc/moc_datawidget.cpp build/moc/moc_lawidget.cpp build/moc/moc_oscwidget.cpp build/moc/moc_plotdisplay.cpp build/moc/moc_codeeditor.cpp build/moc/moc_compiler.cpp build/moc/moc_editorwidget.cpp build/moc/moc_editorwindow.cpp build/moc/moc_highlighter.cpp build/moc/moc_filebrowser.cpp build/moc/moc_filewidget.cpp build/moc/moc_headerwidget.cpp build/moc/moc_mcumonitor.cpp build/moc/moc_memtable.cpp build/moc/moc_ramtable.cpp build/moc/moc_valuewidget.cpp build/moc/moc_watcher.cpp build/moc/moc_boolval.cpp build/moc/moc_colorval.cpp build/moc/moc_enumval.cpp build/moc/moc_labelval.cpp build/moc/moc_numval.cpp build/moc/moc_pathval.cpp build/moc/moc_propdialog.cpp build/moc/moc_strval.cpp build/moc/moc_textval.cpp build/moc/moc_serialmon.cpp build/moc/moc_truthtable.cpp build/moc/moc_findreplace.cpp
build/moc/moc_mainwindow.cpp: ../src/mainwindow.h \
		/opt/qt5.15.15/include/QtWidgets/QMainWindow \
		/opt/qt5.15.15/include/QtWidgets/qmainwindow.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgetsglobal.h \
		/opt/qt5.15.15/include/QtGui/qtguiglobal.h \
		/opt/qt5.15.15/include/QtCore/qglobal.h \
		/opt/qt5.15.15/include/QtCore/qconfig-bootstrapped.h \
		/opt/qt5.15.15/include/QtCore/qconfig.h \
		/opt/qt5.15.15/include/QtCore/qtcore-config.h \
		/opt/qt5.15.15/include/QtCore/qsystemdetection.h \
		/opt/qt5.15.15/include/QtCore/qprocessordetection.h \
		/opt/qt5.15.15/include/QtCore/qcompilerdetection.h \
		/opt/qt5.15.15/include/QtCore/qtypeinfo.h \
		/opt/qt5.15.15/include/QtCore/qsysinfo.h \
		/opt/qt5.15.15/include/QtCore/qlogging.h \
		/opt/qt5.15.15/include/QtCore/qflags.h \
		/opt/qt5.15.15/include/QtCore/qatomic.h \
		/opt/qt5.15.15/include/QtCore/qbasicatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_bootstrap.h \
		/opt/qt5.15.15/include/QtCore/qgenericatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_cxx11.h \
		/opt/qt5.15.15/include/QtCore/qatomic_msvc.h \
		/opt/qt5.15.15/include/QtCore/qglobalstatic.h \
		/opt/qt5.15.15/include/QtCore/qmutex.h \
		/opt/qt5.15.15/include/QtCore/qnumeric.h \
		/opt/qt5.15.15/include/QtCore/qversiontagging.h \
		/opt/qt5.15.15/include/QtGui/qtgui-config.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgets-config.h \
		/opt/qt5.15.15/include/QtWidgets/qwidget.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs.h \
		/opt/qt5.15.15/include/QtCore/qnamespace.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs_impl.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs_win.h \
		/opt/qt5.15.15/include/QtCore/qobject.h \
		/opt/qt5.15.15/include/QtCore/qstring.h \
		/opt/qt5.15.15/include/QtCore/qchar.h \
		/opt/qt5.15.15/include/QtCore/qbytearray.h \
		/opt/qt5.15.15/include/QtCore/qrefcount.h \
		/opt/qt5.15.15/include/QtCore/qarraydata.h \
		/opt/qt5.15.15/include/QtCore/qstringliteral.h \
		/opt/qt5.15.15/include/QtCore/qstringalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qstringview.h \
		/opt/qt5.15.15/include/QtCore/qstringbuilder.h \
		/opt/qt5.15.15/include/QtCore/qlist.h \
		/opt/qt5.15.15/include/QtCore/qalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qiterator.h \
		/opt/qt5.15.15/include/QtCore/qhashfunctions.h \
		/opt/qt5.15.15/include/QtCore/qpair.h \
		/opt/qt5.15.15/include/QtCore/qvector.h \
		/opt/qt5.15.15/include/QtCore/qcontainertools_impl.h \
		/opt/qt5.15.15/include/QtCore/qpoint.h \
		/opt/qt5.15.15/include/QtCore/qbytearraylist.h \
		/opt/qt5.15.15/include/QtCore/qstringlist.h \
		/opt/qt5.15.15/include/QtCore/qregexp.h \
		/opt/qt5.15.15/include/QtCore/qstringmatcher.h \
		/opt/qt5.15.15/include/QtCore/qcoreevent.h \
		/opt/qt5.15.15/include/QtCore/qscopedpointer.h \
		/opt/qt5.15.15/include/QtCore/qmetatype.h \
		/opt/qt5.15.15/include/QtCore/qvarlengtharray.h \
		/opt/qt5.15.15/include/QtCore/qcontainerfwd.h \
		/opt/qt5.15.15/include/QtCore/qobject_impl.h \
		/opt/qt5.15.15/include/QtCore/qmargins.h \
		/opt/qt5.15.15/include/QtGui/qpaintdevice.h \
		/opt/qt5.15.15/include/QtCore/qrect.h \
		/opt/qt5.15.15/include/QtCore/qsize.h \
		/opt/qt5.15.15/include/QtGui/qpalette.h \
		/opt/qt5.15.15/include/QtGui/qcolor.h \
		/opt/qt5.15.15/include/QtGui/qrgb.h \
		/opt/qt5.15.15/include/QtGui/qrgba64.h \
		/opt/qt5.15.15/include/QtGui/qbrush.h \
		/opt/qt5.15.15/include/QtGui/qmatrix.h \
		/opt/qt5.15.15/include/QtGui/qpolygon.h \
		/opt/qt5.15.15/include/QtGui/qregion.h \
		/opt/qt5.15.15/include/QtCore/qdatastream.h \
		/opt/qt5.15.15/include/QtCore/qiodevice.h \
		/opt/qt5.15.15/include/QtCore/qline.h \
		/opt/qt5.15.15/include/QtGui/qtransform.h \
		/opt/qt5.15.15/include/QtGui/qimage.h \
		/opt/qt5.15.15/include/QtGui/qpixelformat.h \
		/opt/qt5.15.15/include/QtGui/qpixmap.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer.h \
		/opt/qt5.15.15/include/QtCore/qshareddata.h \
		/opt/qt5.15.15/include/QtCore/qhash.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer_impl.h \
		/opt/qt5.15.15/include/QtGui/qfont.h \
		/opt/qt5.15.15/include/QtGui/qfontmetrics.h \
		/opt/qt5.15.15/include/QtGui/qfontinfo.h \
		/opt/qt5.15.15/include/QtWidgets/qsizepolicy.h \
		/opt/qt5.15.15/include/QtGui/qcursor.h \
		/opt/qt5.15.15/include/QtGui/qkeysequence.h \
		/opt/qt5.15.15/include/QtGui/qevent.h \
		/opt/qt5.15.15/include/QtCore/qvariant.h \
		/opt/qt5.15.15/include/QtCore/qmap.h \
		/opt/qt5.15.15/include/QtCore/qdebug.h \
		/opt/qt5.15.15/include/QtCore/qtextstream.h \
		/opt/qt5.15.15/include/QtCore/qlocale.h \
		/opt/qt5.15.15/include/QtCore/qset.h \
		/opt/qt5.15.15/include/QtCore/qcontiguouscache.h \
		/opt/qt5.15.15/include/QtCore/qurl.h \
		/opt/qt5.15.15/include/QtCore/qurlquery.h \
		/opt/qt5.15.15/include/QtCore/qfile.h \
		/opt/qt5.15.15/include/QtCore/qfiledevice.h \
		/opt/qt5.15.15/include/QtGui/qvector2d.h \
		/opt/qt5.15.15/include/QtGui/qtouchdevice.h \
		/opt/qt5.15.15/include/QtWidgets/qtabwidget.h \
		/opt/qt5.15.15/include/QtGui/qicon.h \
		/opt/qt5.15.15/include/QtCore/QDir \
		/opt/qt5.15.15/include/QtCore/qdir.h \
		/opt/qt5.15.15/include/QtCore/qfileinfo.h \
		build/moc/moc_predefs.h \
		/opt/qt5.15.15/bin/moc
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/mainwindow.h -o build/moc/moc_mainwindow.cpp
build/moc/moc_custombutton.cpp: ../src/gui/custombutton.h \
		/opt/qt5.15.15/include/QtWidgets/QToolButton \
		/opt/qt5.15.15/include/QtWidgets/qtoolbutton.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractbutton.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/custombutton.h -o build/moc/moc_custombutton.cpp
build/moc/moc_customdial.cpp: ../src/gui/customdial.h \
		/opt/qt5.15.15/include/QtWidgets/QDial \
		/opt/qt5.15.15/include/QtWidgets/qdial.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractslider.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/customdial.h -o build/moc/moc_customdial.cpp
build/moc/moc_customslider.cpp: ../src/gui/customslider.h \
		/opt/qt5.15.15/include/QtWidgets/QSlider \
		/opt/qt5.15.15/include/QtWidgets/qslider.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/customslider.h -o build/moc/moc_customslider.cpp
build/moc/moc_dialwidget.cpp: ../src/gui/dialwidget.h \
		/opt/qt5.15.15/include/QtWidgets/QWidget \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/dialwidget.h -o build/moc/moc_dialwidget.cpp
build/moc/moc_outpaneltext.cpp: ../src/gui/outpaneltext.h \
		/opt/qt5.15.15/include/QtWidgets/QPlainTextEdit \
		/opt/qt5.15.15/include/QtWidgets/qplaintextedit.h \
		/opt/qt5.15.15/include/QtWidgets/qtextedit.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractscrollarea.h \
		/opt/qt5.15.15/include/QtWidgets/qframe.h \
		/opt/qt5.15.15/include/QtGui/qtextdocument.h \
		/opt/qt5.15.15/include/QtGui/qtextoption.h \
		/opt/qt5.15.15/include/QtGui/qtextcursor.h \
		/opt/qt5.15.15/include/QtGui/qtextformat.h \
		/opt/qt5.15.15/include/QtGui/qpen.h \
		/opt/qt5.15.15/include/QtGui/qabstracttextdocumentlayout.h \
		/opt/qt5.15.15/include/QtGui/qtextlayout.h \
		/opt/qt5.15.15/include/QtGui/qglyphrun.h \
		/opt/qt5.15.15/include/QtGui/qrawfont.h \
		/opt/qt5.15.15/include/QtGui/qfontdatabase.h \
		/opt/qt5.15.15/include/QtGui/QSyntaxHighlighter \
		/opt/qt5.15.15/include/QtGui/qsyntaxhighlighter.h \
		/opt/qt5.15.15/include/QtGui/qtextobject.h \
		/opt/qt5.15.15/include/QtCore/QObject \
		../src/gui/circuitwidget/updatable.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/outpaneltext.h -o build/moc/moc_outpaneltext.cpp
build/moc/moc_simulator.cpp: ../src/simulator/simulator.h \
		../src/simulator/e-node.h \
		/opt/qt5.15.15/include/QtCore/QHash \
		../src/simulator/e-element.h \
		/opt/qt5.15.15/include/QtCore/QString \
		/opt/qt5.15.15/include/QtCore/QElapsedTimer \
		/opt/qt5.15.15/include/QtCore/qelapsedtimer.h \
		/opt/qt5.15.15/include/QtCore/QFuture \
		/opt/qt5.15.15/include/QtCore/qfuture.h \
		/opt/qt5.15.15/include/QtCore/qfutureinterface.h \
		/opt/qt5.15.15/include/QtCore/qrunnable.h \
		/opt/qt5.15.15/include/QtCore/qexception.h \
		/opt/qt5.15.15/include/QtCore/qresultstore.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/simulator/simulator.h -o build/moc/moc_simulator.cpp
build/moc/moc_about.cpp: ../src/gui/appdialogs/about.h \
		/opt/qt5.15.15/include/QtWidgets/QDialog \
		/opt/qt5.15.15/include/QtWidgets/qdialog.h \
		ui_about.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/appdialogs/about.h -o build/moc/moc_about.cpp
build/moc/moc_appdialog.cpp: ../src/gui/appdialogs/appdialog.h \
		ui_appdialog.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/appdialogs/appdialog.h -o build/moc/moc_appdialog.cpp
build/moc/moc_infowidget.cpp: ../src/gui/appdialogs/infowidget.h \
		ui_infowidget.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/appdialogs/infowidget.h -o build/moc/moc_infowidget.cpp
build/moc/moc_circuit.cpp: ../src/gui/circuitwidget/circuit.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsScene \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsscene.h \
		/opt/qt5.15.15/include/QtCore/QTimer \
		/opt/qt5.15.15/include/QtCore/qtimer.h \
		/opt/qt5.15.15/include/QtCore/qbasictimer.h \
		../src/components/component.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsItem \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsitem.h \
		/opt/qt5.15.15/include/QtGui/qpainterpath.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsSceneMouseEvent \
		/opt/qt5.15.15/include/QtWidgets/qgraphicssceneevent.h \
		../src/gui/circuitwidget/compbase.h \
		/opt/qt5.15.15/include/QtCore/QPointF \
		/opt/qt5.15.15/include/QtCore/QMap \
		/opt/qt5.15.15/include/QtCore/QCoreApplication \
		/opt/qt5.15.15/include/QtCore/qcoreapplication.h \
		/opt/qt5.15.15/include/QtCore/qeventloop.h \
		../src/gui/properties/proputils.h \
		/opt/qt5.15.15/include/QtCore/QStringRef \
		../src/gui/circuitwidget/connector.h \
		../src/gui/circuitwidget/pin.h \
		../src/simulator/e-pin.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/circuitwidget/circuit.h -o build/moc/moc_circuit.cpp
build/moc/moc_circuitwidget.cpp: ../src/gui/circuitwidget/circuitwidget.h \
		/opt/qt5.15.15/include/QtWidgets/QMenu \
		/opt/qt5.15.15/include/QtWidgets/qmenu.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgetsglobal.h \
		/opt/qt5.15.15/include/QtGui/qtguiglobal.h \
		/opt/qt5.15.15/include/QtCore/qglobal.h \
		/opt/qt5.15.15/include/QtCore/qconfig-bootstrapped.h \
		/opt/qt5.15.15/include/QtCore/qconfig.h \
		/opt/qt5.15.15/include/QtCore/qtcore-config.h \
		/opt/qt5.15.15/include/QtCore/qsystemdetection.h \
		/opt/qt5.15.15/include/QtCore/qprocessordetection.h \
		/opt/qt5.15.15/include/QtCore/qcompilerdetection.h \
		/opt/qt5.15.15/include/QtCore/qtypeinfo.h \
		/opt/qt5.15.15/include/QtCore/qsysinfo.h \
		/opt/qt5.15.15/include/QtCore/qlogging.h \
		/opt/qt5.15.15/include/QtCore/qflags.h \
		/opt/qt5.15.15/include/QtCore/qatomic.h \
		/opt/qt5.15.15/include/QtCore/qbasicatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_bootstrap.h \
		/opt/qt5.15.15/include/QtCore/qgenericatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_cxx11.h \
		/opt/qt5.15.15/include/QtCore/qatomic_msvc.h \
		/opt/qt5.15.15/include/QtCore/qglobalstatic.h \
		/opt/qt5.15.15/include/QtCore/qmutex.h \
		/opt/qt5.15.15/include/QtCore/qnumeric.h \
		/opt/qt5.15.15/include/QtCore/qversiontagging.h \
		/opt/qt5.15.15/include/QtGui/qtgui-config.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgets-config.h \
		/opt/qt5.15.15/include/QtWidgets/qwidget.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs.h \
		/opt/qt5.15.15/include/QtCore/qnamespace.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs_impl.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs_win.h \
		/opt/qt5.15.15/include/QtCore/qobject.h \
		/opt/qt5.15.15/include/QtCore/qstring.h \
		/opt/qt5.15.15/include/QtCore/qchar.h \
		/opt/qt5.15.15/include/QtCore/qbytearray.h \
		/opt/qt5.15.15/include/QtCore/qrefcount.h \
		/opt/qt5.15.15/include/QtCore/qarraydata.h \
		/opt/qt5.15.15/include/QtCore/qstringliteral.h \
		/opt/qt5.15.15/include/QtCore/qstringalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qstringview.h \
		/opt/qt5.15.15/include/QtCore/qstringbuilder.h \
		/opt/qt5.15.15/include/QtCore/qlist.h \
		/opt/qt5.15.15/include/QtCore/qalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qiterator.h \
		/opt/qt5.15.15/include/QtCore/qhashfunctions.h \
		/opt/qt5.15.15/include/QtCore/qpair.h \
		/opt/qt5.15.15/include/QtCore/qvector.h \
		/opt/qt5.15.15/include/QtCore/qcontainertools_impl.h \
		/opt/qt5.15.15/include/QtCore/qpoint.h \
		/opt/qt5.15.15/include/QtCore/qbytearraylist.h \
		/opt/qt5.15.15/include/QtCore/qstringlist.h \
		/opt/qt5.15.15/include/QtCore/qregexp.h \
		/opt/qt5.15.15/include/QtCore/qstringmatcher.h \
		/opt/qt5.15.15/include/QtCore/qcoreevent.h \
		/opt/qt5.15.15/include/QtCore/qscopedpointer.h \
		/opt/qt5.15.15/include/QtCore/qmetatype.h \
		/opt/qt5.15.15/include/QtCore/qvarlengtharray.h \
		/opt/qt5.15.15/include/QtCore/qcontainerfwd.h \
		/opt/qt5.15.15/include/QtCore/qobject_impl.h \
		/opt/qt5.15.15/include/QtCore/qmargins.h \
		/opt/qt5.15.15/include/QtGui/qpaintdevice.h \
		/opt/qt5.15.15/include/QtCore/qrect.h \
		/opt/qt5.15.15/include/QtCore/qsize.h \
		/opt/qt5.15.15/include/QtGui/qpalette.h \
		/opt/qt5.15.15/include/QtGui/qcolor.h \
		/opt/qt5.15.15/include/QtGui/qrgb.h \
		/opt/qt5.15.15/include/QtGui/qrgba64.h \
		/opt/qt5.15.15/include/QtGui/qbrush.h \
		/opt/qt5.15.15/include/QtGui/qmatrix.h \
		/opt/qt5.15.15/include/QtGui/qpolygon.h \
		/opt/qt5.15.15/include/QtGui/qregion.h \
		/opt/qt5.15.15/include/QtCore/qdatastream.h \
		/opt/qt5.15.15/include/QtCore/qiodevice.h \
		/opt/qt5.15.15/include/QtCore/qline.h \
		/opt/qt5.15.15/include/QtGui/qtransform.h \
		/opt/qt5.15.15/include/QtGui/qimage.h \
		/opt/qt5.15.15/include/QtGui/qpixelformat.h \
		/opt/qt5.15.15/include/QtGui/qpixmap.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer.h \
		/opt/qt5.15.15/include/QtCore/qshareddata.h \
		/opt/qt5.15.15/include/QtCore/qhash.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer_impl.h \
		/opt/qt5.15.15/include/QtGui/qfont.h \
		/opt/qt5.15.15/include/QtGui/qfontmetrics.h \
		/opt/qt5.15.15/include/QtGui/qfontinfo.h \
		/opt/qt5.15.15/include/QtWidgets/qsizepolicy.h \
		/opt/qt5.15.15/include/QtGui/qcursor.h \
		/opt/qt5.15.15/include/QtGui/qkeysequence.h \
		/opt/qt5.15.15/include/QtGui/qevent.h \
		/opt/qt5.15.15/include/QtCore/qvariant.h \
		/opt/qt5.15.15/include/QtCore/qmap.h \
		/opt/qt5.15.15/include/QtCore/qdebug.h \
		/opt/qt5.15.15/include/QtCore/qtextstream.h \
		/opt/qt5.15.15/include/QtCore/qlocale.h \
		/opt/qt5.15.15/include/QtCore/qset.h \
		/opt/qt5.15.15/include/QtCore/qcontiguouscache.h \
		/opt/qt5.15.15/include/QtCore/qurl.h \
		/opt/qt5.15.15/include/QtCore/qurlquery.h \
		/opt/qt5.15.15/include/QtCore/qfile.h \
		/opt/qt5.15.15/include/QtCore/qfiledevice.h \
		/opt/qt5.15.15/include/QtGui/qvector2d.h \
		/opt/qt5.15.15/include/QtGui/qtouchdevice.h \
		/opt/qt5.15.15/include/QtGui/qicon.h \
		/opt/qt5.15.15/include/QtWidgets/qaction.h \
		/opt/qt5.15.15/include/QtWidgets/qactiongroup.h \
		/opt/qt5.15.15/include/QtWidgets/QToolBar \
		/opt/qt5.15.15/include/QtWidgets/qtoolbar.h \
		/opt/qt5.15.15/include/QtWidgets/QVBoxLayout \
		/opt/qt5.15.15/include/QtWidgets/qboxlayout.h \
		/opt/qt5.15.15/include/QtWidgets/qlayout.h \
		/opt/qt5.15.15/include/QtWidgets/qlayoutitem.h \
		/opt/qt5.15.15/include/QtWidgets/qgridlayout.h \
		../src/gui/circuitwidget/circuitview.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsView \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsview.h \
		/opt/qt5.15.15/include/QtGui/qpainter.h \
		/opt/qt5.15.15/include/QtWidgets/qscrollarea.h \
		build/moc/moc_predefs.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/circuitwidget/circuitwidget.h -o build/moc/moc_circuitwidget.cpp
build/moc/moc_datalawidget.cpp: ../src/gui/dataplotwidget/datalawidget.h \
		ui_datalawidget.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/dataplotwidget/datalawidget.h -o build/moc/moc_datalawidget.cpp
build/moc/moc_datawidget.cpp: ../src/gui/dataplotwidget/datawidget.h \
		ui_datawidget.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/dataplotwidget/datawidget.h -o build/moc/moc_datawidget.cpp
build/moc/moc_lawidget.cpp: ../src/gui/dataplotwidget/lawidget.h \
		/opt/qt5.15.15/include/QtCore/QVector \
		ui_lawidget.h \
		../src/gui/dataplotwidget/plotdisplay.h \
		/opt/qt5.15.15/include/QtGui/QPixmap \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/dataplotwidget/lawidget.h -o build/moc/moc_lawidget.cpp
build/moc/moc_oscwidget.cpp: ../src/gui/dataplotwidget/oscwidget.h \
		ui_oscwidget.h \
		/opt/qt5.15.15/include/QtWidgets/QWidget \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/dataplotwidget/oscwidget.h -o build/moc/moc_oscwidget.cpp
build/moc/moc_plotdisplay.cpp: ../src/gui/dataplotwidget/plotdisplay.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/dataplotwidget/plotdisplay.h -o build/moc/moc_plotdisplay.cpp
build/moc/moc_codeeditor.cpp: ../src/gui/editorwidget/codeeditor.h \
		/opt/qt5.15.15/include/QtWidgets/QPlainTextEdit \
		/opt/qt5.15.15/include/QtWidgets/qplaintextedit.h \
		/opt/qt5.15.15/include/QtWidgets/qtextedit.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractscrollarea.h \
		/opt/qt5.15.15/include/QtWidgets/qframe.h \
		/opt/qt5.15.15/include/QtGui/qtextdocument.h \
		/opt/qt5.15.15/include/QtGui/qtextoption.h \
		/opt/qt5.15.15/include/QtGui/qtextcursor.h \
		/opt/qt5.15.15/include/QtGui/qtextformat.h \
		/opt/qt5.15.15/include/QtGui/qpen.h \
		/opt/qt5.15.15/include/QtGui/qabstracttextdocumentlayout.h \
		/opt/qt5.15.15/include/QtGui/qtextlayout.h \
		/opt/qt5.15.15/include/QtGui/qglyphrun.h \
		/opt/qt5.15.15/include/QtGui/qrawfont.h \
		/opt/qt5.15.15/include/QtGui/qfontdatabase.h \
		/opt/qt5.15.15/include/QtCore/QString \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/editorwidget/codeeditor.h -o build/moc/moc_codeeditor.cpp
build/moc/moc_compiler.cpp: ../src/gui/editorwidget/compiler.h \
		/opt/qt5.15.15/include/QtCore/QProcess \
		/opt/qt5.15.15/include/QtCore/qprocess.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/editorwidget/compiler.h -o build/moc/moc_compiler.cpp
build/moc/moc_editorwidget.cpp: ../src/gui/editorwidget/editorwidget.h \
		../src/gui/outpaneltext.h \
		/opt/qt5.15.15/include/QtGui/QSyntaxHighlighter \
		/opt/qt5.15.15/include/QtGui/qsyntaxhighlighter.h \
		/opt/qt5.15.15/include/QtGui/qtextobject.h \
		/opt/qt5.15.15/include/QtCore/QObject \
		../src/gui/circuitwidget/updatable.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/editorwidget/editorwidget.h -o build/moc/moc_editorwidget.cpp
build/moc/moc_editorwindow.cpp: ../src/gui/editorwidget/editorwindow.h \
		../src/gui/editorwidget/basedebugger.h \
		/opt/qt5.15.15/include/QtCore/QHash \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/editorwidget/editorwindow.h -o build/moc/moc_editorwindow.cpp
build/moc/moc_highlighter.cpp: ../src/gui/editorwidget/highlighter.h \
		/opt/qt5.15.15/include/QtGui/QTextCharFormat \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/editorwidget/highlighter.h -o build/moc/moc_highlighter.cpp
build/moc/moc_filebrowser.cpp: ../src/gui/filebrowser/filebrowser.h \
		/opt/qt5.15.15/include/QtWidgets/QTreeView \
		/opt/qt5.15.15/include/QtWidgets/qtreeview.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgetsglobal.h \
		/opt/qt5.15.15/include/QtGui/qtguiglobal.h \
		/opt/qt5.15.15/include/QtCore/qglobal.h \
		/opt/qt5.15.15/include/QtCore/qconfig-bootstrapped.h \
		/opt/qt5.15.15/include/QtCore/qconfig.h \
		/opt/qt5.15.15/include/QtCore/qtcore-config.h \
		/opt/qt5.15.15/include/QtCore/qsystemdetection.h \
		/opt/qt5.15.15/include/QtCore/qprocessordetection.h \
		/opt/qt5.15.15/include/QtCore/qcompilerdetection.h \
		/opt/qt5.15.15/include/QtCore/qtypeinfo.h \
		/opt/qt5.15.15/include/QtCore/qsysinfo.h \
		/opt/qt5.15.15/include/QtCore/qlogging.h \
		/opt/qt5.15.15/include/QtCore/qflags.h \
		/opt/qt5.15.15/include/QtCore/qatomic.h \
		/opt/qt5.15.15/include/QtCore/qbasicatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_bootstrap.h \
		/opt/qt5.15.15/include/QtCore/qgenericatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_cxx11.h \
		/opt/qt5.15.15/include/QtCore/qatomic_msvc.h \
		/opt/qt5.15.15/include/QtCore/qglobalstatic.h \
		/opt/qt5.15.15/include/QtCore/qmutex.h \
		/opt/qt5.15.15/include/QtCore/qnumeric.h \
		/opt/qt5.15.15/include/QtCore/qversiontagging.h \
		/opt/qt5.15.15/include/QtGui/qtgui-config.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgets-config.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractitemview.h \
		/opt/qt5.15.15/include/QtWidgets/qwidget.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs.h \
		/opt/qt5.15.15/include/QtCore/qnamespace.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs_impl.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs_win.h \
		/opt/qt5.15.15/include/QtCore/qobject.h \
		/opt/qt5.15.15/include/QtCore/qstring.h \
		/opt/qt5.15.15/include/QtCore/qchar.h \
		/opt/qt5.15.15/include/QtCore/qbytearray.h \
		/opt/qt5.15.15/include/QtCore/qrefcount.h \
		/opt/qt5.15.15/include/QtCore/qarraydata.h \
		/opt/qt5.15.15/include/QtCore/qstringliteral.h \
		/opt/qt5.15.15/include/QtCore/qstringalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qstringview.h \
		/opt/qt5.15.15/include/QtCore/qstringbuilder.h \
		/opt/qt5.15.15/include/QtCore/qlist.h \
		/opt/qt5.15.15/include/QtCore/qalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qiterator.h \
		/opt/qt5.15.15/include/QtCore/qhashfunctions.h \
		/opt/qt5.15.15/include/QtCore/qpair.h \
		/opt/qt5.15.15/include/QtCore/qvector.h \
		/opt/qt5.15.15/include/QtCore/qcontainertools_impl.h \
		/opt/qt5.15.15/include/QtCore/qpoint.h \
		/opt/qt5.15.15/include/QtCore/qbytearraylist.h \
		/opt/qt5.15.15/include/QtCore/qstringlist.h \
		/opt/qt5.15.15/include/QtCore/qregexp.h \
		/opt/qt5.15.15/include/QtCore/qstringmatcher.h \
		/opt/qt5.15.15/include/QtCore/qcoreevent.h \
		/opt/qt5.15.15/include/QtCore/qscopedpointer.h \
		/opt/qt5.15.15/include/QtCore/qmetatype.h \
		/opt/qt5.15.15/include/QtCore/qvarlengtharray.h \
		/opt/qt5.15.15/include/QtCore/qcontainerfwd.h \
		/opt/qt5.15.15/include/QtCore/qobject_impl.h \
		/opt/qt5.15.15/include/QtCore/qmargins.h \
		/opt/qt5.15.15/include/QtGui/qpaintdevice.h \
		/opt/qt5.15.15/include/QtCore/qrect.h \
		/opt/qt5.15.15/include/QtCore/qsize.h \
		/opt/qt5.15.15/include/QtGui/qpalette.h \
		/opt/qt5.15.15/include/QtGui/qcolor.h \
		/opt/qt5.15.15/include/QtGui/qrgb.h \
		/opt/qt5.15.15/include/QtGui/qrgba64.h \
		/opt/qt5.15.15/include/QtGui/qbrush.h \
		/opt/qt5.15.15/include/QtGui/qmatrix.h \
		/opt/qt5.15.15/include/QtGui/qpolygon.h \
		/opt/qt5.15.15/include/QtGui/qregion.h \
		/opt/qt5.15.15/include/QtCore/qdatastream.h \
		/opt/qt5.15.15/include/QtCore/qiodevice.h \
		/opt/qt5.15.15/include/QtCore/qline.h \
		/opt/qt5.15.15/include/QtGui/qtransform.h \
		/opt/qt5.15.15/include/QtGui/qimage.h \
		/opt/qt5.15.15/include/QtGui/qpixelformat.h \
		/opt/qt5.15.15/include/QtGui/qpixmap.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer.h \
		/opt/qt5.15.15/include/QtCore/qshareddata.h \
		/opt/qt5.15.15/include/QtCore/qhash.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer_impl.h \
		/opt/qt5.15.15/include/QtGui/qfont.h \
		/opt/qt5.15.15/include/QtGui/qfontmetrics.h \
		/opt/qt5.15.15/include/QtGui/qfontinfo.h \
		/opt/qt5.15.15/include/QtWidgets/qsizepolicy.h \
		/opt/qt5.15.15/include/QtGui/qcursor.h \
		/opt/qt5.15.15/include/QtGui/qkeysequence.h \
		/opt/qt5.15.15/include/QtGui/qevent.h \
		/opt/qt5.15.15/include/QtCore/qvariant.h \
		/opt/qt5.15.15/include/QtCore/qmap.h \
		/opt/qt5.15.15/include/QtCore/qdebug.h \
		/opt/qt5.15.15/include/QtCore/qtextstream.h \
		/opt/qt5.15.15/include/QtCore/qlocale.h \
		/opt/qt5.15.15/include/QtCore/qset.h \
		/opt/qt5.15.15/include/QtCore/qcontiguouscache.h \
		/opt/qt5.15.15/include/QtCore/qurl.h \
		/opt/qt5.15.15/include/QtCore/qurlquery.h \
		/opt/qt5.15.15/include/QtCore/qfile.h \
		/opt/qt5.15.15/include/QtCore/qfiledevice.h \
		/opt/qt5.15.15/include/QtGui/qvector2d.h \
		/opt/qt5.15.15/include/QtGui/qtouchdevice.h \
		/opt/qt5.15.15/include/QtCore/qabstractitemmodel.h \
		/opt/qt5.15.15/include/QtCore/qitemselectionmodel.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractitemdelegate.h \
		/opt/qt5.15.15/include/QtWidgets/qstyleoption.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractspinbox.h \
		/opt/qt5.15.15/include/QtGui/qvalidator.h \
		/opt/qt5.15.15/include/QtCore/qregularexpression.h \
		/opt/qt5.15.15/include/QtGui/qicon.h \
		/opt/qt5.15.15/include/QtWidgets/qslider.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractslider.h \
		/opt/qt5.15.15/include/QtWidgets/qstyle.h \
		/opt/qt5.15.15/include/QtWidgets/qtabbar.h \
		/opt/qt5.15.15/include/QtWidgets/qtabwidget.h \
		/opt/qt5.15.15/include/QtWidgets/qrubberband.h \
		build/moc/moc_predefs.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/filebrowser/filebrowser.h -o build/moc/moc_filebrowser.cpp
build/moc/moc_filewidget.cpp: ../src/gui/filebrowser/filewidget.h \
		/opt/qt5.15.15/include/QtWidgets/QSplitter \
		/opt/qt5.15.15/include/QtWidgets/qsplitter.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/filebrowser/filewidget.h -o build/moc/moc_filewidget.cpp
build/moc/moc_headerwidget.cpp: ../src/gui/memory/headerwidget.h \
		ui_headerwidget.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/memory/headerwidget.h -o build/moc/moc_headerwidget.cpp
build/moc/moc_mcumonitor.cpp: ../src/gui/memory/mcumonitor.h \
		/opt/qt5.15.15/include/QtWidgets/QDialog \
		/opt/qt5.15.15/include/QtWidgets/qdialog.h \
		/opt/qt5.15.15/include/QtWidgets/QTableWidget \
		/opt/qt5.15.15/include/QtWidgets/qtablewidget.h \
		/opt/qt5.15.15/include/QtWidgets/qtableview.h \
		ui_mcumonitor.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/memory/mcumonitor.h -o build/moc/moc_mcumonitor.cpp
build/moc/moc_memtable.cpp: ../src/gui/memory/memtable.h \
		/opt/qt5.15.15/include/QtWidgets/QWidget \
		ui_memtable.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/memory/memtable.h -o build/moc/moc_memtable.cpp
build/moc/moc_ramtable.cpp: ../src/gui/memory/ramtable.h \
		ui_ramtable.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/memory/ramtable.h -o build/moc/moc_ramtable.cpp
build/moc/moc_valuewidget.cpp: ../src/gui/memory/valuewidget.h \
		ui_valuewidget.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/memory/valuewidget.h -o build/moc/moc_valuewidget.cpp
build/moc/moc_watcher.cpp: ../src/gui/memory/watcher.h \
		ui_watcher.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/memory/watcher.h -o build/moc/moc_watcher.cpp
build/moc/moc_boolval.cpp: ../src/gui/properties/boolval.h \
		ui_boolval.h \
		../src/gui/properties/propval.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/properties/boolval.h -o build/moc/moc_boolval.cpp
build/moc/moc_colorval.cpp: ../src/gui/properties/colorval.h \
		ui_colorval.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/properties/colorval.h -o build/moc/moc_colorval.cpp
build/moc/moc_enumval.cpp: ../src/gui/properties/enumval.h \
		ui_enumval.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/properties/enumval.h -o build/moc/moc_enumval.cpp
build/moc/moc_labelval.cpp: ../src/gui/properties/labelval.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgetsglobal.h \
		/opt/qt5.15.15/include/QtGui/qtguiglobal.h \
		/opt/qt5.15.15/include/QtCore/qglobal.h \
		/opt/qt5.15.15/include/QtCore/qconfig-bootstrapped.h \
		/opt/qt5.15.15/include/QtCore/qconfig.h \
		/opt/qt5.15.15/include/QtCore/qtcore-config.h \
		/opt/qt5.15.15/include/QtCore/qsystemdetection.h \
		/opt/qt5.15.15/include/QtCore/qprocessordetection.h \
		/opt/qt5.15.15/include/QtCore/qcompilerdetection.h \
		/opt/qt5.15.15/include/QtCore/qtypeinfo.h \
		/opt/qt5.15.15/include/QtCore/qsysinfo.h \
		/opt/qt5.15.15/include/QtCore/qlogging.h \
		/opt/qt5.15.15/include/QtCore/qflags.h \
		/opt/qt5.15.15/include/QtCore/qatomic.h \
		/opt/qt5.15.15/include/QtCore/qbasicatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_bootstrap.h \
		/opt/qt5.15.15/include/QtCore/qgenericatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_cxx11.h \
		/opt/qt5.15.15/include/QtCore/qatomic_msvc.h \
		/opt/qt5.15.15/include/QtCore/qglobalstatic.h \
		/opt/qt5.15.15/include/QtCore/qmutex.h \
		/opt/qt5.15.15/include/QtCore/qnumeric.h \
		/opt/qt5.15.15/include/QtCore/qversiontagging.h \
		/opt/qt5.15.15/include/QtGui/qtgui-config.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgets-config.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs.h \
		/opt/qt5.15.15/include/QtCore/qnamespace.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs_impl.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs_win.h \
		/opt/qt5.15.15/include/QtCore/qobject.h \
		/opt/qt5.15.15/include/QtCore/qstring.h \
		/opt/qt5.15.15/include/QtCore/qchar.h \
		/opt/qt5.15.15/include/QtCore/qbytearray.h \
		/opt/qt5.15.15/include/QtCore/qrefcount.h \
		/opt/qt5.15.15/include/QtCore/qarraydata.h \
		/opt/qt5.15.15/include/QtCore/qstringliteral.h \
		/opt/qt5.15.15/include/QtCore/qstringalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qstringview.h \
		/opt/qt5.15.15/include/QtCore/qstringbuilder.h \
		/opt/qt5.15.15/include/QtCore/qlist.h \
		/opt/qt5.15.15/include/QtCore/qalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qiterator.h \
		/opt/qt5.15.15/include/QtCore/qhashfunctions.h \
		/opt/qt5.15.15/include/QtCore/qpair.h \
		/opt/qt5.15.15/include/QtCore/qvector.h \
		/opt/qt5.15.15/include/QtCore/qcontainertools_impl.h \
		/opt/qt5.15.15/include/QtCore/qpoint.h \
		/opt/qt5.15.15/include/QtCore/qbytearraylist.h \
		/opt/qt5.15.15/include/QtCore/qstringlist.h \
		/opt/qt5.15.15/include/QtCore/qregexp.h \
		/opt/qt5.15.15/include/QtCore/qstringmatcher.h \
		/opt/qt5.15.15/include/QtCore/qcoreevent.h \
		/opt/qt5.15.15/include/QtCore/qscopedpointer.h \
		/opt/qt5.15.15/include/QtCore/qmetatype.h \
		/opt/qt5.15.15/include/QtCore/qvarlengtharray.h \
		/opt/qt5.15.15/include/QtCore/qcontainerfwd.h \
		/opt/qt5.15.15/include/QtCore/qobject_impl.h \
		/opt/qt5.15.15/include/QtCore/qmargins.h \
		/opt/qt5.15.15/include/QtGui/qpaintdevice.h \
		/opt/qt5.15.15/include/QtCore/qrect.h \
		/opt/qt5.15.15/include/QtCore/qsize.h \
		/opt/qt5.15.15/include/QtGui/qpalette.h \
		/opt/qt5.15.15/include/QtGui/qcolor.h \
		/opt/qt5.15.15/include/QtGui/qrgb.h \
		/opt/qt5.15.15/include/QtGui/qrgba64.h \
		/opt/qt5.15.15/include/QtGui/qbrush.h \
		/opt/qt5.15.15/include/QtGui/qmatrix.h \
		/opt/qt5.15.15/include/QtGui/qpolygon.h \
		/opt/qt5.15.15/include/QtGui/qregion.h \
		/opt/qt5.15.15/include/QtCore/qdatastream.h \
		/opt/qt5.15.15/include/QtCore/qiodevice.h \
		/opt/qt5.15.15/include/QtCore/qline.h \
		/opt/qt5.15.15/include/QtGui/qtransform.h \
		/opt/qt5.15.15/include/QtGui/qimage.h \
		/opt/qt5.15.15/include/QtGui/qpixelformat.h \
		/opt/qt5.15.15/include/QtGui/qpixmap.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer.h \
		/opt/qt5.15.15/include/QtCore/qshareddata.h \
		/opt/qt5.15.15/include/QtCore/qhash.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer_impl.h \
		/opt/qt5.15.15/include/QtGui/qfont.h \
		/opt/qt5.15.15/include/QtGui/qfontmetrics.h \
		/opt/qt5.15.15/include/QtGui/qfontinfo.h \
		/opt/qt5.15.15/include/QtWidgets/qsizepolicy.h \
		/opt/qt5.15.15/include/QtGui/qcursor.h \
		/opt/qt5.15.15/include/QtGui/qkeysequence.h \
		/opt/qt5.15.15/include/QtGui/qevent.h \
		/opt/qt5.15.15/include/QtCore/qvariant.h \
		/opt/qt5.15.15/include/QtCore/qmap.h \
		/opt/qt5.15.15/include/QtCore/qdebug.h \
		/opt/qt5.15.15/include/QtCore/qtextstream.h \
		/opt/qt5.15.15/include/QtCore/qlocale.h \
		/opt/qt5.15.15/include/QtCore/qset.h \
		/opt/qt5.15.15/include/QtCore/qcontiguouscache.h \
		/opt/qt5.15.15/include/QtCore/qurl.h \
		/opt/qt5.15.15/include/QtCore/qurlquery.h \
		/opt/qt5.15.15/include/QtCore/qfile.h \
		/opt/qt5.15.15/include/QtCore/qfiledevice.h \
		/opt/qt5.15.15/include/QtGui/qvector2d.h \
		/opt/qt5.15.15/include/QtGui/qtouchdevice.h \
		ui_labelval.h \
		build/moc/moc_predefs.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/properties/labelval.h -o build/moc/moc_labelval.cpp
build/moc/moc_numval.cpp: ../src/gui/properties/numval.h \
		ui_numval.h \
		/opt/qt5.15.15/include/QtWidgets/qwidget.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/properties/numval.h -o build/moc/moc_numval.cpp
build/moc/moc_pathval.cpp: ../src/gui/properties/pathval.h \
		ui_pathval.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/properties/pathval.h -o build/moc/moc_pathval.cpp
build/moc/moc_propdialog.cpp: ../src/gui/properties/propdialog.h \
		/opt/qt5.15.15/include/QtWidgets/QDialog \
		/opt/qt5.15.15/include/QtWidgets/qdialog.h \
		ui_propdialog.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/properties/propdialog.h -o build/moc/moc_propdialog.cpp
build/moc/moc_strval.cpp: ../src/gui/properties/strval.h \
		ui_strval.h \
		/opt/qt5.15.15/include/QtWidgets/QWidget \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/properties/strval.h -o build/moc/moc_strval.cpp
build/moc/moc_textval.cpp: ../src/gui/properties/textval.h \
		ui_textval.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/properties/textval.h -o build/moc/moc_textval.cpp
build/moc/moc_serialmon.cpp: ../src/gui/serial/serialmon.h \
		ui_serialmon.h \
		../src/gui/outpaneltext.h \
		/opt/qt5.15.15/include/QtWidgets/QPlainTextEdit \
		/opt/qt5.15.15/include/QtWidgets/qplaintextedit.h \
		/opt/qt5.15.15/include/QtWidgets/qtextedit.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractscrollarea.h \
		/opt/qt5.15.15/include/QtWidgets/qframe.h \
		/opt/qt5.15.15/include/QtGui/qtextdocument.h \
		/opt/qt5.15.15/include/QtGui/qtextoption.h \
		/opt/qt5.15.15/include/QtGui/qtextcursor.h \
		/opt/qt5.15.15/include/QtGui/qtextformat.h \
		/opt/qt5.15.15/include/QtGui/qpen.h \
		/opt/qt5.15.15/include/QtGui/qabstracttextdocumentlayout.h \
		/opt/qt5.15.15/include/QtGui/qtextlayout.h \
		/opt/qt5.15.15/include/QtGui/qglyphrun.h \
		/opt/qt5.15.15/include/QtGui/qrawfont.h \
		/opt/qt5.15.15/include/QtGui/qfontdatabase.h \
		/opt/qt5.15.15/include/QtGui/QSyntaxHighlighter \
		/opt/qt5.15.15/include/QtGui/qsyntaxhighlighter.h \
		/opt/qt5.15.15/include/QtGui/qtextobject.h \
		/opt/qt5.15.15/include/QtCore/QObject \
		../src/gui/circuitwidget/updatable.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/serial/serialmon.h -o build/moc/moc_serialmon.cpp
build/moc/moc_truthtable.cpp: ../src/components/other/truthtable/truthtable.h \
		ui_truthtable.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/components/other/truthtable/truthtable.h -o build/moc/moc_truthtable.cpp
build/moc/moc_findreplace.cpp: ../src/gui/editorwidget/dialogs/findreplace.h \
		ui_findreplace.h \
	/opt/qt5.15.15/bin/moc $(DEFINES) --include /home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc/moc_predefs.h -I/opt/qt5.15.15/mkspecs/linux-aarch64-gnu-g++ -I/home/new/Desktop/SimulIDE-dev-master/build_XX -I/home/new/Desktop/SimulIDE-dev-master/src -I/home/new/Desktop/SimulIDE-dev-master/src/components -I/home/new/Desktop/SimulIDE-dev-master/src/components/active -I/home/new/Desktop/SimulIDE-dev-master/src/components/connectors -I/home/new/Desktop/SimulIDE-dev-master/src/components/graphical -I/home/new/Desktop/SimulIDE-dev-master/src/components/logic -I/home/new/Desktop/SimulIDE-dev-master/src/components/meters -I/home/new/Desktop/SimulIDE-dev-master/src/components/micro -I/home/new/Desktop/SimulIDE-dev-master/src/components/other -I/home/new/Desktop/SimulIDE-dev-master/src/components/other/truthtable -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/displays -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/leds -I/home/new/Desktop/SimulIDE-dev-master/src/components/outputs/motors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/reactive -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resistors -I/home/new/Desktop/SimulIDE-dev-master/src/components/passive/resist_sensors -I/home/new/Desktop/SimulIDE-dev-master/src/components/sources -I/home/new/Desktop/SimulIDE-dev-master/src/components/subcircuits -I/home/new/Desktop/SimulIDE-dev-master/src/components/switches -I/home/new/Desktop/SimulIDE-dev-master/src/gui -I/home/new/Desktop/SimulIDE-dev-master/src/gui/appdialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/circuitwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/componentlist -I/home/new/Desktop/SimulIDE-dev-master/src/gui/dataplotwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/debuggers -I/home/new/Desktop/SimulIDE-dev-master/src/gui/editorwidget/dialogs -I/home/new/Desktop/SimulIDE-dev-master/src/gui/filebrowser -I/home/new/Desktop/SimulIDE-dev-master/src/gui/memory -I/home/new/Desktop/SimulIDE-dev-master/src/gui/properties -I/home/new/Desktop/SimulIDE-dev-master/src/gui/serial -I/home/new/Desktop/SimulIDE-dev-master/src/simulator -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/active -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/outputs -I/home/new/Desktop/SimulIDE-dev-master/src/simulator/elements/passive -I/home/new/Desktop/SimulIDE-dev-master/src/microsim -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/avr -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/i51 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/pic -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/mcs65 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/z80 -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/scripted -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/cores/intmem -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/memory -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/usart -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/twi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/tcp -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/spi -I/home/new/Desktop/SimulIDE-dev-master/src/microsim/modules/script -I/home/new/Desktop/SimulIDE-dev-master/src/angel/include -I/home/new/Desktop/SimulIDE-dev-master/src/angel/JIT -I/home/new/Desktop/SimulIDE-dev-master/src/angel/src -I/home/new/Desktop/SimulIDE-dev-master/build_XX/build/moc -I/opt/qt5.15.15/include -I/opt/qt5.15.15/include/QtSvg -I/opt/qt5.15.15/include/QtWidgets -I/opt/qt5.15.15/include/QtMultimedia -I/opt/qt5.15.15/include/QtGui -I/opt/qt5.15.15/include/QtXml -I/opt/qt5.15.15/include/QtConcurrent -I/opt/qt5.15.15/include/QtSerialPort -I/opt/qt5.15.15/include/QtNetwork -I/opt/qt5.15.15/include/QtCore -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0 -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/aarch64-linux-gnu -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include/c++/7.5.0/backward -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib/gcc/aarch64-linux-gnu/7.5.0/include-fixed -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/include -I/opt/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/libc/usr/include ../src/gui/editorwidget/dialogs/findreplace.h -o build/moc/moc_findreplace.cpp
compiler_moc_objc_header_make_all:
compiler_moc_objc_header_clean:
compiler_moc_source_make_all:
compiler_moc_source_clean:
compiler_uic_make_all: ui_about.h ui_appdialog.h ui_infowidget.h ui_managecomps.h ui_datalawidget.h ui_datawidget.h ui_lawidget.h ui_oscwidget.h ui_headerwidget.h ui_mcumonitor.h ui_memtable.h ui_ramtable.h ui_valuewidget.h ui_watcher.h ui_boolval.h ui_colorval.h ui_enumval.h ui_labelval.h ui_numval.h ui_pathval.h ui_propdialog.h ui_strval.h ui_textval.h ui_serialmon.h ui_truthtable.h ui_findreplace.h
compiler_uic_clean:
	-$(DEL_FILE) ui_about.h ui_appdialog.h ui_infowidget.h ui_managecomps.h ui_datalawidget.h ui_datawidget.h ui_lawidget.h ui_oscwidget.h ui_headerwidget.h ui_mcumonitor.h ui_memtable.h ui_ramtable.h ui_valuewidget.h ui_watcher.h ui_boolval.h ui_colorval.h ui_enumval.h ui_labelval.h ui_numval.h ui_pathval.h ui_propdialog.h ui_strval.h ui_textval.h ui_serialmon.h ui_truthtable.h ui_findreplace.h
ui_about.h: ../src/gui/appdialogs/about.ui \
		/opt/qt5.15.15/bin/uic
	/opt/qt5.15.15/bin/uic ../src/gui/appdialogs/about.ui -o ui_about.h
ui_appdialog.h: ../src/gui/appdialogs/appdialog.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/appdialogs/appdialog.ui -o ui_appdialog.h
ui_infowidget.h: ../src/gui/appdialogs/infowidget.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/appdialogs/infowidget.ui -o ui_infowidget.h
ui_managecomps.h: ../src/gui/componentlist/managecomps.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/componentlist/managecomps.ui -o ui_managecomps.h
ui_datalawidget.h: ../src/gui/dataplotwidget/datalawidget.ui \
		/opt/qt5.15.15/bin/uic \
		../src/gui/custombutton.h \
		/opt/qt5.15.15/include/QtWidgets/QToolButton \
		/opt/qt5.15.15/include/QtWidgets/qtoolbutton.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractbutton.h \
		/opt/qt5.15.15/include/QtGui/qicon.h \
	/opt/qt5.15.15/bin/uic ../src/gui/dataplotwidget/datalawidget.ui -o ui_datalawidget.h
ui_datawidget.h: ../src/gui/dataplotwidget/datawidget.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/dataplotwidget/datawidget.ui -o ui_datawidget.h
ui_lawidget.h: ../src/gui/dataplotwidget/lawidget.ui \
		../src/gui/dataplotwidget/plotdisplay.h \
		../src/gui/dataplotwidget/plotspinbox.h \
		/opt/qt5.15.15/include/QtGui/QPixmap \
		/opt/qt5.15.15/include/QtWidgets/QDoubleSpinBox \
		/opt/qt5.15.15/include/QtWidgets/qspinbox.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractspinbox.h \
		/opt/qt5.15.15/include/QtGui/qvalidator.h \
		/opt/qt5.15.15/include/QtCore/qregularexpression.h
	/opt/qt5.15.15/bin/uic ../src/gui/dataplotwidget/lawidget.ui -o ui_lawidget.h
ui_oscwidget.h: ../src/gui/dataplotwidget/oscwidget.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/dataplotwidget/oscwidget.ui -o ui_oscwidget.h
ui_headerwidget.h: ../src/gui/memory/headerwidget.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/memory/headerwidget.ui -o ui_headerwidget.h
ui_mcumonitor.h: ../src/gui/memory/mcumonitor.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/memory/mcumonitor.ui -o ui_mcumonitor.h
ui_memtable.h: ../src/gui/memory/memtable.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/memory/memtable.ui -o ui_memtable.h
ui_ramtable.h: ../src/gui/memory/ramtable.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/memory/ramtable.ui -o ui_ramtable.h
ui_valuewidget.h: ../src/gui/memory/valuewidget.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/memory/valuewidget.ui -o ui_valuewidget.h
ui_watcher.h: ../src/gui/memory/watcher.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/memory/watcher.ui -o ui_watcher.h
ui_boolval.h: ../src/gui/properties/boolval.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/properties/boolval.ui -o ui_boolval.h
ui_colorval.h: ../src/gui/properties/colorval.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/properties/colorval.ui -o ui_colorval.h
ui_enumval.h: ../src/gui/properties/enumval.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/properties/enumval.ui -o ui_enumval.h
ui_labelval.h: ../src/gui/properties/labelval.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/properties/labelval.ui -o ui_labelval.h
ui_numval.h: ../src/gui/properties/numval.ui \
		../src/gui/properties/dspinbox.h \
		/opt/qt5.15.15/include/QtCore/qregularexpression.h \
		../src/angel/src/scripthelper.h \
		../src/angel/include/angelscript.h
	/opt/qt5.15.15/bin/uic ../src/gui/properties/numval.ui -o ui_numval.h
ui_pathval.h: ../src/gui/properties/pathval.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/properties/pathval.ui -o ui_pathval.h
ui_propdialog.h: ../src/gui/properties/propdialog.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/properties/propdialog.ui -o ui_propdialog.h
ui_strval.h: ../src/gui/properties/strval.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/properties/strval.ui -o ui_strval.h
ui_textval.h: ../src/gui/properties/textval.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/properties/textval.ui -o ui_textval.h
ui_serialmon.h: ../src/gui/serial/serialmon.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/serial/serialmon.ui -o ui_serialmon.h
ui_truthtable.h: ../src/components/other/truthtable/truthtable.ui \
	/opt/qt5.15.15/bin/uic ../src/components/other/truthtable/truthtable.ui -o ui_truthtable.h
ui_findreplace.h: ../src/gui/editorwidget/dialogs/findreplace.ui \
	/opt/qt5.15.15/bin/uic ../src/gui/editorwidget/dialogs/findreplace.ui -o ui_findreplace.h
compiler_yacc_decl_make_all:
compiler_yacc_decl_clean:
compiler_yacc_impl_make_all:
compiler_yacc_impl_clean:
compiler_lex_make_all:
compiler_lex_clean:
compiler_clean: compiler_rcc_clean compiler_moc_predefs_clean compiler_moc_header_clean compiler_uic_clean
####### Compile
build/objects/main.o: ../src/main.cpp /opt/qt5.15.15/include/QtWidgets/QApplication \
		/opt/qt5.15.15/include/QtWidgets/qapplication.h \
		/opt/qt5.15.15/include/QtCore/qcoreapplication.h \
		/opt/qt5.15.15/include/QtCore/qeventloop.h \
		/opt/qt5.15.15/include/QtWidgets/qdesktopwidget.h \
		/opt/qt5.15.15/include/QtGui/qguiapplication.h \
		/opt/qt5.15.15/include/QtGui/qinputmethod.h \
		/opt/qt5.15.15/include/QtCore/QTranslator \
		/opt/qt5.15.15/include/QtCore/qtranslator.h \
		/opt/qt5.15.15/include/QtCore/QStandardPaths \
		/opt/qt5.15.15/include/QtCore/qstandardpaths.h \
		/opt/qt5.15.15/include/QtGui/QtGui \
		/opt/qt5.15.15/include/QtGui/QtGuiDepends \
		/opt/qt5.15.15/include/QtCore/QtCore \
		/opt/qt5.15.15/include/QtCore/QtCoreDepends \
		/opt/qt5.15.15/include/QtCore/qabstractanimation.h \
		/opt/qt5.15.15/include/QtCore/qabstracteventdispatcher.h \
		/opt/qt5.15.15/include/QtCore/qabstractitemmodel.h \
		/opt/qt5.15.15/include/QtCore/qabstractnativeeventfilter.h \
		/opt/qt5.15.15/include/QtCore/qabstractproxymodel.h \
		/opt/qt5.15.15/include/QtCore/qabstractstate.h \
		/opt/qt5.15.15/include/QtCore/qabstracttransition.h \
		/opt/qt5.15.15/include/QtCore/qanimationgroup.h \
		/opt/qt5.15.15/include/QtCore/qarraydataops.h \
		/opt/qt5.15.15/include/QtCore/qarraydatapointer.h \
		/opt/qt5.15.15/include/QtCore/qbasictimer.h \
		/opt/qt5.15.15/include/QtCore/qbitarray.h \
		/opt/qt5.15.15/include/QtCore/qbuffer.h \
		/opt/qt5.15.15/include/QtCore/qbytearraymatcher.h \
		/opt/qt5.15.15/include/QtCore/qcache.h \
		/opt/qt5.15.15/include/QtCore/qcalendar.h \
		/opt/qt5.15.15/include/QtCore/qcborarray.h \
		/opt/qt5.15.15/include/QtCore/qcborvalue.h \
		/opt/qt5.15.15/include/QtCore/qdatetime.h \
		/opt/qt5.15.15/include/QtCore/qcborcommon.h \
		/opt/qt5.15.15/include/QtCore/quuid.h \
		/opt/qt5.15.15/include/QtCore/qcbormap.h \
		/opt/qt5.15.15/include/QtCore/qcborstream.h \
		/opt/qt5.15.15/include/QtCore/qcborstreamreader.h \
		/opt/qt5.15.15/include/QtCore/qfloat16.h \
		/opt/qt5.15.15/include/QtCore/qcborstreamwriter.h \
		/opt/qt5.15.15/include/QtCore/qcollator.h \
		/opt/qt5.15.15/include/QtCore/qcommandlineoption.h \
		/opt/qt5.15.15/include/QtCore/qcommandlineparser.h \
		/opt/qt5.15.15/include/QtCore/qconcatenatetablesproxymodel.h \
		/opt/qt5.15.15/include/QtCore/qcryptographichash.h \
		/opt/qt5.15.15/include/QtCore/qdeadlinetimer.h \
		/opt/qt5.15.15/include/QtCore/qelapsedtimer.h \
		/opt/qt5.15.15/include/QtCore/qdir.h \
		/opt/qt5.15.15/include/QtCore/qfileinfo.h \
		/opt/qt5.15.15/include/QtCore/qdiriterator.h \
		/opt/qt5.15.15/include/QtCore/qeasingcurve.h \
		/opt/qt5.15.15/include/QtCore/qendian.h \
		/opt/qt5.15.15/include/QtCore/qeventtransition.h \
		/opt/qt5.15.15/include/QtCore/qexception.h \
		/opt/qt5.15.15/include/QtCore/qfactoryinterface.h \
		/opt/qt5.15.15/include/QtCore/qfileselector.h \
		/opt/qt5.15.15/include/QtCore/QStringList \
		/opt/qt5.15.15/include/QtCore/qfilesystemwatcher.h \
		/opt/qt5.15.15/include/QtCore/qfinalstate.h \
		/opt/qt5.15.15/include/QtCore/qfuture.h \
		/opt/qt5.15.15/include/QtCore/qfutureinterface.h \
		/opt/qt5.15.15/include/QtCore/qrunnable.h \
		/opt/qt5.15.15/include/QtCore/qresultstore.h \
		/opt/qt5.15.15/include/QtCore/qfuturesynchronizer.h \
		/opt/qt5.15.15/include/QtCore/qfuturewatcher.h \
		/opt/qt5.15.15/include/QtCore/qhistorystate.h \
		/opt/qt5.15.15/include/QtCore/qidentityproxymodel.h \
		/opt/qt5.15.15/include/QtCore/qisenum.h \
		/opt/qt5.15.15/include/QtCore/qitemselectionmodel.h \
		/opt/qt5.15.15/include/QtCore/qjsonarray.h \
		/opt/qt5.15.15/include/QtCore/qjsonvalue.h \
		/opt/qt5.15.15/include/QtCore/qjsondocument.h \
		/opt/qt5.15.15/include/QtCore/qjsonobject.h \
		/opt/qt5.15.15/include/QtCore/qlibrary.h \
		/opt/qt5.15.15/include/QtCore/qlibraryinfo.h \
		/opt/qt5.15.15/include/QtCore/qversionnumber.h \
		/opt/qt5.15.15/include/QtCore/qlinkedlist.h \
		/opt/qt5.15.15/include/QtCore/qlockfile.h \
		/opt/qt5.15.15/include/QtCore/qloggingcategory.h \
		/opt/qt5.15.15/include/QtCore/qmath.h \
		/opt/qt5.15.15/include/QtCore/qmessageauthenticationcode.h \
		/opt/qt5.15.15/include/QtCore/qmetaobject.h \
		/opt/qt5.15.15/include/QtCore/qmimedata.h \
		/opt/qt5.15.15/include/QtCore/qmimedatabase.h \
		/opt/qt5.15.15/include/QtCore/qmimetype.h \
		/opt/qt5.15.15/include/QtCore/qobjectcleanuphandler.h \
		/opt/qt5.15.15/include/QtCore/qoperatingsystemversion.h \
		/opt/qt5.15.15/include/QtCore/qparallelanimationgroup.h \
		/opt/qt5.15.15/include/QtCore/qpauseanimation.h \
		/opt/qt5.15.15/include/QtCore/qplugin.h \
		/opt/qt5.15.15/include/QtCore/qpointer.h \
		/opt/qt5.15.15/include/QtCore/qpluginloader.h \
		/opt/qt5.15.15/include/QtCore/qprocess.h \
		/opt/qt5.15.15/include/QtCore/qpropertyanimation.h \
		/opt/qt5.15.15/include/QtCore/qvariantanimation.h \
		/opt/qt5.15.15/include/QtCore/qqueue.h \
		/opt/qt5.15.15/include/QtCore/qrandom.h \
		/opt/qt5.15.15/include/QtCore/qreadwritelock.h \
		/opt/qt5.15.15/include/QtCore/qresource.h \
		/opt/qt5.15.15/include/QtCore/qsavefile.h \
		/opt/qt5.15.15/include/QtCore/qscopedvaluerollback.h \
		/opt/qt5.15.15/include/QtCore/qscopeguard.h \
		/opt/qt5.15.15/include/QtCore/qsemaphore.h \
		/opt/qt5.15.15/include/QtCore/qsequentialanimationgroup.h \
		/opt/qt5.15.15/include/QtCore/qsettings.h \
		/opt/qt5.15.15/include/QtCore/qsharedmemory.h \
		/opt/qt5.15.15/include/QtCore/qsignalmapper.h \
		/opt/qt5.15.15/include/QtCore/qsignaltransition.h \
		/opt/qt5.15.15/include/QtCore/qsocketnotifier.h \
		/opt/qt5.15.15/include/QtCore/qsortfilterproxymodel.h \
		/opt/qt5.15.15/include/QtCore/qstack.h \
		/opt/qt5.15.15/include/QtCore/qstate.h \
		/opt/qt5.15.15/include/QtCore/qstatemachine.h \
		/opt/qt5.15.15/include/QtCore/qstorageinfo.h \
		/opt/qt5.15.15/include/QtCore/qstringlistmodel.h \
		/opt/qt5.15.15/include/QtCore/qsystemsemaphore.h \
		/opt/qt5.15.15/include/QtCore/qtemporarydir.h \
		/opt/qt5.15.15/include/QtCore/qtemporaryfile.h \
		/opt/qt5.15.15/include/QtCore/qtextboundaryfinder.h \
		/opt/qt5.15.15/include/QtCore/qtextcodec.h \
		/opt/qt5.15.15/include/QtCore/qthread.h \
		/opt/qt5.15.15/include/QtCore/qthreadpool.h \
		/opt/qt5.15.15/include/QtCore/qthreadstorage.h \
		/opt/qt5.15.15/include/QtCore/qtimeline.h \
		/opt/qt5.15.15/include/QtCore/qtimer.h \
		/opt/qt5.15.15/include/QtCore/qtimezone.h \
		/opt/qt5.15.15/include/QtCore/qtransposeproxymodel.h \
		/opt/qt5.15.15/include/QtCore/qtypetraits.h \
		/opt/qt5.15.15/include/QtCore/qwaitcondition.h \
		/opt/qt5.15.15/include/QtCore/QDeadlineTimer \
		/opt/qt5.15.15/include/QtCore/qwineventnotifier.h \
		/opt/qt5.15.15/include/QtCore/qxmlstream.h \
		/opt/qt5.15.15/include/QtCore/qtcoreversion.h \
		/opt/qt5.15.15/include/QtGui/qaccessible.h \
		/opt/qt5.15.15/include/QtGui/qaccessiblebridge.h \
		/opt/qt5.15.15/include/QtGui/qaccessibleobject.h \
		/opt/qt5.15.15/include/QtGui/qaccessibleplugin.h \
		/opt/qt5.15.15/include/QtGui/qbackingstore.h \
		/opt/qt5.15.15/include/QtGui/qwindow.h \
		/opt/qt5.15.15/include/QtCore/QEvent \
		/opt/qt5.15.15/include/QtCore/QMargins \
		/opt/qt5.15.15/include/QtCore/QRect \
		/opt/qt5.15.15/include/QtGui/qsurface.h \
		/opt/qt5.15.15/include/QtGui/qsurfaceformat.h \
		/opt/qt5.15.15/include/QtGui/qbitmap.h \
		/opt/qt5.15.15/include/QtGui/qclipboard.h \
		/opt/qt5.15.15/include/QtGui/qcolorspace.h \
		/opt/qt5.15.15/include/QtGui/qcolortransform.h \
		/opt/qt5.15.15/include/QtGui/qdesktopservices.h \
		/opt/qt5.15.15/include/QtGui/qdrag.h \
		/opt/qt5.15.15/include/QtGui/qgenericmatrix.h \
		/opt/qt5.15.15/include/QtGui/qgenericplugin.h \
		/opt/qt5.15.15/include/QtGui/qgenericpluginfactory.h \
		/opt/qt5.15.15/include/QtGui/qiconengine.h \
		/opt/qt5.15.15/include/QtGui/qiconengineplugin.h \
		/opt/qt5.15.15/include/QtGui/qimageiohandler.h \
		/opt/qt5.15.15/include/QtGui/qimagereader.h \
		/opt/qt5.15.15/include/QtGui/qimagewriter.h \
		/opt/qt5.15.15/include/QtGui/qmatrix4x4.h \
		/opt/qt5.15.15/include/QtGui/qvector3d.h \
		/opt/qt5.15.15/include/QtGui/qvector4d.h \
		/opt/qt5.15.15/include/QtGui/qquaternion.h \
		/opt/qt5.15.15/include/QtGui/qmovie.h \
		/opt/qt5.15.15/include/QtGui/qoffscreensurface.h \
		/opt/qt5.15.15/include/QtGui/qopengl.h \
		/opt/qt5.15.15/include/QtCore/qt_windows.h \
		/opt/qt5.15.15/include/QtGui/qopengles2ext.h \
		/opt/qt5.15.15/include/QtGui/qopenglext.h \
		/opt/qt5.15.15/include/QtGui/qopenglbuffer.h \
		/opt/qt5.15.15/include/QtGui/qopenglcontext.h \
		/opt/qt5.15.15/include/QtCore/QScopedPointer \
		/opt/qt5.15.15/include/QtGui/QSurfaceFormat \
		/opt/qt5.15.15/include/QtGui/qopenglversionfunctions.h \
		/opt/qt5.15.15/include/QtGui/qopengldebug.h \
		/opt/qt5.15.15/include/QtGui/qopenglextrafunctions.h \
		/opt/qt5.15.15/include/QtGui/qopenglfunctions.h \
		/opt/qt5.15.15/include/QtGui/qopenglframebufferobject.h \
		/opt/qt5.15.15/include/QtGui/qopenglpaintdevice.h \
		/opt/qt5.15.15/include/QtGui/qopenglpixeltransferoptions.h \
		/opt/qt5.15.15/include/QtCore/QSharedDataPointer \
		/opt/qt5.15.15/include/QtGui/qopenglshaderprogram.h \
		/opt/qt5.15.15/include/QtGui/qopengltexture.h \
		/opt/qt5.15.15/include/QtGui/qopengltextureblitter.h \
		/opt/qt5.15.15/include/QtGui/QMatrix3x3 \
		/opt/qt5.15.15/include/QtGui/QMatrix4x4 \
		/opt/qt5.15.15/include/QtGui/qopengltimerquery.h \
		/opt/qt5.15.15/include/QtGui/qopenglvertexarrayobject.h \
		/opt/qt5.15.15/include/QtGui/qopenglwindow.h \
		/opt/qt5.15.15/include/QtGui/QPaintDeviceWindow \
		/opt/qt5.15.15/include/QtGui/qpaintdevicewindow.h \
		/opt/qt5.15.15/include/QtGui/QWindow \
		/opt/qt5.15.15/include/QtGui/QPaintDevice \
		/opt/qt5.15.15/include/QtGui/QOpenGLContext \
		/opt/qt5.15.15/include/QtGui/QImage \
		/opt/qt5.15.15/include/QtGui/qpagedpaintdevice.h \
		/opt/qt5.15.15/include/QtGui/qpagelayout.h \
		/opt/qt5.15.15/include/QtGui/qpagesize.h \
		/opt/qt5.15.15/include/QtGui/qpaintengine.h \
		/opt/qt5.15.15/include/QtGui/qpainter.h \
		/opt/qt5.15.15/include/QtGui/qpainterpath.h \
		/opt/qt5.15.15/include/QtGui/qpdfwriter.h \
		/opt/qt5.15.15/include/QtGui/qpicture.h \
		/opt/qt5.15.15/include/QtGui/qpictureformatplugin.h \
		/opt/qt5.15.15/include/QtGui/qpixmapcache.h \
		/opt/qt5.15.15/include/QtGui/qrasterwindow.h \
		/opt/qt5.15.15/include/QtGui/qscreen.h \
		/opt/qt5.15.15/include/QtCore/QList \
		/opt/qt5.15.15/include/QtCore/QSize \
		/opt/qt5.15.15/include/QtCore/QSizeF \
		/opt/qt5.15.15/include/QtGui/QTransform \
		/opt/qt5.15.15/include/QtGui/qsessionmanager.h \
		/opt/qt5.15.15/include/QtGui/qstandarditemmodel.h \
		/opt/qt5.15.15/include/QtGui/qstatictext.h \
		/opt/qt5.15.15/include/QtGui/qstylehints.h \
		/opt/qt5.15.15/include/QtGui/qtextdocumentfragment.h \
		/opt/qt5.15.15/include/QtGui/qtextdocumentwriter.h \
		/opt/qt5.15.15/include/QtGui/qtextlist.h \
		/opt/qt5.15.15/include/QtGui/qtexttable.h \
		/opt/qt5.15.15/include/QtGui/qtguiversion.h \
		../src/mainwindow.h \
		/opt/qt5.15.15/include/QtWidgets/QMainWindow \
		/opt/qt5.15.15/include/QtWidgets/qmainwindow.h \
		/opt/qt5.15.15/include/QtWidgets/qtabwidget.h \
		/opt/qt5.15.15/include/QtCore/QDir \
		../src/gui/circuitwidget/circuitwidget.h \
		/opt/qt5.15.15/include/QtWidgets/QMenu \
		/opt/qt5.15.15/include/QtWidgets/qmenu.h \
		/opt/qt5.15.15/include/QtWidgets/qaction.h \
		/opt/qt5.15.15/include/QtWidgets/qactiongroup.h \
		/opt/qt5.15.15/include/QtWidgets/QToolBar \
		/opt/qt5.15.15/include/QtWidgets/qtoolbar.h \
		/opt/qt5.15.15/include/QtWidgets/QVBoxLayout \
		/opt/qt5.15.15/include/QtWidgets/qboxlayout.h \
		/opt/qt5.15.15/include/QtWidgets/qlayout.h \
		/opt/qt5.15.15/include/QtWidgets/qlayoutitem.h \
		/opt/qt5.15.15/include/QtWidgets/qgridlayout.h \
		../src/gui/circuitwidget/circuitview.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsView \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsview.h \
		/opt/qt5.15.15/include/QtWidgets/qscrollarea.h \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsscene.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/main.o ../src/main.cpp
build/objects/mainwindow.o: ../src/mainwindow.cpp /opt/qt5.15.15/include/QtWidgets/QApplication \
		/opt/qt5.15.15/include/QtWidgets/qtwidgetsglobal.h \
		/opt/qt5.15.15/include/QtGui/qtguiglobal.h \
		/opt/qt5.15.15/include/QtCore/qglobal.h \
		/opt/qt5.15.15/include/QtCore/qconfig-bootstrapped.h \
		/opt/qt5.15.15/include/QtCore/qconfig.h \
		/opt/qt5.15.15/include/QtCore/qtcore-config.h \
		/opt/qt5.15.15/include/QtCore/qsystemdetection.h \
		/opt/qt5.15.15/include/QtCore/qprocessordetection.h \
		/opt/qt5.15.15/include/QtCore/qcompilerdetection.h \
		/opt/qt5.15.15/include/QtCore/qtypeinfo.h \
		/opt/qt5.15.15/include/QtCore/qsysinfo.h \
		/opt/qt5.15.15/include/QtCore/qlogging.h \
		/opt/qt5.15.15/include/QtCore/qflags.h \
		/opt/qt5.15.15/include/QtCore/qatomic.h \
		/opt/qt5.15.15/include/QtCore/qbasicatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_bootstrap.h \
		/opt/qt5.15.15/include/QtCore/qgenericatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_cxx11.h \
		/opt/qt5.15.15/include/QtCore/qatomic_msvc.h \
		/opt/qt5.15.15/include/QtCore/qglobalstatic.h \
		/opt/qt5.15.15/include/QtCore/qmutex.h \
		/opt/qt5.15.15/include/QtCore/qnumeric.h \
		/opt/qt5.15.15/include/QtCore/qversiontagging.h \
		/opt/qt5.15.15/include/QtGui/qtgui-config.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgets-config.h \
		/opt/qt5.15.15/include/QtCore/qstring.h \
		/opt/qt5.15.15/include/QtCore/qchar.h \
		/opt/qt5.15.15/include/QtCore/qbytearray.h \
		/opt/qt5.15.15/include/QtCore/qrefcount.h \
		/opt/qt5.15.15/include/QtCore/qnamespace.h \
		/opt/qt5.15.15/include/QtCore/qarraydata.h \
		/opt/qt5.15.15/include/QtCore/qstringliteral.h \
		/opt/qt5.15.15/include/QtCore/qstringalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qstringview.h \
		/opt/qt5.15.15/include/QtCore/qstringbuilder.h \
		/opt/qt5.15.15/include/QtCore/qobject.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs_impl.h \
		/opt/qt5.15.15/include/QtCore/qlist.h \
		/opt/qt5.15.15/include/QtCore/qalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qiterator.h \
		/opt/qt5.15.15/include/QtCore/qhashfunctions.h \
		/opt/qt5.15.15/include/QtCore/qpair.h \
		/opt/qt5.15.15/include/QtCore/qvector.h \
		/opt/qt5.15.15/include/QtCore/qcontainertools_impl.h \
		/opt/qt5.15.15/include/QtCore/qpoint.h \
		/opt/qt5.15.15/include/QtCore/qbytearraylist.h \
		/opt/qt5.15.15/include/QtCore/qstringlist.h \
		/opt/qt5.15.15/include/QtCore/qregexp.h \
		/opt/qt5.15.15/include/QtCore/qstringmatcher.h \
		/opt/qt5.15.15/include/QtCore/qcoreevent.h \
		/opt/qt5.15.15/include/QtCore/qscopedpointer.h \
		/opt/qt5.15.15/include/QtCore/qmetatype.h \
		/opt/qt5.15.15/include/QtCore/qvarlengtharray.h \
		/opt/qt5.15.15/include/QtCore/qcontainerfwd.h \
		/opt/qt5.15.15/include/QtCore/qobject_impl.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs_win.h \
		/opt/qt5.15.15/include/QtCore/qsize.h \
		/opt/qt5.15.15/include/QtCore/qmargins.h \
		/opt/qt5.15.15/include/QtGui/qcursor.h \
		/opt/qt5.15.15/include/QtWidgets/qwidget.h \
		/opt/qt5.15.15/include/QtGui/qpaintdevice.h \
		/opt/qt5.15.15/include/QtCore/qrect.h \
		/opt/qt5.15.15/include/QtGui/qpalette.h \
		/opt/qt5.15.15/include/QtGui/qcolor.h \
		/opt/qt5.15.15/include/QtGui/qrgb.h \
		/opt/qt5.15.15/include/QtGui/qrgba64.h \
		/opt/qt5.15.15/include/QtGui/qbrush.h \
		/opt/qt5.15.15/include/QtGui/qmatrix.h \
		/opt/qt5.15.15/include/QtGui/qpolygon.h \
		/opt/qt5.15.15/include/QtGui/qregion.h \
		/opt/qt5.15.15/include/QtCore/qdatastream.h \
		/opt/qt5.15.15/include/QtCore/qiodevice.h \
		/opt/qt5.15.15/include/QtCore/qline.h \
		/opt/qt5.15.15/include/QtGui/qtransform.h \
		/opt/qt5.15.15/include/QtGui/qimage.h \
		/opt/qt5.15.15/include/QtGui/qpixelformat.h \
		/opt/qt5.15.15/include/QtGui/qpixmap.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer.h \
		/opt/qt5.15.15/include/QtCore/qshareddata.h \
		/opt/qt5.15.15/include/QtCore/qhash.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer_impl.h \
		/opt/qt5.15.15/include/QtGui/qfont.h \
		/opt/qt5.15.15/include/QtGui/qfontmetrics.h \
		/opt/qt5.15.15/include/QtGui/qfontinfo.h \
		/opt/qt5.15.15/include/QtWidgets/qsizepolicy.h \
		/opt/qt5.15.15/include/QtGui/qkeysequence.h \
		/opt/qt5.15.15/include/QtGui/qevent.h \
		/opt/qt5.15.15/include/QtCore/qvariant.h \
		/opt/qt5.15.15/include/QtCore/qmap.h \
		/opt/qt5.15.15/include/QtCore/qdebug.h \
		/opt/qt5.15.15/include/QtCore/qtextstream.h \
		/opt/qt5.15.15/include/QtCore/qlocale.h \
		/opt/qt5.15.15/include/QtCore/qset.h \
		/opt/qt5.15.15/include/QtCore/qcontiguouscache.h \
		/opt/qt5.15.15/include/QtCore/qurl.h \
		/opt/qt5.15.15/include/QtCore/qurlquery.h \
		/opt/qt5.15.15/include/QtCore/qfile.h \
		/opt/qt5.15.15/include/QtCore/qfiledevice.h \
		/opt/qt5.15.15/include/QtGui/qvector2d.h \
		/opt/qt5.15.15/include/QtGui/qtouchdevice.h \
		/opt/qt5.15.15/include/QtWidgets/QFileDialog \
		/opt/qt5.15.15/include/QtWidgets/qfiledialog.h \
		/opt/qt5.15.15/include/QtCore/QSettings \
		/opt/qt5.15.15/include/QtWidgets/QDesktopWidget \
		/opt/qt5.15.15/include/QtWidgets/QMessageBox \
		/opt/qt5.15.15/include/QtWidgets/qmessagebox.h \
		/opt/qt5.15.15/include/QtWidgets/QSplitter \
		/opt/qt5.15.15/include/QtWidgets/qsplitter.h \
		/opt/qt5.15.15/include/QtWidgets/QLineEdit \
		/opt/qt5.15.15/include/QtWidgets/qlineedit.h \
		/opt/qt5.15.15/include/QtWidgets/QPushButton \
		/opt/qt5.15.15/include/QtWidgets/qpushbutton.h \
		/opt/qt5.15.15/include/QtCore/QTextStream \
		/opt/qt5.15.15/include/QtCore/QDebug \
		/opt/qt5.15.15/include/QtWidgets/QStyleFactory \
		/opt/qt5.15.15/include/QtWidgets/qstylefactory.h \
		/opt/qt5.15.15/include/QtCore/QProcessEnvironment \
		../src/gui/circuitwidget/circuit.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsScene \
		/opt/qt5.15.15/include/QtCore/QTimer \
		../src/components/component.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsItem \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsitem.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsSceneMouseEvent \
		/opt/qt5.15.15/include/QtWidgets/qgraphicssceneevent.h \
		../src/gui/circuitwidget/compbase.h \
		/opt/qt5.15.15/include/QtCore/QString \
		/opt/qt5.15.15/include/QtCore/QPointF \
		/opt/qt5.15.15/include/QtCore/QMap \
		/opt/qt5.15.15/include/QtCore/QCoreApplication \
		../src/gui/properties/proputils.h \
		/opt/qt5.15.15/include/QtCore/QStringRef \
		../src/gui/circuitwidget/connector.h \
		../src/gui/circuitwidget/pin.h \
		../src/simulator/e-pin.h \
		../src/simulator/e-node.h \
		/opt/qt5.15.15/include/QtCore/QHash \
		../src/gui/componentlist/componentlist.h \
		/opt/qt5.15.15/include/QtGui/QDropEvent \
		/opt/qt5.15.15/include/QtWidgets/QTreeWidget \
		/opt/qt5.15.15/include/QtWidgets/qtreewidget.h \
		/opt/qt5.15.15/include/QtWidgets/qtreeview.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractitemview.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractitemdelegate.h \
		/opt/qt5.15.15/include/QtWidgets/qstyleoption.h \
		/opt/qt5.15.15/include/QtWidgets/qslider.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractslider.h \
		/opt/qt5.15.15/include/QtWidgets/qstyle.h \
		/opt/qt5.15.15/include/QtWidgets/qtabbar.h \
		/opt/qt5.15.15/include/QtWidgets/qrubberband.h \
		/opt/qt5.15.15/include/QtWidgets/qtreewidgetitemiterator.h \
		../src/gui/componentlist/managecomps.h \
		ui_managecomps.h \
		../src/gui/componentlist/itemlibrary.h \
		../src/gui/editorwidget/editorwindow.h \
		../src/gui/editorwidget/editorwidget.h \
		../src/gui/editorwidget/codeeditor.h \
		../src/gui/editorwidget/basedebugger.h \
		../src/gui/editorwidget/compiler.h \
		/opt/qt5.15.15/include/QtCore/QProcess \
		../src/gui/filebrowser/filewidget.h \
		../src/gui/filebrowser/filebrowser.h \
		/opt/qt5.15.15/include/QtWidgets/QTreeView \
		../src/utils.h \
		/opt/qt5.15.15/include/QtCore/QtMath \
		build/moc/moc_mainwindow.cpp
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mainwindow.o ../src/mainwindow.cpp
build/objects/utils.o: ../src/utils.cpp /opt/qt5.15.15/include/QtXml/QDomDocument \
		/opt/qt5.15.15/include/QtXml/qdom.h \
		/opt/qt5.15.15/include/QtXml/qtxmlglobal.h \
		/opt/qt5.15.15/include/QtXml/qtxml-config.h \
		/opt/qt5.15.15/include/QtCore/QFile \
		/opt/qt5.15.15/include/QtCore/QFileInfo \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/utils.o ../src/utils.cpp
build/objects/comp2pin.o: ../src/components/comp2pin.cpp ../src/components/comp2pin.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/comp2pin.o ../src/components/comp2pin.cpp
build/objects/component.o: ../src/components/component.cpp /opt/qt5.15.15/include/QtCore/QDebug \
		../src/gui/circuitwidget/label.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsTextItem \
		../src/gui/circuitwidget/connectorline.h \
		../src/utils.h \
		ui_propdialog.h \
		../src/components/linker.h \
		/opt/qt5.15.15/include/QtCore/QSet \
		/opt/qt5.15.15/include/QtGui/QCursor \
		../src/gui/properties/doubleprop.h \
		../src/gui/properties/numprop.h \
		../src/gui/properties/comproperty.h \
		../src/gui/properties/boolprop.h \
		../src/gui/properties/intprop.h \
		../src/gui/properties/stringprop.h \
		../src/gui/properties/pointprop.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/component.o ../src/components/component.cpp
build/objects/iocomponent.o: ../src/components/iocomponent.cpp ../src/components/iocomponent.h \
		../src/components/logicfamily.h \
		ui_propdialog.h \
		../src/simulator/simulator.h \
		../src/simulator/e-element.h \
		/opt/qt5.15.15/include/QtCore/QElapsedTimer \
		/opt/qt5.15.15/include/QtCore/QFuture \
		../src/gui/circuitwidget/iopin.h \
		/opt/qt5.15.15/include/QtGui/QColor \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/iocomponent.o ../src/components/iocomponent.cpp
build/objects/linker.o: ../src/components/linker.cpp /opt/qt5.15.15/include/QtGui/QGuiApplication \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/linker.o ../src/components/linker.cpp
build/objects/linkercomponent.o: ../src/components/linkercomponent.cpp /opt/qt5.15.15/include/QtWidgets/QMenu \
		../src/components/linkercomponent.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/linkercomponent.o ../src/components/linkercomponent.cpp
build/objects/logiccomponent.o: ../src/components/logiccomponent.cpp ../src/components/logiccomponent.h \
		../src/simulator/elements/e-clocked_device.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/logiccomponent.o ../src/components/logiccomponent.cpp
build/objects/logicfamily.o: ../src/components/logicfamily.cpp ../src/components/logicfamily.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/logicfamily.o ../src/components/logicfamily.cpp
build/objects/node.o: ../src/components/node.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/node.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/node.o ../src/components/node.cpp
build/objects/custombutton.o: ../src/gui/custombutton.cpp ../src/gui/custombutton.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/custombutton.o ../src/gui/custombutton.cpp
build/objects/customdial.o: ../src/gui/customdial.cpp ../src/gui/customdial.h \
		/opt/qt5.15.15/include/QtWidgets/QDial \
		/opt/qt5.15.15/include/QtWidgets/qdial.h \
		/opt/qt5.15.15/include/QtGui/QPalette \
		/opt/qt5.15.15/include/QtWidgets/QStyleOptionSlider \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/customdial.o ../src/gui/customdial.cpp
build/objects/customslider.o: ../src/gui/customslider.cpp ../src/gui/customslider.h \
		/opt/qt5.15.15/include/QtWidgets/QSlider \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/customslider.o ../src/gui/customslider.cpp
build/objects/dialwidget.o: ../src/gui/dialwidget.cpp /opt/qt5.15.15/include/QtWidgets/QDial \
		../src/gui/dialwidget.h \
		build/moc/moc_dialwidget.cpp
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/dialwidget.o ../src/gui/dialwidget.cpp
build/objects/joystickwidget.o: ../src/gui/joystickwidget.cpp /opt/qt5.15.15/include/QtCore/QVariant \
		/opt/qt5.15.15/include/QtGui/QMouseEvent \
		../src/gui/joystickwidget.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/joystickwidget.o ../src/gui/joystickwidget.cpp
build/objects/outpaneltext.o: ../src/gui/outpaneltext.cpp ../src/gui/outpaneltext.h \
		build/moc/moc_outpaneltext.cpp
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/outpaneltext.o ../src/gui/outpaneltext.cpp
build/objects/sourcewidget.o: ../src/gui/sourcewidget.cpp /opt/qt5.15.15/include/QtWidgets/QVBoxLayout \
		../src/gui/sourcewidget.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/sourcewidget.o ../src/gui/sourcewidget.cpp
build/objects/datautils.o: ../src/microsim/datautils.cpp ../src/microsim/datautils.h \
		../src/microsim/mcutypes.h \
		../src/microsim/mcusignal.h \
		../src/microsim/mcudataspace.h \
		../src/gui/memory/ramtable.h \
		ui_ramtable.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/datautils.o ../src/microsim/datautils.cpp
build/objects/e_iou.o: ../src/microsim/e_iou.cpp ../src/microsim/e_iou.h \
		../src/microsim/cores/cpubase.h \
		../src/microsim/e_mcu.h \
		../src/microsim/mcutimer.h \
		../src/microsim/mcuprescaled.h \
		../src/microsim/mcumodule.h \
		../src/microsim/mcuuart.h \
		../src/microsim/modules/usart/usartmodule.h \
		../src/microsim/mcuinterrupts.h \
		ui_ramtable.h \
		../src/microsim/mcusleep.h \
		../src/microsim/cores/corebase.h \
		../src/gui/circuitwidget/ioport.h \
		../src/angel/src/scriptarray.h \
		../src/angel/include/angelscript.h \
		../src/gui/memory/watcher.h \
		ui_watcher.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/e_iou.o ../src/microsim/e_iou.cpp
build/objects/e_mcu.o: ../src/microsim/e_mcu.cpp ../src/microsim/e_mcu.h \
		ui_ramtable.h \
		../src/microsim/mcu.h \
		../src/components/subcircuits/chip.h \
		../src/microsim/mcuconfigword.h \
		../src/microsim/mcuport.h \
		../src/microsim/mcupin.h \
		../src/microsim/mcuwdt.h \
		../src/microsim/modules/usart/usartrx.h \
		../src/microsim/mcuvref.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/e_mcu.o ../src/microsim/e_mcu.cpp
build/objects/mcu.o: ../src/microsim/mcu.cpp /opt/qt5.15.15/include/QtXml/QDomDocument \
		/opt/qt5.15.15/include/QtCore/QSignalMapper \
		/opt/qt5.15.15/include/QtWidgets/qdialog.h \
		ui_ramtable.h \
		../src/microsim/mcucreator.h \
		../src/microsim/cores/scripted/scriptcpu.h \
		../src/microsim/modules/script/scriptbase.h \
		../src/angel/JIT/as_jit.h \
		../src/microsim/cores/mcucpu.h \
		../src/gui/appdialogs/infowidget.h \
		ui_infowidget.h \
		/opt/qt5.15.15/include/QtWidgets/QDialog \
		ui_managecomps.h \
		../src/gui/memory/mcumonitor.h \
		/opt/qt5.15.15/include/QtWidgets/QTableWidget \
		/opt/qt5.15.15/include/QtWidgets/qtablewidget.h \
		/opt/qt5.15.15/include/QtWidgets/qtableview.h \
		ui_mcumonitor.h \
		../src/gui/memory/memdata.h \
		/opt/qt5.15.15/include/QtCore/QVector \
		../src/microsim/mcuintosc.h \
		../src/utils.h \
		ui_watcher.h \
		../src/gui/properties/propdialog.h \
		ui_propdialog.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcu.o ../src/microsim/mcu.cpp
build/objects/mcuadc.o: ../src/microsim/mcuadc.cpp ../src/microsim/mcuadc.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuadc.o ../src/microsim/mcuadc.cpp
build/objects/mcucomparator.o: ../src/microsim/mcucomparator.cpp ../src/microsim/mcucomparator.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcucomparator.o ../src/microsim/mcucomparator.cpp
build/objects/mcuconfigword.o: ../src/microsim/mcuconfigword.cpp /opt/qt5.15.15/include/QtCore/QDebug \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuconfigword.o ../src/microsim/mcuconfigword.cpp
build/objects/mcucreator.o: ../src/microsim/mcucreator.cpp /opt/qt5.15.15/include/QtXml/QDomDocument \
		../src/microsim/regwatcher.h \
		ui_ramtable.h \
		../src/microsim/modules/usart/usarttx.h \
		ui_watcher.h \
		../src/gui/serial/console.h \
		../src/microsim/cores/avr/avrcore.h \
		../src/microsim/cores/avr/avrport.h \
		../src/microsim/cores/avr/avrtimer.h \
		../src/microsim/cores/avr/avrocunit.h \
		../src/microsim/mcuocunit.h \
		../src/microsim/cores/avr/avrocm.h \
		../src/microsim/mcuocm.h \
		../src/microsim/cores/avr/avricunit.h \
		../src/microsim/mcuicunit.h \
		../src/microsim/cores/avr/avrinterrupt.h \
		../src/microsim/cores/avr/avrusart.h \
		../src/microsim/cores/avr/avradc.h \
		../src/microsim/cores/avr/avrtwi.h \
		../src/microsim/mcutwi.h \
		../src/microsim/modules/twi/twimodule.h \
		../src/microsim/cores/avr/avrtwicodes.h \
		../src/microsim/cores/avr/avrspi.h \
		../src/microsim/mcuspi.h \
		../src/microsim/modules/spi/spimodule.h \
		../src/microsim/cores/avr/avrusi.h \
		../src/microsim/cores/avr/avrwdt.h \
		../src/microsim/cores/avr/avreeprom.h \
		../src/microsim/mcueeprom.h \
		../src/microsim/cores/avr/avrcomparator.h \
		../src/microsim/cores/avr/avrsleep.h \
		../src/microsim/cores/avr/avrintosc.h \
		../src/microsim/cores/pic/pic14core.h \
		../src/microsim/cores/pic/picmrcore.h \
		../src/microsim/cores/pic/pic14ecore.h \
		../src/microsim/cores/pic/picport.h \
		../src/microsim/cores/pic/pictimer.h \
		../src/microsim/cores/pic/picccpunit.h \
		../src/microsim/cores/pic/picicunit.h \
		../src/microsim/cores/pic/picinterrupt.h \
		../src/microsim/cores/pic/pic14einterrupt.h \
		../src/microsim/cores/pic/picusart.h \
		../src/microsim/cores/pic/picmssp.h \
		../src/microsim/cores/pic/pictwi.h \
		../src/microsim/cores/pic/picspi.h \
		../src/microsim/cores/pic/picadc.h \
		../src/microsim/cores/pic/picdac.h \
		../src/microsim/mcudac.h \
		../src/microsim/cores/pic/piccomparator.h \
		../src/microsim/cores/pic/picvref.h \
		../src/microsim/cores/pic/picwdt.h \
		../src/microsim/cores/pic/piceeprom.h \
		../src/microsim/cores/pic/picconfigword.h \
		../src/microsim/cores/pic/picintosc.h \
		../src/microsim/cores/pic/picsleep.h \
		../src/microsim/cores/i51/i51core.h \
		../src/microsim/cores/i51/i51timer.h \
		../src/microsim/cores/i51/i51usart.h \
		../src/microsim/cores/i51/i51port.h \
		../src/microsim/cores/mcs65/mcs65core.h \
		../src/microsim/cores/mcs65/mcs65interface.h \
		../src/microsim/cores/intmem/intmemcore.h \
		../src/microsim/cores/z80/z80core.h \
		../src/microsim/cores/z80/z80regs.h \
		../src/microsim/cores/z80/ula_zx48k.h \
		../src/microsim/cores/scripted/scriptport.h \
		../src/microsim/cores/scripted/scriptusart.h \
		../src/microsim/cores/scripted/scriptperif.h \
		../src/microsim/cores/scripted/scriptspi.h \
		../src/microsim/cores/scripted/scripttwi.h \
		../src/microsim/cores/scripted/scripttcp.h \
		../src/microsim/modules/tcp/tcpmodule.h \
		../src/gui/properties/scriptprop.h \
		../src/microsim/cores/scripted/scriptdisplay.h \
		../src/microsim/cores/scripted/display.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcucreator.o ../src/microsim/mcucreator.cpp
build/objects/mcudac.o: ../src/microsim/mcudac.cpp ../src/microsim/mcudac.h \
		/opt/qt5.15.15/include/QtWidgets/QWidget \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcudac.o ../src/microsim/mcudac.cpp
build/objects/mcudataspace.o: ../src/microsim/mcudataspace.cpp /opt/qt5.15.15/include/QtCore/QDebug \
		ui_ramtable.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcudataspace.o ../src/microsim/mcudataspace.cpp
build/objects/mcueeprom.o: ../src/microsim/mcueeprom.cpp ../src/microsim/mcueeprom.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcueeprom.o ../src/microsim/mcueeprom.cpp
build/objects/mcuicunit.o: ../src/microsim/mcuicunit.cpp ../src/microsim/mcuicunit.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuicunit.o ../src/microsim/mcuicunit.cpp
build/objects/mcuinterrupts.o: ../src/microsim/mcuinterrupts.cpp /opt/qt5.15.15/include/QtCore/QDebug \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuinterrupts.o ../src/microsim/mcuinterrupts.cpp
build/objects/mcuintosc.o: ../src/microsim/mcuintosc.cpp ../src/microsim/mcuintosc.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuintosc.o ../src/microsim/mcuintosc.cpp
build/objects/mcumodule.o: ../src/microsim/mcumodule.cpp ../src/microsim/mcumodule.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcumodule.o ../src/microsim/mcumodule.cpp
build/objects/mcuocm.o: ../src/microsim/mcuocm.cpp ../src/microsim/mcuocm.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuocm.o ../src/microsim/mcuocm.cpp
build/objects/mcuocunit.o: ../src/microsim/mcuocunit.cpp ../src/microsim/mcuocunit.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuocunit.o ../src/microsim/mcuocunit.cpp
build/objects/mcupin.o: ../src/microsim/mcupin.cpp ../src/microsim/mcupin.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcupin.o ../src/microsim/mcupin.cpp
build/objects/mcuport.o: ../src/microsim/mcuport.cpp /opt/qt5.15.15/include/QtCore/QDebug \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuport.o ../src/microsim/mcuport.cpp
build/objects/mcuprescaled.o: ../src/microsim/mcuprescaled.cpp ../src/microsim/mcuprescaled.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuprescaled.o ../src/microsim/mcuprescaled.cpp
build/objects/mcusleep.o: ../src/microsim/mcusleep.cpp /opt/qt5.15.15/include/QtCore/QDebug \
		ui_ramtable.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcusleep.o ../src/microsim/mcusleep.cpp
build/objects/mcuspi.o: ../src/microsim/mcuspi.cpp ../src/microsim/mcuspi.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuspi.o ../src/microsim/mcuspi.cpp
build/objects/mcutimer.o: ../src/microsim/mcutimer.cpp ../src/microsim/mcutimer.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcutimer.o ../src/microsim/mcutimer.cpp
build/objects/mcutwi.o: ../src/microsim/mcutwi.cpp ../src/microsim/mcutwi.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcutwi.o ../src/microsim/mcutwi.cpp
build/objects/mcuuart.o: ../src/microsim/mcuuart.cpp ../src/microsim/mcuuart.h \
		ui_serialmon.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuuart.o ../src/microsim/mcuuart.cpp
build/objects/mcuvref.o: ../src/microsim/mcuvref.cpp ../src/microsim/mcuvref.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuvref.o ../src/microsim/mcuvref.cpp
build/objects/mcuwdt.o: ../src/microsim/mcuwdt.cpp ../src/microsim/mcuwdt.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mcuwdt.o ../src/microsim/mcuwdt.cpp
build/objects/circmatrix.o: ../src/simulator/circmatrix.cpp /opt/qt5.15.15/include/QtCore/QtMath \
		../src/simulator/circmatrix.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/circmatrix.o ../src/simulator/circmatrix.cpp
build/objects/e-element.o: ../src/simulator/e-element.cpp ../src/simulator/e-element.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/e-element.o ../src/simulator/e-element.cpp
build/objects/e-node.o: ../src/simulator/e-node.cpp ../src/simulator/e-node.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/e-node.o ../src/simulator/e-node.cpp
build/objects/e-pin.o: ../src/simulator/e-pin.cpp ../src/simulator/e-pin.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/e-pin.o ../src/simulator/e-pin.cpp
build/objects/simulator.o: ../src/simulator/simulator.cpp /opt/qt5.15.15/include/QtConcurrent/qtconcurrentrun.h \
		/opt/qt5.15.15/include/QtConcurrent/qtconcurrentcompilertest.h \
		/opt/qt5.15.15/include/QtConcurrent/qtconcurrent_global.h \
		/opt/qt5.15.15/include/QtConcurrent/qtconcurrentrunbase.h \
		/opt/qt5.15.15/include/QtConcurrent/qtconcurrentstoredfunctioncall.h \
		ui_infowidget.h \
		../src/components/connectors/socket.h \
		../src/gui/circuitwidget/connbase.h \
		build/moc/moc_simulator.cpp
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/simulator.o ../src/simulator/simulator.cpp
build/objects/as_jit.o: ../src/angel/JIT/as_jit.cpp ../src/angel/JIT/as_jit.h \
		../src/angel/src/as_scriptfunction.h \
		../src/angel/src/as_config.h \
		../src/angel/src/as_memory.h \
		../src/angel/src/as_criticalsection.h \
		../src/angel/src/as_array.h \
		../src/components/logic/memory.h \
		../src/angel/src/as_string.h \
		../src/angel/src/as_datatype.h \
		../src/angel/src/as_tokendef.h \
		../src/angel/src/as_atomic.h \
		../src/angel/src/as_objecttype.h \
		../src/angel/src/as_property.h \
		../src/angel/src/as_symboltable.h \
		../src/angel/src/as_map.h \
		../src/angel/src/as_namespace.h \
		../src/angel/src/as_typeinfo.h \
		../src/angel/src/as_callfunc.h \
		../src/angel/src/as_scriptengine.h \
		../src/angel/src/as_module.h \
		../src/angel/src/as_configgroup.h \
		../src/angel/src/as_gc.h \
		../src/angel/src/as_thread.h \
		../src/angel/src/as_tokenizer.h \
		../src/angel/src/as_scriptobject.h \
		../src/angel/src/as_texts.h \
		../src/angel/src/as_context.h \
		../src/angel/JIT/virtual_asm.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_jit.o ../src/angel/JIT/as_jit.cpp
build/objects/virtual_asm_linux.o: ../src/angel/JIT/virtual_asm_linux.cpp /opt/qt5.15.15/include/QtCore/QtGlobal \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/virtual_asm_linux.o ../src/angel/JIT/virtual_asm_linux.cpp
build/objects/virtual_asm_windows.o: ../src/angel/JIT/virtual_asm_windows.cpp /opt/qt5.15.15/include/QtCore/QtGlobal \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/virtual_asm_windows.o ../src/angel/JIT/virtual_asm_windows.cpp
build/objects/virtual_asm_x64.o: ../src/angel/JIT/virtual_asm_x64.cpp /opt/qt5.15.15/include/QtCore/QtGlobal \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/virtual_asm_x64.o ../src/angel/JIT/virtual_asm_x64.cpp
build/objects/as_atomic.o: ../src/angel/src/as_atomic.cpp ../src/angel/src/as_atomic.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_atomic.o ../src/angel/src/as_atomic.cpp
build/objects/as_builder.o: ../src/angel/src/as_builder.cpp ../src/angel/src/as_config.h \
		../src/angel/src/as_builder.h \
		../src/angel/src/as_scriptcode.h \
		../src/angel/src/as_scriptnode.h \
		../src/angel/src/as_parser.h \
		../src/angel/src/as_compiler.h \
		../src/angel/src/as_variablescope.h \
		../src/angel/src/as_bytecode.h \
		../src/angel/src/as_string_util.h \
		../src/angel/src/as_outputbuffer.h \
		../src/angel/src/as_debug.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_builder.o ../src/angel/src/as_builder.cpp
build/objects/as_bytecode.o: ../src/angel/src/as_bytecode.cpp ../src/angel/src/as_config.h \
		../src/angel/src/as_debug.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_bytecode.o ../src/angel/src/as_bytecode.cpp
build/objects/as_callfunc.o: ../src/angel/src/as_callfunc.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_callfunc.o ../src/angel/src/as_callfunc.cpp
build/objects/as_callfunc_arm64.o: ../src/angel/src/as_callfunc_arm64.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_callfunc_arm64.o ../src/angel/src/as_callfunc_arm64.cpp
build/objects/as_callfunc_x64_gcc.o: ../src/angel/src/as_callfunc_x64_gcc.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_callfunc_x64_gcc.o ../src/angel/src/as_callfunc_x64_gcc.cpp
build/objects/as_callfunc_x64_mingw.o: ../src/angel/src/as_callfunc_x64_mingw.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_callfunc_x64_mingw.o ../src/angel/src/as_callfunc_x64_mingw.cpp
build/objects/as_callfunc_x86.o: ../src/angel/src/as_callfunc_x86.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_callfunc_x86.o ../src/angel/src/as_callfunc_x86.cpp
build/objects/as_compiler.o: ../src/angel/src/as_compiler.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_compiler.o ../src/angel/src/as_compiler.cpp
build/objects/as_configgroup.o: ../src/angel/src/as_configgroup.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_configgroup.o ../src/angel/src/as_configgroup.cpp
build/objects/as_context.o: ../src/angel/src/as_context.cpp ../src/angel/src/as_config.h \
		../src/angel/src/as_generic.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_context.o ../src/angel/src/as_context.cpp
build/objects/as_datatype.o: ../src/angel/src/as_datatype.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_datatype.o ../src/angel/src/as_datatype.cpp
build/objects/as_gc.o: ../src/angel/src/as_gc.cpp ../src/angel/src/as_gc.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_gc.o ../src/angel/src/as_gc.cpp
build/objects/as_generic.o: ../src/angel/src/as_generic.cpp ../src/angel/src/as_generic.h \
		../src/gui/circuitwidget/updatable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_generic.o ../src/angel/src/as_generic.cpp
build/objects/as_globalproperty.o: ../src/angel/src/as_globalproperty.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_globalproperty.o ../src/angel/src/as_globalproperty.cpp
build/objects/as_memory.o: ../src/angel/src/as_memory.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_memory.o ../src/angel/src/as_memory.cpp
build/objects/as_module.o: ../src/angel/src/as_module.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_module.o ../src/angel/src/as_module.cpp
build/objects/as_objecttype.o: ../src/angel/src/as_objecttype.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_objecttype.o ../src/angel/src/as_objecttype.cpp
build/objects/as_outputbuffer.o: ../src/angel/src/as_outputbuffer.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_outputbuffer.o ../src/angel/src/as_outputbuffer.cpp
build/objects/as_parser.o: ../src/angel/src/as_parser.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_parser.o ../src/angel/src/as_parser.cpp
build/objects/as_scriptcode.o: ../src/angel/src/as_scriptcode.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_scriptcode.o ../src/angel/src/as_scriptcode.cpp
build/objects/as_scriptengine.o: ../src/angel/src/as_scriptengine.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_scriptengine.o ../src/angel/src/as_scriptengine.cpp
build/objects/as_scriptfunction.o: ../src/angel/src/as_scriptfunction.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_scriptfunction.o ../src/angel/src/as_scriptfunction.cpp
build/objects/as_scriptnode.o: ../src/angel/src/as_scriptnode.cpp ../src/angel/src/as_scriptnode.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_scriptnode.o ../src/angel/src/as_scriptnode.cpp
build/objects/as_scriptobject.o: ../src/angel/src/as_scriptobject.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_scriptobject.o ../src/angel/src/as_scriptobject.cpp
build/objects/as_string.o: ../src/angel/src/as_string.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_string.o ../src/angel/src/as_string.cpp
build/objects/as_string_util.o: ../src/angel/src/as_string_util.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_string_util.o ../src/angel/src/as_string_util.cpp
build/objects/as_thread.o: ../src/angel/src/as_thread.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_thread.o ../src/angel/src/as_thread.cpp
build/objects/as_tokenizer.o: ../src/angel/src/as_tokenizer.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_tokenizer.o ../src/angel/src/as_tokenizer.cpp
build/objects/as_typeinfo.o: ../src/angel/src/as_typeinfo.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_typeinfo.o ../src/angel/src/as_typeinfo.cpp
build/objects/as_variablescope.o: ../src/angel/src/as_variablescope.cpp ../src/angel/src/as_config.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/as_variablescope.o ../src/angel/src/as_variablescope.cpp
build/objects/scriptarray.o: ../src/angel/src/scriptarray.cpp ../src/angel/src/scriptarray.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/scriptarray.o ../src/angel/src/scriptarray.cpp
build/objects/scripthelper.o: ../src/angel/src/scripthelper.cpp ../src/angel/src/scripthelper.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/scripthelper.o ../src/angel/src/scripthelper.cpp
build/objects/scriptstdstring.o: ../src/angel/src/scriptstdstring.cpp ../src/angel/src/scriptstdstring.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/scriptstdstring.o ../src/angel/src/scriptstdstring.cpp
build/objects/bjt.o: ../src/components/active/bjt.cpp ../src/components/active/bjt.h \
		../src/simulator/elements/active/e-bjt.h \
		/opt/qt5.15.15/include/QtGui/qtextoption.h \
		/opt/qt5.15.15/include/QtGui/qpen.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractscrollarea.h \
		/opt/qt5.15.15/include/QtWidgets/qframe.h \
		/opt/qt5.15.15/include/QtWidgets/QPlainTextEdit \
		/opt/qt5.15.15/include/QtWidgets/qplaintextedit.h \
		/opt/qt5.15.15/include/QtWidgets/qtextedit.h \
		/opt/qt5.15.15/include/QtGui/qtextdocument.h \
		/opt/qt5.15.15/include/QtGui/qtextcursor.h \
		/opt/qt5.15.15/include/QtGui/qtextformat.h \
		/opt/qt5.15.15/include/QtGui/qabstracttextdocumentlayout.h \
		/opt/qt5.15.15/include/QtGui/qtextlayout.h \
		/opt/qt5.15.15/include/QtGui/qglyphrun.h \
		/opt/qt5.15.15/include/QtGui/qrawfont.h \
		/opt/qt5.15.15/include/QtGui/qfontdatabase.h \
		/opt/qt5.15.15/include/QtGui/QSyntaxHighlighter \
		/opt/qt5.15.15/include/QtGui/qsyntaxhighlighter.h \
		/opt/qt5.15.15/include/QtGui/qtextobject.h \
		/opt/qt5.15.15/include/QtCore/QObject \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/bjt.o ../src/components/active/bjt.cpp
build/objects/comparator.o: ../src/components/active/comparator.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/active/comparator.h \
		ui_propdialog.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/comparator.o ../src/components/active/comparator.cpp
build/objects/diac.o: ../src/components/active/diac.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/active/diac.h \
		../src/simulator/elements/active/e-diode.h \
		../src/simulator/elements/passive/e-resistor.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/diac.o ../src/components/active/diac.cpp
build/objects/diode.o: ../src/components/active/diode.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/active/diode.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/diode.o ../src/components/active/diode.cpp
build/objects/mosfet.o: ../src/components/active/mosfet.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/active/mosfet.h \
		../src/simulator/elements/active/e-mosfet.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mosfet.o ../src/components/active/mosfet.cpp
build/objects/mux_analog.o: ../src/components/active/mux_analog.cpp ../src/components/active/mux_analog.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mux_analog.o ../src/components/active/mux_analog.cpp
build/objects/op_amp.o: ../src/components/active/op_amp.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/active/op_amp.h \
		ui_propdialog.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/op_amp.o ../src/components/active/op_amp.cpp
build/objects/scr.o: ../src/components/active/scr.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/active/scr.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/scr.o ../src/components/active/scr.cpp
build/objects/triac.o: ../src/components/active/triac.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/active/triac.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/triac.o ../src/components/active/triac.cpp
build/objects/volt_reg.o: ../src/components/active/volt_reg.cpp /opt/qt5.15.15/include/QtCore/QtMath \
		../src/components/active/volt_reg.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/volt_reg.o ../src/components/active/volt_reg.cpp
build/objects/zener.o: ../src/components/active/zener.cpp ../src/components/active/zener.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/zener.o ../src/components/active/zener.cpp
build/objects/header.o: ../src/components/connectors/header.cpp ../src/components/connectors/header.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/header.o ../src/components/connectors/header.cpp
build/objects/socket.o: ../src/components/connectors/socket.cpp ../src/components/connectors/socket.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/socket.o ../src/components/connectors/socket.cpp
build/objects/tunnel.o: ../src/components/connectors/tunnel.cpp /opt/qt5.15.15/include/QtWidgets/QInputDialog \
		/opt/qt5.15.15/include/QtWidgets/qinputdialog.h \
		../src/components/connectors/tunnel.h \
		ui_propdialog.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/tunnel.o ../src/components/connectors/tunnel.cpp
build/objects/ellipse.o: ../src/components/graphical/ellipse.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/graphical/ellipse.h \
		../src/components/graphical/shape.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/ellipse.o ../src/components/graphical/ellipse.cpp
build/objects/image.o: ../src/components/graphical/image.cpp /opt/qt5.15.15/include/QtWidgets/QMenu \
		/opt/qt5.15.15/include/QtGui/QMovie \
		../src/components/graphical/image.h \
		../src/components/graphical/shape.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/image.o ../src/components/graphical/image.cpp
build/objects/line.o: ../src/components/graphical/line.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/graphical/line.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/line.o ../src/components/graphical/line.cpp
build/objects/rectangle.o: ../src/components/graphical/rectangle.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/graphical/rectangle.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/rectangle.o ../src/components/graphical/rectangle.cpp
build/objects/shape.o: ../src/components/graphical/shape.cpp ../src/components/graphical/shape.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/shape.o ../src/components/graphical/shape.cpp
build/objects/textcomponent.o: ../src/components/graphical/textcomponent.cpp /opt/qt5.15.15/include/QtGui/QCursor \
		/opt/qt5.15.15/include/QtGui/QTextDocument \
		../src/components/graphical/textcomponent.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/textcomponent.o ../src/components/graphical/textcomponent.cpp
build/objects/adc.o: ../src/components/logic/adc.cpp ../src/components/logic/adc.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/adc.o ../src/components/logic/adc.cpp
build/objects/bcdbase.o: ../src/components/logic/bcdbase.cpp ../src/components/logic/bcdbase.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/bcdbase.o ../src/components/logic/bcdbase.cpp
build/objects/bcdto7s.o: ../src/components/logic/bcdto7s.cpp ../src/components/logic/bcdto7s.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/bcdto7s.o ../src/components/logic/bcdto7s.cpp
build/objects/bcdtodec.o: ../src/components/logic/bcdtodec.cpp ../src/components/logic/bcdtodec.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/bcdtodec.o ../src/components/logic/bcdtodec.cpp
build/objects/bincounter.o: ../src/components/logic/bincounter.cpp ../src/components/logic/bincounter.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/bincounter.o ../src/components/logic/bincounter.cpp
build/objects/buffer.o: ../src/components/logic/buffer.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/logic/buffer.h \
		../src/components/logic/gate.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/buffer.o ../src/components/logic/buffer.cpp
build/objects/bus.o: ../src/components/logic/bus.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/logic/bus.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/bus.o ../src/components/logic/bus.cpp
build/objects/dac.o: ../src/components/logic/dac.cpp ../src/components/logic/dac.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/dac.o ../src/components/logic/dac.cpp
build/objects/dectobcd.o: ../src/components/logic/dectobcd.cpp ../src/components/logic/dectobcd.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/dectobcd.o ../src/components/logic/dectobcd.cpp
build/objects/demux.o: ../src/components/logic/demux.cpp ../src/components/logic/demux.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/demux.o ../src/components/logic/demux.cpp
build/objects/dynamic_memory.o: ../src/components/logic/dynamic_memory.cpp /opt/qt5.15.15/include/QtCore/QDebug \
		../src/components/logic/dynamic_memory.h \
		../src/gui/memory/memtable.h \
		ui_memtable.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/dynamic_memory.o ../src/components/logic/dynamic_memory.cpp
build/objects/flipflopbase.o: ../src/components/logic/flipflopbase.cpp ../src/components/logic/flipflopbase.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/flipflopbase.o ../src/components/logic/flipflopbase.cpp
build/objects/flipflopd.o: ../src/components/logic/flipflopd.cpp ../src/components/logic/flipflopd.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/flipflopd.o ../src/components/logic/flipflopd.cpp
build/objects/flipflopjk.o: ../src/components/logic/flipflopjk.cpp ../src/components/logic/flipflopjk.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/flipflopjk.o ../src/components/logic/flipflopjk.cpp
build/objects/flipfloprs.o: ../src/components/logic/flipfloprs.cpp ../src/components/logic/flipfloprs.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/flipfloprs.o ../src/components/logic/flipfloprs.cpp
build/objects/flipflopt.o: ../src/components/logic/flipflopt.cpp ../src/components/logic/flipflopt.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/flipflopt.o ../src/components/logic/flipflopt.cpp
build/objects/fulladder.o: ../src/components/logic/fulladder.cpp ../src/components/logic/fulladder.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/fulladder.o ../src/components/logic/fulladder.cpp
build/objects/function.o: ../src/components/logic/function.cpp /opt/qt5.15.15/include/QtWidgets/QMenu \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsProxyWidget \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsproxywidget.h \
		/opt/qt5.15.15/include/QtWidgets/qgraphicswidget.h \
		/opt/qt5.15.15/include/QtWidgets/qgraphicslayoutitem.h \
		../src/components/logic/function.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/function.o ../src/components/logic/function.cpp
build/objects/gate.o: ../src/components/logic/gate.cpp ../src/components/logic/gate.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/gate.o ../src/components/logic/gate.cpp
build/objects/gate_and.o: ../src/components/logic/gate_and.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/logic/gate_and.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/gate_and.o ../src/components/logic/gate_and.cpp
build/objects/gate_or.o: ../src/components/logic/gate_or.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/logic/gate_or.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/gate_or.o ../src/components/logic/gate_or.cpp
build/objects/gate_xor.o: ../src/components/logic/gate_xor.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/logic/gate_xor.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/gate_xor.o ../src/components/logic/gate_xor.cpp
build/objects/i2cram.o: ../src/components/logic/i2cram.cpp /opt/qt5.15.15/include/QtWidgets/QMenu \
		../src/components/logic/i2cram.h \
		ui_memtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/i2cram.o ../src/components/logic/i2cram.cpp
build/objects/i2ctoparallel.o: ../src/components/logic/i2ctoparallel.cpp ../src/components/logic/i2ctoparallel.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/i2ctoparallel.o ../src/components/logic/i2ctoparallel.cpp
build/objects/latchd.o: ../src/components/logic/latchd.cpp ../src/components/logic/latchd.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/latchd.o ../src/components/logic/latchd.cpp
build/objects/lm555.o: ../src/components/logic/lm555.cpp /opt/qt5.15.15/include/QtCore/QtMath \
		../src/components/logic/lm555.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/lm555.o ../src/components/logic/lm555.cpp
build/objects/magnitudecomp.o: ../src/components/logic/magnitudecomp.cpp ../src/components/logic/magnitudecomp.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/magnitudecomp.o ../src/components/logic/magnitudecomp.cpp
build/objects/memory.o: ../src/components/logic/memory.cpp ../src/components/logic/memory.h \
		ui_memtable.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/memory.o ../src/components/logic/memory.cpp
build/objects/mux.o: ../src/components/logic/mux.cpp ../src/components/logic/mux.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mux.o ../src/components/logic/mux.cpp
build/objects/sevensegment_bcd.o: ../src/components/logic/sevensegment_bcd.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/logic/sevensegment_bcd.h \
		../src/components/outputs/leds/ledbase.h \
		../src/simulator/elements/outputs/e-led.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/sevensegment_bcd.o ../src/components/logic/sevensegment_bcd.cpp
build/objects/shiftreg.o: ../src/components/logic/shiftreg.cpp ../src/components/logic/shiftreg.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/shiftreg.o ../src/components/logic/shiftreg.cpp
build/objects/ampmeter.o: ../src/components/meters/ampmeter.cpp ../src/components/meters/ampmeter.h \
		../src/components/meters/meter.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/ampmeter.o ../src/components/meters/ampmeter.cpp
build/objects/freqmeter.o: ../src/components/meters/freqmeter.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		/opt/qt5.15.15/include/QtGui/QFont \
		../src/components/meters/freqmeter.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/freqmeter.o ../src/components/meters/freqmeter.cpp
build/objects/lachannel.o: ../src/components/meters/lachannel.cpp ../src/components/meters/lachannel.h \
		../src/gui/dataplotwidget/datachannel.h \
		../src/components/meters/logicanalizer.h \
		../src/gui/dataplotwidget/plotbase.h \
		../src/gui/dataplotwidget/plotdisplay.h \
		/opt/qt5.15.15/include/QtGui/QPixmap \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/lachannel.o ../src/components/meters/lachannel.cpp
build/objects/logicanalizer.o: ../src/components/meters/logicanalizer.cpp /opt/qt5.15.15/include/QtWidgets/QGraphicsProxyWidget \
		/opt/qt5.15.15/include/QtGui/qicon.h \
		../src/gui/dataplotwidget/lawidget.h \
		ui_lawidget.h \
		../src/gui/dataplotwidget/datalawidget.h \
		ui_datalawidget.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/logicanalizer.o ../src/components/meters/logicanalizer.cpp
build/objects/meter.o: ../src/components/meters/meter.cpp /opt/qt5.15.15/include/QtCore/QtMath \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/meter.o ../src/components/meters/meter.cpp
build/objects/oscope.o: ../src/components/meters/oscope.cpp /opt/qt5.15.15/include/QtWidgets/QGraphicsProxyWidget \
		../src/components/meters/oscope.h \
		../src/components/meters/oscopechannel.h \
		../src/gui/dataplotwidget/oscwidget.h \
		ui_oscwidget.h \
		../src/gui/dataplotwidget/datawidget.h \
		ui_datawidget.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/oscope.o ../src/components/meters/oscope.cpp
build/objects/oscopechannel.o: ../src/components/meters/oscopechannel.cpp ../src/components/meters/oscopechannel.h \
		ui_datawidget.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/oscopechannel.o ../src/components/meters/oscopechannel.cpp
build/objects/probe.o: ../src/components/meters/probe.cpp /opt/qt5.15.15/include/QtCore/QtMath \
		../src/components/meters/probe.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/probe.o ../src/components/meters/probe.cpp
build/objects/voltmeter.o: ../src/components/meters/voltmeter.cpp ../src/components/meters/voltmeter.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/voltmeter.o ../src/components/meters/voltmeter.cpp
build/objects/dht22.o: ../src/components/micro/dht22.cpp /opt/qt5.15.15/include/QtCore/QtMath \
		/opt/qt5.15.15/include/QtWidgets/qabstractbutton.h \
		../src/components/micro/dht22.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/dht22.o ../src/components/micro/dht22.cpp
build/objects/ds1307.o: ../src/components/micro/ds1307.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/micro/ds1307.h \
		../src/components/micro/rtclock.h \
		/opt/qt5.15.15/include/QtCore/QTime \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/ds1307.o ../src/components/micro/ds1307.cpp
build/objects/ds1621.o: ../src/components/micro/ds1621.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/micro/ds1621.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/ds1621.o ../src/components/micro/ds1621.cpp
build/objects/ds18b20.o: ../src/components/micro/ds18b20.cpp /opt/qt5.15.15/include/QtCore/QDebug \
		../src/components/micro/ds18b20.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/ds18b20.o ../src/components/micro/ds18b20.cpp
build/objects/esp01.o: ../src/components/micro/esp01.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		/opt/qt5.15.15/include/QtNetwork/QtNetwork \
		/opt/qt5.15.15/include/QtNetwork/QtNetworkDepends \
		/opt/qt5.15.15/include/QtCore/qeventloop.h \
		/opt/qt5.15.15/include/QtCore/qregularexpression.h \
		/opt/qt5.15.15/include/QtCore/qcoreapplication.h \
		/opt/qt5.15.15/include/QtCore/qstandardpaths.h \
		/opt/qt5.15.15/include/QtCore/qtranslator.h \
		/opt/qt5.15.15/include/QtNetwork/qtnetworkglobal.h \
		/opt/qt5.15.15/include/QtNetwork/qtnetwork-config.h \
		/opt/qt5.15.15/include/QtNetwork/qabstractnetworkcache.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkrequest.h \
		/opt/qt5.15.15/include/QtCore/QUrl \
		/opt/qt5.15.15/include/QtNetwork/qabstractsocket.h \
		/opt/qt5.15.15/include/QtNetwork/qauthenticator.h \
		/opt/qt5.15.15/include/QtNetwork/qdnslookup.h \
		/opt/qt5.15.15/include/QtNetwork/qdtls.h \
		/opt/qt5.15.15/include/QtNetwork/qsslsocket.h \
		/opt/qt5.15.15/include/QtNetwork/qtcpsocket.h \
		/opt/qt5.15.15/include/QtNetwork/qsslerror.h \
		/opt/qt5.15.15/include/QtNetwork/qsslcertificate.h \
		/opt/qt5.15.15/include/QtNetwork/qssl.h \
		/opt/qt5.15.15/include/QtCore/QFlags \
		/opt/qt5.15.15/include/QtNetwork/qhostaddress.h \
		/opt/qt5.15.15/include/QtNetwork/qhostinfo.h \
		/opt/qt5.15.15/include/QtNetwork/qhstspolicy.h \
		/opt/qt5.15.15/include/QtNetwork/qhttp2configuration.h \
		/opt/qt5.15.15/include/QtNetwork/qhttpmultipart.h \
		/opt/qt5.15.15/include/QtCore/QByteArray \
		/opt/qt5.15.15/include/QtCore/QIODevice \
		/opt/qt5.15.15/include/QtNetwork/QNetworkRequest \
		/opt/qt5.15.15/include/QtNetwork/qlocalserver.h \
		/opt/qt5.15.15/include/QtNetwork/qlocalsocket.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkaccessmanager.h \
		/opt/qt5.15.15/include/QtNetwork/QSslConfiguration \
		/opt/qt5.15.15/include/QtNetwork/qsslconfiguration.h \
		/opt/qt5.15.15/include/QtNetwork/QSslPreSharedKeyAuthenticator \
		/opt/qt5.15.15/include/QtNetwork/qsslpresharedkeyauthenticator.h \
		/opt/qt5.15.15/include/QtCore/QMetaType \
		/opt/qt5.15.15/include/QtNetwork/qnetworkconfigmanager.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkconfiguration.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkcookie.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkcookiejar.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkdatagram.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkdiskcache.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkinterface.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkproxy.h \
		/opt/qt5.15.15/include/QtNetwork/qnetworkreply.h \
		/opt/qt5.15.15/include/QtNetwork/QNetworkAccessManager \
		/opt/qt5.15.15/include/QtNetwork/qnetworksession.h \
		/opt/qt5.15.15/include/QtNetwork/qocspresponse.h \
		/opt/qt5.15.15/include/QtNetwork/qpassworddigestor.h \
		/opt/qt5.15.15/include/QtCore/QCryptographicHash \
		/opt/qt5.15.15/include/QtNetwork/qsctpserver.h \
		/opt/qt5.15.15/include/QtNetwork/qtcpserver.h \
		/opt/qt5.15.15/include/QtNetwork/qsctpsocket.h \
		/opt/qt5.15.15/include/QtNetwork/qsslcertificateextension.h \
		/opt/qt5.15.15/include/QtNetwork/qsslcipher.h \
		/opt/qt5.15.15/include/QtNetwork/qssldiffiehellmanparameters.h \
		/opt/qt5.15.15/include/QtNetwork/qsslellipticcurve.h \
		/opt/qt5.15.15/include/QtNetwork/qsslkey.h \
		/opt/qt5.15.15/include/QtNetwork/qudpsocket.h \
		/opt/qt5.15.15/include/QtNetwork/qtnetworkversion.h \
		/opt/qt5.15.15/include/QtNetwork/QTcpSocket \
		../src/components/micro/esp01.h \
		../src/gui/serial/serialmon.h \
		ui_serialmon.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/esp01.o ../src/components/micro/esp01.cpp
build/objects/ky023.o: ../src/components/micro/ky023.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/micro/ky023.h \
		/opt/qt5.15.15/include/QtCore/qelapsedtimer.h \
		/opt/qt5.15.15/include/QtCore/qfuture.h \
		/opt/qt5.15.15/include/QtCore/qfutureinterface.h \
		/opt/qt5.15.15/include/QtCore/qrunnable.h \
		/opt/qt5.15.15/include/QtCore/qexception.h \
		/opt/qt5.15.15/include/QtCore/qresultstore.h \
		/opt/qt5.15.15/include/QtCore/qbasictimer.h \
		/opt/qt5.15.15/include/QtWidgets/QToolButton \
		/opt/qt5.15.15/include/QtWidgets/qtoolbutton.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/ky023.o ../src/components/micro/ky023.cpp
build/objects/ky040.o: ../src/components/micro/ky040.cpp /opt/qt5.15.15/include/QtWidgets/QGraphicsProxyWidget \
		../src/components/micro/ky040.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/ky040.o ../src/components/micro/ky040.cpp
build/objects/rtclock.o: ../src/components/micro/rtclock.cpp ../src/components/micro/rtclock.h \
		/opt/qt5.15.15/include/QtCore/qdatetime.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/rtclock.o ../src/components/micro/rtclock.cpp
build/objects/serialport.o: ../src/components/micro/serialport.cpp /opt/qt5.15.15/include/QtWidgets/QGraphicsProxyWidget \
		../src/components/micro/serialport.h \
		/opt/qt5.15.15/include/QtSerialPort/QSerialPort \
		/opt/qt5.15.15/include/QtSerialPort/qserialport.h \
		/opt/qt5.15.15/include/QtSerialPort/qserialportglobal.h \
		ui_serialmon.h \
		../src/utils.h \
		/opt/qt5.15.15/include/QtCore/qmath.h \
		/opt/qt5.15.15/include/QtCore/qdir.h \
		/opt/qt5.15.15/include/QtCore/qfileinfo.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/serialport.o ../src/components/micro/serialport.cpp
build/objects/serialterm.o: ../src/components/micro/serialterm.cpp /opt/qt5.15.15/include/QtWidgets/QGraphicsProxyWidget \
		../src/components/micro/serialterm.h \
		ui_serialmon.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/serialterm.o ../src/components/micro/serialterm.cpp
build/objects/sr04.o: ../src/components/micro/sr04.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/micro/sr04.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/sr04.o ../src/components/micro/sr04.cpp
build/objects/touchpad.o: ../src/components/micro/touchpad.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/micro/touchpad.h \
		../src/components/micro/touchpadwidget.h \
		/opt/qt5.15.15/include/QtCore/qtimer.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/touchpad.o ../src/components/micro/touchpad.cpp
build/objects/touchpadwidget.o: ../src/components/micro/touchpadwidget.cpp /opt/qt5.15.15/include/QtGui/QMouseEvent \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/touchpadwidget.o ../src/components/micro/touchpadwidget.cpp
build/objects/dial.o: ../src/components/other/dial.cpp /opt/qt5.15.15/include/QtWidgets/QAbstractSlider \
		../src/components/other/dial.h \
		../src/gui/circuitwidget/dialed.h \
		ui_propdialog.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/dial.o ../src/components/other/dial.cpp
build/objects/packagepin.o: ../src/components/other/packagepin.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/other/packagepin.h \
		../src/components/other/subpackage.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/packagepin.o ../src/components/other/packagepin.cpp
build/objects/subpackage.o: ../src/components/other/subpackage.cpp /opt/qt5.15.15/include/QtWidgets/QApplication \
		/opt/qt5.15.15/include/QtWidgets/qapplication.h \
		/opt/qt5.15.15/include/QtWidgets/qdesktopwidget.h \
		/opt/qt5.15.15/include/QtGui/qguiapplication.h \
		/opt/qt5.15.15/include/QtGui/qinputmethod.h \
		/opt/qt5.15.15/include/QtWidgets/QLabel \
		/opt/qt5.15.15/include/QtWidgets/qlabel.h \
		/opt/qt5.15.15/include/QtWidgets/QSpinBox \
		/opt/qt5.15.15/include/QtWidgets/qspinbox.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractspinbox.h \
		/opt/qt5.15.15/include/QtGui/qvalidator.h \
		/opt/qt5.15.15/include/QtWidgets/QCheckBox \
		/opt/qt5.15.15/include/QtWidgets/qcheckbox.h \
		/opt/qt5.15.15/include/QtWidgets/QDialogButtonBox \
		/opt/qt5.15.15/include/QtWidgets/qdialogbuttonbox.h \
		/opt/qt5.15.15/include/QtWidgets/QComboBox \
		/opt/qt5.15.15/include/QtWidgets/qcombobox.h \
		/opt/qt5.15.15/include/QtCore/qabstractitemmodel.h \
		/opt/qt5.15.15/include/QtCore/qitemselectionmodel.h \
		ui_managecomps.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/subpackage.o ../src/components/other/subpackage.cpp
build/objects/testunit.o: ../src/components/other/testunit.cpp ../src/components/other/testunit.h \
		../src/components/other/truthtable/truthtable.h \
		ui_truthtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/testunit.o ../src/components/other/testunit.cpp
build/objects/audio_out.o: ../src/components/outputs/audio_out.cpp /opt/qt5.15.15/include/QtCore/QCoreApplication \
		../src/components/outputs/audio_out.h \
		/opt/qt5.15.15/include/QtMultimedia/QAudioOutput \
		/opt/qt5.15.15/include/QtMultimedia/qaudiooutput.h \
		/opt/qt5.15.15/include/QtMultimedia/qtmultimediaglobal.h \
		/opt/qt5.15.15/include/QtMultimedia/qtmultimedia-config.h \
		/opt/qt5.15.15/include/QtMultimedia/qmultimedia.h \
		/opt/qt5.15.15/include/QtMultimedia/qaudio.h \
		/opt/qt5.15.15/include/QtMultimedia/qaudioformat.h \
		/opt/qt5.15.15/include/QtMultimedia/qaudiodeviceinfo.h \
		ui_propdialog.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/audio_out.o ../src/components/outputs/audio_out.cpp
build/objects/lamp.o: ../src/components/outputs/lamp.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/outputs/lamp.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/lamp.o ../src/components/outputs/lamp.cpp
build/objects/battery.o: ../src/components/sources/battery.cpp ../src/components/sources/battery.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/battery.o ../src/components/sources/battery.cpp
build/objects/clock-base.o: ../src/components/sources/clock-base.cpp ../src/components/sources/clock-base.h \
		../src/components/sources/fixedvolt.h \
		/opt/qt5.15.15/include/QtGui/qpainterpath.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/clock-base.o ../src/components/sources/clock-base.cpp
build/objects/clock.o: ../src/components/sources/clock.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		/opt/qt5.15.15/include/QtGui/qpainter.h \
		../src/components/sources/clock.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/clock.o ../src/components/sources/clock.cpp
build/objects/csource.o: ../src/components/sources/csource.cpp /opt/qt5.15.15/include/QtCore/QtMath \
		../src/components/sources/csource.h \
		ui_propdialog.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/csource.o ../src/components/sources/csource.cpp
build/objects/currsource.o: ../src/components/sources/currsource.cpp ../src/components/sources/currsource.h \
		../src/components/sources/varsource.h \
		ui_propdialog.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/currsource.o ../src/components/sources/currsource.cpp
build/objects/fixedvolt.o: ../src/components/sources/fixedvolt.cpp /opt/qt5.15.15/include/QtGui/QPainter \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/fixedvolt.o ../src/components/sources/fixedvolt.cpp
build/objects/ground.o: ../src/components/sources/ground.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/sources/ground.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/ground.o ../src/components/sources/ground.cpp
build/objects/rail.o: ../src/components/sources/rail.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/sources/rail.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/rail.o ../src/components/sources/rail.cpp
build/objects/varsource.o: ../src/components/sources/varsource.cpp /opt/qt5.15.15/include/QtWidgets/QGraphicsProxyWidget \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsscene.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/varsource.o ../src/components/sources/varsource.cpp
build/objects/voltsource.o: ../src/components/sources/voltsource.cpp ../src/components/sources/voltsource.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgetsglobal.h \
		/opt/qt5.15.15/include/QtGui/qtguiglobal.h \
		/opt/qt5.15.15/include/QtCore/qglobal.h \
		/opt/qt5.15.15/include/QtCore/qconfig-bootstrapped.h \
		/opt/qt5.15.15/include/QtCore/qconfig.h \
		/opt/qt5.15.15/include/QtCore/qtcore-config.h \
		/opt/qt5.15.15/include/QtCore/qsystemdetection.h \
		/opt/qt5.15.15/include/QtCore/qprocessordetection.h \
		/opt/qt5.15.15/include/QtCore/qcompilerdetection.h \
		/opt/qt5.15.15/include/QtCore/qtypeinfo.h \
		/opt/qt5.15.15/include/QtCore/qsysinfo.h \
		/opt/qt5.15.15/include/QtCore/qlogging.h \
		/opt/qt5.15.15/include/QtCore/qflags.h \
		/opt/qt5.15.15/include/QtCore/qatomic.h \
		/opt/qt5.15.15/include/QtCore/qbasicatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_bootstrap.h \
		/opt/qt5.15.15/include/QtCore/qgenericatomic.h \
		/opt/qt5.15.15/include/QtCore/qatomic_cxx11.h \
		/opt/qt5.15.15/include/QtCore/qatomic_msvc.h \
		/opt/qt5.15.15/include/QtCore/qglobalstatic.h \
		/opt/qt5.15.15/include/QtCore/qmutex.h \
		/opt/qt5.15.15/include/QtCore/qnumeric.h \
		/opt/qt5.15.15/include/QtCore/qversiontagging.h \
		/opt/qt5.15.15/include/QtGui/qtgui-config.h \
		/opt/qt5.15.15/include/QtWidgets/qtwidgets-config.h \
		/opt/qt5.15.15/include/QtCore/qstring.h \
		/opt/qt5.15.15/include/QtCore/qchar.h \
		/opt/qt5.15.15/include/QtCore/qbytearray.h \
		/opt/qt5.15.15/include/QtCore/qrefcount.h \
		/opt/qt5.15.15/include/QtCore/qarraydata.h \
		/opt/qt5.15.15/include/QtCore/qstringliteral.h \
		/opt/qt5.15.15/include/QtCore/qstringalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qstringview.h \
		/opt/qt5.15.15/include/QtCore/qstringbuilder.h \
		ui_propdialog.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/voltsource.o ../src/components/sources/voltsource.cpp
build/objects/wavegen.o: ../src/components/sources/wavegen.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		/opt/qt5.15.15/include/QtCore/qnamespace.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs.h \
		/opt/qt5.15.15/include/QtCore/qobjectdefs_impl.h \
		/opt/qt5.15.15/include/QtCore/qlist.h \
		/opt/qt5.15.15/include/QtCore/qalgorithms.h \
		/opt/qt5.15.15/include/QtCore/qiterator.h \
		/opt/qt5.15.15/include/QtCore/qhashfunctions.h \
		/opt/qt5.15.15/include/QtCore/qpair.h \
		/opt/qt5.15.15/include/QtCore/qvector.h \
		/opt/qt5.15.15/include/QtCore/qcontainertools_impl.h \
		/opt/qt5.15.15/include/QtCore/qbytearraylist.h \
		/opt/qt5.15.15/include/QtCore/qregexp.h \
		/opt/qt5.15.15/include/QtCore/qstringmatcher.h \
		/opt/qt5.15.15/include/QtCore/qobject.h \
		/opt/qt5.15.15/include/QtCore/qcoreevent.h \
		/opt/qt5.15.15/include/QtCore/qmetatype.h \
		/opt/qt5.15.15/include/QtCore/qvarlengtharray.h \
		/opt/qt5.15.15/include/QtCore/qcontainerfwd.h \
		/opt/qt5.15.15/include/QtCore/qobject_impl.h \
		/opt/qt5.15.15/include/QtCore/QDir \
		../src/components/sources/wavegen.h \
		ui_propdialog.h \
		../src/mainwindow.h \
		/opt/qt5.15.15/include/QtWidgets/QMainWindow \
		/opt/qt5.15.15/include/QtWidgets/qmainwindow.h \
		/opt/qt5.15.15/include/QtWidgets/qtabwidget.h \
		../src/gui/circuitwidget/circuitwidget.h \
		/opt/qt5.15.15/include/QtWidgets/qmenu.h \
		/opt/qt5.15.15/include/QtWidgets/qaction.h \
		/opt/qt5.15.15/include/QtWidgets/qactiongroup.h \
		/opt/qt5.15.15/include/QtWidgets/QToolBar \
		/opt/qt5.15.15/include/QtWidgets/qtoolbar.h \
		/opt/qt5.15.15/include/QtWidgets/qboxlayout.h \
		/opt/qt5.15.15/include/QtWidgets/qlayout.h \
		/opt/qt5.15.15/include/QtWidgets/qlayoutitem.h \
		/opt/qt5.15.15/include/QtWidgets/qgridlayout.h \
		../src/gui/circuitwidget/circuitview.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsView \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsview.h \
		/opt/qt5.15.15/include/QtWidgets/qscrollarea.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/wavegen.o ../src/components/sources/wavegen.cpp
build/objects/board.o: ../src/components/subcircuits/board.cpp ../src/components/subcircuits/board.h \
		../src/components/subcircuits/subcircuit.h \
		/opt/qt5.15.15/include/QtCore/qpoint.h \
		/opt/qt5.15.15/include/QtCore/qstringlist.h \
		/opt/qt5.15.15/include/QtCore/qscopedpointer.h \
		/opt/qt5.15.15/include/QtCore/qvariant.h \
		/opt/qt5.15.15/include/QtCore/qmap.h \
		/opt/qt5.15.15/include/QtCore/qdebug.h \
		/opt/qt5.15.15/include/QtCore/qhash.h \
		/opt/qt5.15.15/include/QtCore/qtextstream.h \
		/opt/qt5.15.15/include/QtCore/qiodevice.h \
		/opt/qt5.15.15/include/QtCore/qlocale.h \
		/opt/qt5.15.15/include/QtCore/qshareddata.h \
		/opt/qt5.15.15/include/QtCore/qset.h \
		/opt/qt5.15.15/include/QtCore/qcontiguouscache.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer.h \
		/opt/qt5.15.15/include/QtCore/qsharedpointer_impl.h \
		/opt/qt5.15.15/include/QtCore/qrect.h \
		/opt/qt5.15.15/include/QtCore/qmargins.h \
		/opt/qt5.15.15/include/QtCore/qsize.h \
		/opt/qt5.15.15/include/QtGui/qmatrix.h \
		/opt/qt5.15.15/include/QtGui/qpolygon.h \
		/opt/qt5.15.15/include/QtGui/qregion.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs.h \
		/opt/qt5.15.15/include/QtGui/qwindowdefs_win.h \
		/opt/qt5.15.15/include/QtCore/qdatastream.h \
		/opt/qt5.15.15/include/QtCore/qline.h \
		/opt/qt5.15.15/include/QtGui/qtransform.h \
		/opt/qt5.15.15/include/QtGui/qpixmap.h \
		/opt/qt5.15.15/include/QtGui/qpaintdevice.h \
		/opt/qt5.15.15/include/QtGui/qcolor.h \
		/opt/qt5.15.15/include/QtGui/qrgb.h \
		/opt/qt5.15.15/include/QtGui/qrgba64.h \
		/opt/qt5.15.15/include/QtGui/qimage.h \
		/opt/qt5.15.15/include/QtGui/qpixelformat.h \
		/opt/qt5.15.15/include/QtGui/qbrush.h \
		/opt/qt5.15.15/include/QtGui/qfont.h \
		../src/components/subcircuits/shield.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/board.o ../src/components/subcircuits/board.cpp
build/objects/chip.o: ../src/components/subcircuits/chip.cpp ../src/components/subcircuits/chip.h \
		../src/components/component.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsItem \
		/opt/qt5.15.15/include/QtWidgets/qgraphicsitem.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsSceneMouseEvent \
		/opt/qt5.15.15/include/QtWidgets/qgraphicssceneevent.h \
		../src/gui/circuitwidget/compbase.h \
		/opt/qt5.15.15/include/QtCore/QString \
		/opt/qt5.15.15/include/QtCore/QPointF \
		/opt/qt5.15.15/include/QtCore/QMap \
		../src/gui/properties/proputils.h \
		/opt/qt5.15.15/include/QtCore/QStringRef \
		/opt/qt5.15.15/include/QtWidgets/qwidget.h \
		/opt/qt5.15.15/include/QtGui/qpalette.h \
		/opt/qt5.15.15/include/QtGui/qfontmetrics.h \
		/opt/qt5.15.15/include/QtGui/qfontinfo.h \
		/opt/qt5.15.15/include/QtWidgets/qsizepolicy.h \
		/opt/qt5.15.15/include/QtGui/qcursor.h \
		/opt/qt5.15.15/include/QtGui/qkeysequence.h \
		/opt/qt5.15.15/include/QtGui/qevent.h \
		/opt/qt5.15.15/include/QtCore/qurl.h \
		/opt/qt5.15.15/include/QtCore/qurlquery.h \
		/opt/qt5.15.15/include/QtCore/qfile.h \
		/opt/qt5.15.15/include/QtCore/qfiledevice.h \
		/opt/qt5.15.15/include/QtGui/qvector2d.h \
		/opt/qt5.15.15/include/QtGui/qtouchdevice.h \
		/opt/qt5.15.15/include/QtCore/QHash \
		../src/gui/circuitwidget/connector.h \
		../src/gui/circuitwidget/circuit.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsScene \
		/opt/qt5.15.15/include/QtCore/QTimer \
		../src/gui/circuitwidget/pin.h \
		../src/utils.h \
		/opt/qt5.15.15/include/QtCore/QList
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/chip.o ../src/components/subcircuits/chip.cpp
build/objects/logicsubc.o: ../src/components/subcircuits/logicsubc.cpp ../src/components/subcircuits/logicsubc.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/logicsubc.o ../src/components/subcircuits/logicsubc.cpp
build/objects/module.o: ../src/components/subcircuits/module.cpp ../src/components/subcircuits/module.h \
		../src/components/subcircuits/shield.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/module.o ../src/components/subcircuits/module.cpp
build/objects/shield.o: ../src/components/subcircuits/shield.cpp ../src/components/subcircuits/shield.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/shield.o ../src/components/subcircuits/shield.cpp
build/objects/subcircuit.o: ../src/components/subcircuits/subcircuit.cpp ../src/components/subcircuits/subcircuit.h \
		../src/gui/componentlist/itemlibrary.h \
		../src/gui/componentlist/componentlist.h \
		/opt/qt5.15.15/include/QtGui/QDropEvent \
		/opt/qt5.15.15/include/QtWidgets/QTreeWidget \
		/opt/qt5.15.15/include/QtWidgets/qtreewidget.h \
		/opt/qt5.15.15/include/QtWidgets/qtreeview.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractitemview.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractitemdelegate.h \
		/opt/qt5.15.15/include/QtWidgets/qstyleoption.h \
		/opt/qt5.15.15/include/QtWidgets/qslider.h \
		/opt/qt5.15.15/include/QtWidgets/qabstractslider.h \
		/opt/qt5.15.15/include/QtWidgets/qstyle.h \
		/opt/qt5.15.15/include/QtWidgets/qtabbar.h \
		/opt/qt5.15.15/include/QtWidgets/qrubberband.h \
		/opt/qt5.15.15/include/QtWidgets/qtreewidgetitemiterator.h \
		../src/gui/componentlist/managecomps.h \
		ui_managecomps.h \
		../src/utils.h \
		/opt/qt5.15.15/include/QtCore/QList \
		ui_ramtable.h \
		../src/components/linker.h \
		/opt/qt5.15.15/include/QtCore/QSet \
		../src/gui/properties/stringprop.h \
		../src/gui/properties/comproperty.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/subcircuit.o ../src/components/subcircuits/subcircuit.cpp
build/objects/keypad.o: ../src/components/switches/keypad.cpp ../src/components/switches/keypad.h \
		../src/components/switches/push_base.h \
		../src/components/switches/switch_base.h \
		../src/components/switches/mech_contact.h \
		../src/simulator/simulator.h \
		/opt/qt5.15.15/include/QtCore/QElapsedTimer \
		/opt/qt5.15.15/include/QtCore/QFuture \
		../src/gui/properties/comproperty.h \
		../src/gui/properties/intprop.h \
		../src/gui/properties/numprop.h \
		../src/gui/properties/boolprop.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/keypad.o ../src/components/switches/keypad.cpp
build/objects/mech_contact.o: ../src/components/switches/mech_contact.cpp ../src/components/switches/mech_contact.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/mech_contact.o ../src/components/switches/mech_contact.cpp
build/objects/push.o: ../src/components/switches/push.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/switches/push.h \
		../src/gui/properties/boolprop.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/push.o ../src/components/switches/push.cpp
build/objects/push_base.o: ../src/components/switches/push_base.cpp ../src/components/switches/push_base.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/push_base.o ../src/components/switches/push_base.cpp
build/objects/relay.o: ../src/components/switches/relay.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/components/switches/relay.h \
		../src/components/passive/reactive/inductor.h \
		../src/components/passive/reactive/reactive.h \
		../src/simulator/elements/passive/e-reactive.h \
		../src/components/comp2pin.h \
		../src/gui/properties/doubleprop.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/relay.o ../src/components/switches/relay.cpp
build/objects/switch.o: ../src/components/switches/switch.cpp /opt/qt5.15.15/include/QtWidgets/QGraphicsProxyWidget \
		../src/components/switches/switch.h \
		../src/gui/custombutton.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/switch.o ../src/components/switches/switch.cpp
build/objects/switch_base.o: ../src/components/switches/switch_base.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		../src/gui/circuitwidget/label.h \
		/opt/qt5.15.15/include/QtWidgets/QGraphicsTextItem \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/switch_base.o ../src/components/switches/switch_base.cpp
build/objects/switchdip.o: ../src/components/switches/switchdip.cpp /opt/qt5.15.15/include/QtGui/QPainter \
		/opt/qt5.15.15/include/QtWidgets/QPushButton \
		/opt/qt5.15.15/include/QtWidgets/qpushbutton.h \
		../src/components/switches/switchdip.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/switchdip.o ../src/components/switches/switchdip.cpp
build/objects/about.o: ../src/gui/appdialogs/about.cpp /opt/qt5.15.15/include/QtGui/QDesktopServices \
		/opt/qt5.15.15/include/QtGui/qdesktopservices.h \
		/opt/qt5.15.15/include/QtWidgets/QTabBar \
		../src/gui/appdialogs/about.h \
		ui_about.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/about.o ../src/gui/appdialogs/about.cpp
build/objects/appdialog.o: ../src/gui/appdialogs/appdialog.cpp ../src/gui/appdialogs/appdialog.h \
		ui_appdialog.h \
		/opt/qt5.15.15/include/QtWidgets/QVBoxLayout \
		../src/gui/outpaneltext.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/appdialog.o ../src/gui/appdialogs/appdialog.cpp
build/objects/infowidget.o: ../src/gui/appdialogs/infowidget.cpp ../src/gui/appdialogs/infowidget.h \
		ui_infowidget.h \
		../src/microsim/mcutypes.h \
		../src/microsim/mcusignal.h \
		../src/microsim/mcudataspace.h \
		../src/gui/memory/ramtable.h \
		ui_ramtable.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/infowidget.o ../src/gui/appdialogs/infowidget.cpp
build/objects/circuit.o: ../src/gui/circuitwidget/circuit.cpp /opt/qt5.15.15/include/QtWidgets/QMessageBox \
		/opt/qt5.15.15/include/QtWidgets/qmessagebox.h \
		/opt/qt5.15.15/include/QtWidgets/QFileDialog \
		/opt/qt5.15.15/include/QtWidgets/qfiledialog.h \
		/opt/qt5.15.15/include/QtGui/QClipboard \
		/opt/qt5.15.15/include/QtGui/qclipboard.h \
		/opt/qt5.15.15/include/QtCore/QMimeData \
		/opt/qt5.15.15/include/QtCore/qmimedata.h \
		/opt/qt5.15.15/include/QtCore/QSettings \
		/opt/qt5.15.15/include/QtCore/qsettings.h \
		../src/gui/circuitwidget/connectorline.h \
		ui_managecomps.h \
		../src/components/node.h \
		../src/utils.h \
		../src/microsim/mcu.h \
		../src/microsim/e_mcu.h \
		../src/microsim/e_iou.h \
		../src/microsim/modules/usart/usartmodule.h \
		../src/microsim/mcuinterrupts.h \
		ui_ramtable.h \
		../src/microsim/mcusleep.h \
		build/moc/moc_circuit.cpp
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/circuit.o ../src/gui/circuitwidget/circuit.cpp
build/objects/circuitview.o: ../src/gui/circuitwidget/circuitview.cpp /opt/qt5.15.15/include/QtCore/QDebug \
		/opt/qt5.15.15/include/QtSvg/QSvgGenerator \
		/opt/qt5.15.15/include/QtSvg/qsvggenerator.h \
		/opt/qt5.15.15/include/QtSvg/qtsvgglobal.h \
		/opt/qt5.15.15/include/QtWidgets/qdialog.h \
		/opt/qt5.15.15/include/QtGui/QGuiApplication \
		/opt/qt5.15.15/include/QtWidgets/QScrollBar \
		/opt/qt5.15.15/include/QtWidgets/qscrollbar.h \
		/opt/qt5.15.15/include/QtWidgets/QTreeWidgetItem \
		/opt/qt5.15.15/include/QtWidgets/QDialog \
		ui_managecomps.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/circuitview.o ../src/gui/circuitwidget/circuitview.cpp
build/objects/circuitwidget.o: ../src/gui/circuitwidget/circuitwidget.cpp /opt/qt5.15.15/include/QtWidgets/QSplitter \
		/opt/qt5.15.15/include/QtWidgets/qsplitter.h \
		../src/gui/editorwidget/editorwindow.h \
		../src/gui/editorwidget/editorwidget.h \
		../src/gui/editorwidget/codeeditor.h \
		../src/gui/editorwidget/basedebugger.h \
		../src/gui/editorwidget/compiler.h \
		/opt/qt5.15.15/include/QtCore/QProcess \
		/opt/qt5.15.15/include/QtCore/qprocess.h \
		ui_appdialog.h \
		../src/gui/filebrowser/filebrowser.h \
		/opt/qt5.15.15/include/QtWidgets/QTreeView \
		ui_infowidget.h \
		ui_about.h \
		../src/utils.h \
		build/moc/moc_circuitwidget.cpp
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/circuitwidget.o ../src/gui/circuitwidget/circuitwidget.cpp
build/objects/compbase.o: ../src/gui/circuitwidget/compbase.cpp ../src/gui/circuitwidget/compbase.h \
		../src/gui/properties/propdialog.h \
		ui_propdialog.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/compbase.o ../src/gui/circuitwidget/compbase.cpp
build/objects/connbase.o: ../src/gui/circuitwidget/connbase.cpp ../src/gui/circuitwidget/connbase.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/connbase.o ../src/gui/circuitwidget/connbase.cpp
build/objects/connector.o: ../src/gui/circuitwidget/connector.cpp ../src/gui/circuitwidget/connector.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/connector.o ../src/gui/circuitwidget/connector.cpp
build/objects/connectorline.o: ../src/gui/circuitwidget/connectorline.cpp ../src/gui/circuitwidget/connectorline.h \
		../src/utils.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/connectorline.o ../src/gui/circuitwidget/connectorline.cpp
build/objects/dialed.o: ../src/gui/circuitwidget/dialed.cpp /opt/qt5.15.15/include/QtWidgets/QAbstractSlider \
		../src/gui/dialwidget.h \
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/dialed.o ../src/gui/circuitwidget/dialed.cpp
build/objects/iopin.o: ../src/gui/circuitwidget/iopin.cpp /opt/qt5.15.15/include/QtCore/QtMath \
		../src/gui/circuitwidget/iopin.h \
		/opt/qt5.15.15/include/QtGui/QColor \
		../src/angel/include/angelscript.h
	$(CXX) -c $(CXXFLAGS) $(INCPATH) -o build/objects/iopin.o ../src/gui/circuitwidget/iopin.cpp
build/objects/ioport.o: ../src/gui/circuitwidget/ioport.cpp /opt/qt5.15.15/include/QtCore/QDebug \
		/opt/qt5.15.15/i
